What are the best aftermarket headers?
Discussion in 'Performance and Tuning' started by TreyStewart, Nov 2, 2015.
  1. Nov 2, 2015 at 1:47 PM
    TreyStewart
    TreyStewart [OP] Well-Known Member
    Trey
    Tigerville, South Carolina
    2013 PreRunner
    URD everything, nfab front bumper with 2 LED bars, maxtrax spindle lift, Baja rack
    Hi,
    I'm going to be getting some headers around Christmas time so I've been doing all the research about which ones are the best and which one provides best gains. From what I've found all the companies say the same thing about their product. I'm leaning toward the URD headers right now. Anyone have any experience with these or DTs and JBAs?
  2. Nov 2, 2015 at 3:05 PM
    StuckinOhio
    StuckinOhio Well-Known Member
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    Currently the top 3 are:
    URD equal length
    Pros: Wide powerband. No loss in low end
    Cons: 1st member that got them had fit and finish issues. He re-machined the exhaust flange and his headers contacted his frame.
    AFE shorties
    Pros: Biggest gains are in low end
    Cons: price / still have cats
    Doug thorley long pipes
    Pros: high end gains no Cats
    Cons: low end power loss for N/A engines
    honestly evaluate what you plan to do with your truck and pick the ones that best suits your needs
    MadDaddy likes this.
  3. Nov 2, 2015 at 3:07 PM
    Tacoma SS
    Tacoma SS Well-Known Member
    Denver
    Supercharged 09 on 35s
    Boost and flex and 35s
    AFE or JBA?
  4. Nov 2, 2015 at 3:14 PM
    StuckinOhio
    Mark
    Ohio
    12' v6 AC 4x4 SR5
    AFE. Shorties come ready to bolt on.
    JBA's you have to remove stock headers hack off catalytic converter/ weld stock catalytic back on JBA headers then install.
  5. Nov 2, 2015 at 6:09 PM
    TreyStewart
    Trey
    2013 PreRunner
    Well I have a prerunner, so I won't be doing anything crazy off-road. My goal is to make it as fast as possible
  6. Nov 3, 2015 at 4:14 PM
    Justus
    Justus fucks not given
    Nabisco the kid
    In ur toolbox
    stockish
    quick....... U have a governor, so it will not be faster, but quicker.
    freddy2923 and MadDaddy like this.
  7. Nov 3, 2015 at 4:16 PM
    Tacoma SS
    Denver
    Wat?
  8. Nov 3, 2015 at 4:20 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Faster, typically higher top speed........ Quicker, typically quicker acceleration to a given speed
  9. Nov 3, 2015 at 4:30 PM
    Justus
    Nabisco the kid
    In ur toolbox
    stockish
    Well, u could make it faster, but it cannot be discussed here.
  10. Nov 3, 2015 at 5:28 PM
    TreyStewart
    Trey
    2013 PreRunner
    Lol I'm not trying to go 110 plus in my truck. I don't think it as made for speeds any faster than that. So yes, I would like to make it quicker. Quicker in a 0-60
    Justus[QUOTED] likes this.
  11. Nov 4, 2015 at 6:37 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Seen mine do 130. URD's has been 150. ;)
    I'd like to get a certificate for doing just under 190.
    Thuguon2.7 likes this.
  12. Nov 4, 2015 at 6:56 AM
    TreyStewart
    Trey
    2013 PreRunner
    Mph?
  13. Nov 4, 2015 at 7:09 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Correct
  14. Nov 4, 2015 at 7:11 AM
    Tacoma SS
    Denver
    $1200 for the jba's LOL
  15. Nov 4, 2015 at 7:36 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    URD Spec-U.
  16. Nov 4, 2015 at 7:42 AM
    Tacoma SS
    Denver
    I can't do long tube... Stupid emissions
    TreyStewart[OP] likes this.
  17. Nov 4, 2015 at 8:10 AM
    TreyStewart
    Trey
    2013 PreRunner
    Has anyone else installed the URD headers? Just wondering if that was a fluke or not
  18. Nov 4, 2015 at 8:19 AM
    Lurkin
    Lurkin Well-Known Member
    Rod
    Pearland, TX
    09 PreRunner SR5 DC
    Oh, you'll be certifiable at 190.... :D
    Torspd[QUOTED] likes this.
  19. Nov 4, 2015 at 9:12 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I helped Lucario Runner on his 4Runner. Had no issues what so ever. That ecu is much more sensitive to exhaust leaks than the Tacoma's as well. Nor does his header have a clearance problem.
    Some are different. They are hand made, last I checked, with a jig. Might be machine made now, but I am not certain. If they are hand made still, there will always be slight differences. As well as the differences each vehicle has from how the owner uses it.
  20. Nov 5, 2015 at 8:38 AM
    steezinstangl
    steezinstangl Well-Known Member
    Elk Grove, Ca
    2008 FJ Cruiser
    i know torspd and i were discussing the quality of OBX headers and y pipe a while ago on another thread, well i ended up biting the bullet and buying them. the quality is top notch actually which surprised me and the fit and finish was good. i ordered the extra large gaskets from URD for where the header collectors and y pipe meet. the only problem i have is where the y pipe comes together around the transfer case (4wd for me) and there is a little bit of a gap, but some high temp silicone and an overlapping clamp will fix it right up. here's a video of my exhaust: https://www.youtube.com/watch?v=7xTQM5LVtok
    Edit: i know the URD equal length headers are better, but i just didn't want to pay that much for only headers.
    TreyStewart[OP] and Justus like this.
