What are some ways to upgrade the power on a 2.7l 4cyl Tacoma?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by elrobbygtaco, May 24, 2020.
  1. May 24, 2020 at 7:24 PM
    elrobbygtaco
    elrobbygtaco [OP] Member
    Robby
    2.7L 2013 Toyota Tacoma 4x4
    Ive looked into headers, cat back exhaust, chip, supercharger, intake spacer, air flow. Are there any tips on increasing this engines power? Interested in preferred brands and opinions.
    Thanks!
  2. May 24, 2020 at 7:29 PM
    ryfox0276
    ryfox0276 Well-Known Member
    Montana
    2013 RC 4x4
    You've pretty much got it. I've heard performance gains from headers, supercharger and turbo. Everything else either is snake oil, or won't make a difference till you supercharge it/ turbo it.
  3. May 24, 2020 at 7:30 PM
    elrobbygtaco
    Robby
    there are turbo's for this engine? I couldn't find a turbo when I was looking
  4. May 24, 2020 at 7:31 PM
    ryfox0276
    Montana
    2013 RC 4x4
    Idk if anyone sells a bolt on kit, but yeah these engines take boost very well.
  5. May 24, 2020 at 7:33 PM
    ryfox0276
    Montana
    2013 RC 4x4
  6. May 24, 2020 at 7:58 PM
    elrobbygtaco
    Robby
    Thanks!
    Super helpful I almost gave up looking into a turbo. Much more affordable
    ryfox0276 likes this.
  7. May 24, 2020 at 7:59 PM
    BuzzardsGottaEat
    BuzzardsGottaEat Well-Known Member
    Some Toyotas
    Round tires
    LCE Engineering header and a tune up. Don't get a CAI... they're mostly actually hot air intakes and will decrease your power. You can open it up intake and out, but the header will be the biggest and probably only notable gain/difference.
    mabepossibly and EdgemanVA like this.
  8. May 24, 2020 at 8:07 PM
    LoveableWerewolf
    LoveableWerewolf Well-Known Member
    Nashville
    2014 5 lug, 1989 mighty max
    4 runner seats, storage cubbies
    The URD supercharger kit is supposedly the best, however 4.5k is a bit steep. There is a coupon for tacomaworld members though. "ForumMember" I believe. It's about 235$ off
  9. May 24, 2020 at 8:42 PM
    elrobbygtaco
    Robby
    Thanks for the coupon! I have only heard good things about URD
  10. May 24, 2020 at 8:45 PM
    LoveableWerewolf
    Nashville
    Don't thank me til you check that the code still works:fingerscrossed: also if you call them, I've heard they are great service and may also give you a discount if you ask. Just a guess though.
  11. May 24, 2020 at 8:47 PM
    elrobbygtaco
    Robby
    Any Idea the horse power increase with urd super charger
  12. May 24, 2020 at 8:53 PM
    LoveableWerewolf
    Nashville
    Ozzie's taco on YouTube is a good resource. I think he said 230 ish wheel with a stage 1 pully? The urd says 250 with a stage 2 pully wheel hp. Considering the stock motor makes 159 crank, that's not half bad.
    I would love to a Dyno sheet of a stock 2.7 that would be hilarious
  13. May 24, 2020 at 8:56 PM
    LoveableWerewolf
    Nashville
    Oh, and ov tune is hopefully coming out with something for the 2nd gens, and maybe 3rd gen 2.7? Not sure though, it's buried in some ov tune thread.
  14. May 24, 2020 at 11:53 PM
    WillyTtaco
    WillyTtaco Well-Known Member
    Bill
    So Cal
    2014 DCSB TRD OFFROAD 4X4
    265/75/16 AT2 BILSTEIN,SNUGTOP MBRP,SPC UCA
    I had an air intake on my ‘99 4 banger Tacoma before my ‘14. It did add noticeable HP and loved the sound. I changed it out for stock every time I got a smog test and I could definitely feel a change in power. Just my experience !
  15. May 25, 2020 at 7:07 AM
    LoveableWerewolf
    Nashville
    The 2nd gen 2.7 had a giant airbox that goes into the outside fender, I believe that counts as a cold air intake. I've heard, not from experience, that the 2nd gen doesn't benefit from a relocated airbox as much as other vehicles. Urd kit is compatible with stock airbox, and Ozzie's Tacoma on youtube uses it. Remember it's up to you if you want to try.
    elrobbygtaco[OP] likes this.
  16. May 25, 2020 at 7:14 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    The stock intake will definitely flow cooler air, but an aftermarket one will flow more air. I ran an aftermarket aFe for a while when i was n/a still and it make a good difference in usable power. LCE header is also a nice upgrade
    Here's a link with a few things ive put together. I am running the URD kit and it's the best thing ive done to the truck so far for performance.
    https://www.tacomaworld.com/threads/2tr-fe-performance-thread.636292/
    Bgonzblacktaco27 likes this.
  17. May 25, 2020 at 7:17 AM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    I believe the @OVTune self user tunable files are available. That requires contacting them though for specifics. Definitely worthy for improving the tuning over stock and for aftermarket upgrades.
    Whether turbo or s/c.
    BassAckwards likes this.
  18. May 26, 2020 at 8:16 AM
    Gandalf
    Gandalf Member
    Rich
    2014 AC TRD offroad
    Arb bumper, OME 886/dakars 265/75r16 ko2s
    Regear. I just went from stock 3.73 to 4.56 in my 4.0 6m with 34x10.5r17s and the difference in acceleration is dramatically improved. I feel silly i didn't do it years ago.
  19. May 26, 2020 at 9:07 AM
    EdgemanVA
    EdgemanVA Well-Known Member
    Virginia Beach
    2008 X-Runner
    Several
    LS3 Swap?
  20. May 26, 2020 at 10:21 AM
    shaeff
    shaeff Roaming Around
    Hudson Valley, NY
    '07 DCSB SR5 6MT 4x4
    If you've got a 4 banger, turbo all the way. I almost wish my pickup was a 4 cylinder for this reason alone.
