What Anytime locker is the best?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by AlexM06, Oct 25, 2024.
  1. Oct 25, 2024 at 11:57 PM
    AlexM06
    AlexM06 [OP] Member
    Alex
    2020 Toyota Tacoma TRD-off road 4x4
    I’m looking into the anytime locker since my old t100 I swapped a mechanical lsd on the back and absolutely loved it but the new tacomas are only in 4 low and it’s a bit of a let down with that, anyway I wanted to know if any of you guys have installed them and which ones you think are the best overall. Thanks!
  2. Oct 26, 2024 at 4:50 AM
    devinzz1
    devinzz1 Well-Known Member
    devin
    lewisporte Newfoundland
    2023 aclb trd or mt
    icon stage 10 kit, toytec 1" bl, 35" general x3s, 17x9.5 procomp wheels, locker anytime mod, s&b intake, blackhawk 2.1 tune,
    experimental designs kit is cleanest install imo being able to retain the factory locker switch
  3. Oct 26, 2024 at 5:40 PM
    AlexM06
    AlexM06 [OP] Member
    Alex
    Ask does this one lock thru the factory button? I’ve seen the other ones where you have a separate button for it.
  4. Oct 26, 2024 at 6:51 PM
    devinzz1
    devin
    2023 aclb trd or mt
    yes. factory switch. with both kits you lose the dash light. experimental gives you a little blue led indicator in its place. in installed in a blank switch spot
    AlexM06[QUOTED][OP] likes this.
  5. Oct 26, 2024 at 10:06 PM
    mgregg85
    mgregg85 Member
    Michigan
    23 OR DCSB MT 4x4
    Winch, bumper, pro grille, lift kit soon
    IMG_1804.jpg I went with the experimental designs option, it works well. It was nice to be able to use the locker in 4hi on the sand dunes.
    I put my indicator light next to my switch panel in the sunglasses holder.
    AlexM06[OP] likes this.
  6. Oct 26, 2024 at 11:48 PM
    AlexM06
    AlexM06 [OP] Member
    Alex
    Is the wire that connects to the light long enough or do I need to extend the wire to have it be able to connect in the roof consel?
  7. Oct 27, 2024 at 8:58 AM
    helix66
    helix66 Well-Known Member
    DPRC
    2017 DclB TRDor MgM
    ProGrille,MesoStuff,Tinted,AllPro sliders, RCI ALL skids, BAMF diff skid, KDmaxPro tune, Demello bumper, Warn evo10s, BD s8 & squadrons, Accutune UCAs, Fox 2.5pes, Eibach & Deaver
    I’ll probably go with this brand to but mount the indicator in the lower switch panel….it looks like it can be removed from that switch plate.
    Same question on the indicator light….long leads or splice?
  8. Oct 27, 2024 at 7:01 PM
    mgregg85
    mgregg85 Member
    Michigan
    23 OR DCSB MT 4x4
    It was long enough to go from behind the glovebox, through the column, and to the sunglasses holder.
  9. Oct 28, 2024 at 6:59 AM
    devinzz1
    devin
    2023 aclb trd or mt
    theres was enough wire to go from the module behind glovebox to where i have mine on the switch blank by steering wheel.
