What are 12.9 fasters used for?
Discussion in 'Off-Topic Discussion' started by soggyBottom, Dec 4, 2020.
  1. Dec 4, 2020 at 7:56 PM
    soggyBottom
    soggyBottom [OP] Well-Known Member
    What type of applications call for grade 12.9 fasters? Please give specific answers if you have them.
    :::Edit:::
    Not strictly asking about Tacomas, or even automotive.
  2. Dec 4, 2020 at 7:57 PM
    Drainbung
    Drainbung Somedays you are the show....
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Grade/Class Strength
    Metric Class 8.8 Similar to Grade 5.
    Metric Class 10.9 Similar to Grade 8.
    Metric Class 12.9 The highest metric class for strength, it exceeds Grade 8.
    SR-71A likes this.
  3. Dec 4, 2020 at 8:27 PM
    soggyBottom
    Yes but what are the applications?
  4. Dec 4, 2020 at 8:37 PM
    Drainbung
    Bob
    Fallabama, NV
    10 DCLB
    TRD Fleshlight
    Sorry, I misread your question. I'm not an engineer so I cannot answer.
  5. Dec 4, 2020 at 8:53 PM
    kbp810
    kbp810 Well-Known Member
    Au Gres, MI
    2016 Tacoma TRD OR
    I don’t think there’s anything on a taco that would benefit from a 12.9... except maybe perhaps shock bolts, as it would perhaps have more abrasion/wear resistance, and bolt is short enough that the brittleness of a harder bolt shouldn’t be a factor. For other suspension components, a bolt with a little more “stretch” to it for clamping force or give is ideal (class 8.8). Same with aftermarket bumpers and recovery points as well, considering they could be subjected to heavy shock loads during a recovery.
    In other words, I guess I’m also not sure what the ideal applications for a 12.9 are?
  6. Dec 5, 2020 at 2:54 AM
    soggyBottom
    I suspect there isn't anything on the tacoma that calls for 12.9 but what about other things?
  7. Dec 5, 2020 at 6:03 AM
    My Name is Rahl
    Head bolts are typically a 12.9/G9.
  8. Dec 5, 2020 at 7:51 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Probably used a lot in aircraft applications i imagine.
    I think the leaf spring bolts are stronger than grade 8. Same with the big bolts at the lower knuckle in the front. The ball-joint stud material has that darker look that sets it apart from grade 8
    My Name is Rahl likes this.
  9. Dec 5, 2020 at 7:57 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    If there is a demand They will be made and sold.
    Sometimes the only reason they are used is the salesperson talked the customer into buying them
    They were the only size bolts in the bin that would work the right length or right diameter
    weefek likes this.
  10. Dec 5, 2020 at 7:59 AM
    My Name is Rahl
    Darker look? That's not how you identify a 12.9 grade hex cap screw. The grade is always stamped on the head, whether SAE or Metric.
    b_r_o[QUOTED] and SR-71A like this.
  11. Dec 5, 2020 at 8:00 AM
    SR-71A
    SR-71A Define "Well-Known Member"
    Zack
    Southern Maine
    2012 DCSB, TX Baja Edition. Barcelona Red
    255/85/R16 Falken Wildpeak MTs, Mobtown sliders, ARB bar, SOS front skid, Icon RXT leafs, extended & adjustable Kings, JBA UCAs, OVS wedge RTT, dual AGM batteries, Gen2 xrc9.5 winch, CB, GMRS, S1 ditch lights...
    Higher grade bolt means moar ugga duggas..
    Actually refers to the tensile strength of the steel the bolt is made out of. Higher grade = higher tensile strength = more axial load (tension) that the bolt support
  12. Dec 5, 2020 at 8:02 AM
    jake72
    jake72 Well-Known Member
    Jake
    N.E. PA
    2019 trd off-road dcsb mt
    Bed bolts could be that strong
  13. Dec 5, 2020 at 8:03 AM
    My Name is Rahl
    You're right.
  14. Dec 5, 2020 at 8:06 AM
    My Name is Rahl
    No, 12.9 grade bolts do have industrial applications. 8.8 and 10.9 are more common grades in bolt bins.
  15. Dec 5, 2020 at 10:24 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Im aware of the stamp on the head.
    Also notice i used words like probably and I think :thumbsup:
    I handle a lot of bolts on cars on a daily basis. Not all bolts have a designation stamped on the head. The ones that come already installed on cars don't always have a stamp. Alot of torx and hex fasteners dont have any room on the head for a stamp.
    When you buy a nut/bolt selection from a parts store, those will often be stamped
    Generally speaking darker fasteners will be found on suspension applications where tensile strength is needed. At a glance they look different than the bright shiny grade 8s that are found elsewhere
  16. Dec 5, 2020 at 10:36 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    10.9 and 12.9 bolts can suffer from a somewhat unique failure mode called "Hydrogen Embrittlement" Most common in poorly coated (electropated) high grade fasteners.
    -molecular structure related failures due to crystalline metal. Fascinating stuff for material science geeks.
    I've heard that 12.9 suspension bolts that are over-torqued (typically with a shop monkey and an impact gun) will cause these fasteners to break very quickly.
    https://www.boltscience.com/pages/t...is-not-necessarily-the-case-for-fasteners.pdf
    3JOH22A and kbp810 like this.
  17. Dec 5, 2020 at 10:44 AM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    3G Tacoma on 35"s, 5G 4Runner
    Connecting rod bolts, head bolts, brake caliper assembly bolts... basically allows the designer to use a smaller bolt for any given load, with all the caveats mentioned above (needs precision torquing or better yet a stretch gauge, increased likelihood of hydrogen embrittlement and/or stress corrosion cracking).
    Me? I use either Toyota OEM bolts or stainless bolts from the hardware store - not as strong as SAE grade 8 or metric 10.9 when new, but will be stronger after a couple of salty winters...
    Drainbung likes this.
  18. Dec 5, 2020 at 10:47 AM
    svdude
    svdude Well-Known Member
    jonathan
    I don’t think I’ve ever seen a 12.9 bolt used on small aircraft. However, I worked on chinooks for a while and even though they’re an SAE, I think there’s some bolts that may be similar grade to 12.9 for transmission mounts.
    As for a more consistent application, maybe big rigs, tractors, etc. large machinery would be my guess for a normal usage of them.
  19. Dec 6, 2020 at 6:36 PM
    3JOH22A
    3JOH22A トヨタ純正男娼
    District 6ix
    Want to see really high-end fasteners in automotive use? :devil: https://www.summitracing.com/parts/arp-247-4205
    They're expensive because the material is inconel 625.
  20. Dec 6, 2020 at 7:03 PM
    Knute
    Knute Well-Known Member
    '06 4.0L Tacoma TRD Sport
    Stock, 4WD, Access Cab, White,
    SAE fasteners (bolts in this case) will have radial marks on the head to indicate Grade. 3 marks (spaced at 120 degree) indicate a Grade 5 bolts. 5 marks (spaced at 72 degrees) indicate Grade 8. No marks indicate Grade 2, IMHO these are best left in the bin.
    Metrics are marked with the Grade number. 8.8, 10.9, 12.9
    The Grade indicates the strength of the bolt. The high strength bolts require heat treatment to build the Carbon/steel structure.
    Torx and Socket heads are typically at a Grade 5 strength.
    The "black" treatment can come from several sources. Black Oxide, Heat treatment, anti-rust....... the color is not a reliable indicator of the bolt strength.
    Yes, Hydrogen embrittlement can be an issue. The H2 invades the carbon/iron matrix to begin fractures.
    FWIW, all metal is a crystalline structure.
