What amount of air pressure to run in bigger tires?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by SCLOSKEY, Dec 18, 2010.
  1. Dec 18, 2010 at 3:30 PM
    SCLOSKEY
    SCLOSKEY [OP] Well-Known Member
    shane
    PA
    V6 SR5 TRD
    Hey guys, just got a set of 285/70/17s - Hankook Dynapros. The max is can put in is 80 pounds of pressure, but I can't seem to find what the appropriate amount to run in them is ? What are you guys running in your 285/70/17s?
  2. Dec 18, 2010 at 3:32 PM
    cameronlane
    cameronlane Well-Known Member
    cameron
    Anywhere but there
    2014 Dbl Cab TRD OR 4x4
    im running 35 in mine toyo open country
  3. Dec 18, 2010 at 3:40 PM
    OZ-T
    OZ-T You chose ... poorly
    Peter North
    British Columbia
    Off topic , but did you get the AT or MT Dynapros ?
  4. Dec 18, 2010 at 3:47 PM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Chalk line test- Draw a line across the whole tread and drive a little- See how the chalk wears off. If it's even- That's the perfect pressure for tire wear. If the outsides wear more than the center- Too low-add air. Inside wears off and outsides stay- Too much air- let some out.
    Once you know that "perfect" pressure-You can add air to improve mpgs (to a point) at the cost of a stiffer ride. Less air will give you a softer ride. So it's kind of your call from there.
  5. Dec 18, 2010 at 4:35 PM
    SCLOSKEY
    shane
    PA
    V6 SR5 TRD
    I got the AT's
  6. Dec 18, 2010 at 4:37 PM
    Tacomanator
    Tacomanator Well-Known Member
    Clam Slammer
    Southern Cali
    King 2.5" extended travel coilovers with compression adjusters, Camburg UCA's, King 2.5" rear shocks, TRD 1st gen CAI.
    what load rating are they?
  7. Dec 18, 2010 at 5:04 PM
    DevL
    DevL Well-Known Member
    Load rating of the tire has nothing to do with how much air you should run in it. Run the factory specs or close to it. The higher load range tires are deigned to be able to air up to a higher pressure IF NEEDED for heavier loads. You wont run loads that heavy so run the correct pressure for your truck... around 30-35 psi. People who do stupid stuff like run 40+ psi are just getting a Fred Flintstone ride for no reason.
  8. Dec 18, 2010 at 7:31 PM
    Gregman
    Gregman Well-Known Member
    Freddy Beach, NB
    05 DC LB 4x4 SR5
    Should be a sticker inside the drivers side door pillar that tells you what psi to run, it's mostly based on the gross vehicle weight rating of your truck. Mine says 29 psi front and rear. The tire manufacturer has no idea what you are mounting their tire to, they just put the maximum pressure the tires are capeable of on the sidewall. Running them way over inflated makes them wear out in the centre as everyone has already said. Start with what is written on the sticker on your truck then do the chalk test to make sure you've got it right, it will likely be a slightly different pressure depending on what type of tire you've got and what size you've got. I run the same pressure in my 265/75R16 as I did in my 245/76R16. Currently I am running 32psi front and 30psi rear.
  9. Dec 18, 2010 at 8:38 PM
    bjmoose
    bjmoose Bullwinkle J. Moose
    San Jose CA
    '11 Std Cab 4x4 5sp
    It's not NO reason. They're also prematurely wearing down the center of the tires. :p
  10. Dec 19, 2010 at 12:58 AM
    scott572011
    scott572011 Well-Known Member
    SCOTT
    SO-CAL.
    THE RELENTLESS PRUIST....
    BF GOODRICH T/A ko, BILSTEIN HDs, AMERICAN RACING RAZOR`S 16X7.5, READYLIFT SST HYBRID LIFT SYSTEMS, ALTEC LANSING AUDIO,DREGS OF THE EARTH SYSTEMS,WOLF EYES,SUREFIRE ILLUMINATION TOOLS,HK-PROTECTION!!. POP LOCK, SHORTY ANTENNA, TACO TENT #3,. NITECORE ILLUMINATION, FENIX FLASHLITES. STILL PROTECTOR`S, FACTORY BED MAT, CUSTOM BED WEB, INTRO-TECH INTRO-GUARD CUSTOM TRUCK COVER, CENTER CONSOLE LOCK MOD, TECH-SHADE M1068, WEATHER-TECH CLEAR-COVER`S, OEM MINI TIE-DOWNS, TRUCK BEDZ AIR MATTRESS EXPEDITION SERIES, McGARD TOUGH NUTS WHEEL LOCK`S, DISABLE SEAT/BELT CHIME MOD, GARMIN GPS, KERSHAW BLADE`S, SKELETOOL, WEATHER-TECH FLOORLINER DIGITAL-FIT GRAY # 461781, NITE(IZE) KNOT-BONE ADJUSTABLE BUNGEE SYSTEM, WET OKole SEAT COVERS, UNDER DASH FLYZEYE BW LED LIGHT W/CUSTOM BLUE HALOS. NITECORE IFE1 INFILUX ILLUMINATION SYSTEM. JETBEAM BC-10 HANDHELD, HK VP-70Z 9mm PROTECTION!. JETBEAM PC-10 550 LUMEN ILLUMINATION SYSTEM. SUREFIRE E2D-LED-DEFENDER ULTRA 500 LUMENS KICK ASS ILLUMINATION...VIPER ALARM SYSTEM`S,ROCKFORD FOSGATE POWER COMPONENT SYSTEM`S.KENWOOD AUDIO/VIDEO,HUSHMAT SOUND DEADENING INSULATION,3M AUTOMOTIVE FILMS.
    2010 ass cab stock wheels called 4- 30psi front 33psi rear. peanut wheels!!. 245/75r16nz. i run 35 psi all round seems to be work`n fine.
  11. Dec 19, 2010 at 5:56 AM
    RainDodger
    RainDodger YGWYPF
    Great Northwest
    '09 Black, TRD Sport
    None yet! It's new!
    Call the Tire Rack. Ask to talk to their tire pressure expert guy. After you tell him exactly what vehicle you have and your tire sizes, he will calculate for you, what pressures you should be running, based on vehicle weight and internal volume of your new tires. Worked for me.
  12. Dec 19, 2010 at 8:15 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    When you say "worked"- Did you compare to something else or are you just going off the "I'm happy with how it rides and the tires wear looks decent" method??
    To the folks above talking about the door plate-That really only applies with the OEM size tires from the same manufacturer. And even then it can vary a few PSI based on compound composition, time of year, and individual truck options packages/extra gear.
  13. Dec 19, 2010 at 8:46 AM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    Good info. Thanks. You a mechanic or just know what U R doing ?
  14. Dec 19, 2010 at 10:20 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Not a mech...and even saying I know what I'm doing is a stretch. I just have learned a few tricks from some smart dudes and realize that they work.
  15. Dec 19, 2010 at 10:29 AM
    bajaracer
    bajaracer Well-Known Member
    Charly
    Chandler
    05 PRERUNNER DBLCAB SPORT 4.0
    AEM DRY BRUTE FORCE, FLOWMASTER 50 SERIES, 285/70/17 BFG'S AT KO2'S MOTO METALS 17X8 885's with 5100's LOUD STEREO
    im running 285/70/17's BFG's ATand the mechanics at Discount tires told me to keep it at 50 psi for maximum tread life.... not sure becuase ive always had my previous Toyo's AT tires at 33 psi and lasted long time
  16. Dec 19, 2010 at 10:41 AM
    billas333
    billas333 They Still Love To Hate Me! - T.O.
    Joel
    NorCal
    2008 4x4 Tacoma Sport
    Mods so far: Tube steps from toyota, Bed extender from toyota, Spare Tire lock, Sound System Makeover, Tacoma All-Weather heavy duty rubber floor mats. Rear TSB, Icon Coilovers w/ TC UCA's and 3inch rear block with rear 5100 bilstein shocks, Black Headlights, Grillcraft black grill, Devil Horns from Andres, Black Headlights, Chrome Liquid Metal Gatlins Wheels, 285/70R17 Nitto Tera Grapplers, Wet Okole Seat Covers! Seat Belt Chime Mod, Flowmaster 50 series dual exhaust, Debadged tailgate, TRD Decals, HID hi/low + fogs.
    I run 38psi in my 285s.
  17. Dec 19, 2010 at 10:54 AM
    hendooman
    hendooman The Stroker Ace
    Jeff
    KC
    2009 Tacoma OR (SOLD); 2015 TRD PRO 4Runner
    Toytec TRD PRO LIFT with 1.5 SAW in rear, 255 Coopers, Baja Rack, Southern Style Front Bumper, Warn Wireless Winch, DeMello Sliders.
    Wow 50? Did you take his advice? I would do a chalk test 50 sounds like a lot. 33 sounds better to me
  18. Dec 19, 2010 at 12:06 PM
    george3
    New Jersey
    Well, thanks for passing them on !
  19. Dec 19, 2010 at 4:32 PM
    skistoy
    skistoy Make mine a Double!
    Western New York
    09 4X4 SR5 BSP Double Taco
    Rear Spring TSB,Billy 5100@.85,Bull bar,Nerfbar,Painted Grill,Painted Rims,Bed D-rings,Compustar Starter,Goodyear Duratrac's,Transmission TSB,Brake Overide
    just for example:
    I have goodyear Duratrac's 265/75R16, larger than the 245's that came with the truck.
    Did the chalk like test, as i do with all my tires
    Found the best pressure for MY TRUCK, with MY TIRES
    to be 36 p.s.i. up front, 24 p.s.i. in the rear.
    I believe the 24 p.s.i. is because the back end is so light, carbon fiber bed and all.
    have been running this for a couple years now, summer, winter, year round.
    Have had no problems, runs great at highway speeds, haven't got stuck in snow yet.
