What 4wd mode should I be In for snow?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by pahaf, Jan 20, 2023.
  1. Jan 20, 2023 at 7:22 PM
    pahaf
    pahaf [OP] Well-Known Member
    paul
    NorCal
    2015 Tacoma TRD Off Road
    Bilstein 6112/5160 OME Meduim leaf pack JBA HD UCA 3* retard exhaust gear TRD Pro Sema rims 265/70R17 Falken Wildpeak AT3W
    Hey guys. Got a 2015 Tacoma 4x4 off road. Go to snow here and there. Usually if there is snow on the road, I’ll be in 4hi.
    but what about the areas where it’s snow——no snow——snow——no snow?
    do you guys just keep it in 4x4 or switch back and forth?
    as I understand, our trucks have a center diff, or transfer case that sends power 50-50 locked. So can’t drive with it on a dry surface when it’s dry. I don’t want to put extra stress on the drivetrain.
    what are you guys doing? Is it ok to leave it in 4x4?
    pictures from my recent trip where snow was off and on.
    MGMDesertTaco and TXpro4X4 like this.
  2. Jan 20, 2023 at 7:30 PM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    If its the corners you're worried about, highways are usually straight enough to where it's not a big concern
    Nefarious and ImMrCrash like this.
  3. Jan 20, 2023 at 7:37 PM
    GilbertOz
    GilbertOz Driver
    CA
    2014 AC V6 MT 4WD, 80K miles
    FOX 2.5, Deavers, ARB, 4xInnovations
    If I was driving that I would be switching back & forth between 2HI and 4HI, on the fly, as needed. Assuming your truck is in normal working order, this should be fine at any speed up to 60MPH. Best to do the transitions when the truck is travelling straight, not around curves.
    In my experience, the truck can tolerate small accumulations of drive-line bind-up caused by differing wheel speeds around turns, on non-slipping surfaces (i.e. dry, or even wet/rainy, pavement) -- but only small accumulations.
    The key is not how far you travel in 4HI on dry pavement -- essentially any distance in a straight line is fine. It's the turns. If I am in 4HI during heavy rains on asphalt roadways, I will switch out of 4HI and back to 2HI after completeing no more than a few -- maybe 2 or 3 -- major curves in the road.
    I can drive for miles in a straight line at highway speeds, in 4HI, and barely perceive any sound or sensation when switching back to 2HI. But after just a few curves at the same speeds in 4HI, there is a distinct "clunk" and shudder when switching back to 2HI. The clunk/shudder is driveline windup / tension being released.
    I'm very cautious & attentive when using 4HI this way. I would not want to find out what the upper limits of driveline windup are when travelling at highway speeds. Seems like it'd be possible end up in a situation where extreme windup makes it impossible to switch out of 4HI.
    Here are some further thoughts I've shared about driving in 4HI on dry pavement.
  4. Jan 20, 2023 at 7:41 PM
    Bishop84
    Bishop84 Well-Known Member
    4HI both photos. It is intended for low traction. Use it for stability and be safe.
    I dial it off when the pavement is dry, but wet and Icey means twitchy rear end. Especially with non-winters.
    The biggest wear point is the front u joints, they are the weak point, and they are 40$ each. The tcase and diff can handle it. It's a Toyota.
  5. Jan 20, 2023 at 7:41 PM
    Dbarffish
    Dbarffish Well-Known Member
    Doug
    Montana
    2024 dcsb TRDOR blue crush
    Stock
    I do sometimes shift in and out. BUT often the change can come fast and sometimes I’m above 60. I think you are fine leaving it in 4hi. There is a lot of stress out on these systems when people are rock crawling and the trucks handle it. Just minimize it as you can and don’t sweat it too much
    pahaf[QUOTED][OP] likes this.
  6. Jan 20, 2023 at 7:50 PM
    TXpro4X4
    TXpro4X4 Fuck Cancer!
    Bryan
    Costa Mesa, CA
    2011 TOY
    In pics posted, leave it on.
    Lol, it's friday
  7. Jan 20, 2023 at 10:11 PM
    TacoTuesday1
    FL
    if its "snow, no snow" then it's probably not slippery enough to desperately need 4x4 in the first place
    Nefarious, Bivouac and pahaf[OP] like this.
  8. Jan 20, 2023 at 10:20 PM
    libagui
    libagui Well-Known Member
    Dominican Republic
    05 tacoma prerunner
    Bilsteins 5100 set at .085 Rear custom 1" add a leaf 265/70 R17 tires. Custom made aluminum tonneau cover with bike rack. 4x4 conversion with 4Runner transfer case.
    That is why I used a 4runner transfer case on my 4X4 conversion. You can select lock or unlock mode.
  9. Jan 21, 2023 at 12:07 AM
    muddog321
    muddog321 Well-Known Member
    FL
    09 Tacoma DCSB 4wd TRD Off-Road w/e-locker Pyrite Mica
    TW 1-piece driveshaft with 1310 u-joints All Pro and Budbuilt skid plates OME Dakar rear springs 3" with 5100 5100 front set at 1.75" (3rd groove up) with stock springs Falken Wildpeak A/T3W 265/70R16 2018 TRD Offroad wheels 16x7J with +25mm offset Powerstop rotors with Z36 pads and rebuilt with OEM caliper kit Complete rebuilt rear brakes drums, shoes, springs, wheel cylinders Rebuilt rear diff with Yukon 3.73 ring/pinion Denso 130A rebuilt alternator AGM 24F Battery New OEM idlers and tensioner assembly New AC compressor New PS hose and flushed Walker SS Quiet Flow muffler Denso Iridium long life plugs #3421 (SK20HR11) OEM coolant, cap, and thermostat NAPA CV axles and new seals ECGS bushing Rhino front guard Shortened mud flaps Alziria Black Tail Lights Nilight Headlights X-Bull Traction Boards Maaco full single stage paint job 2023 Nat CV to Knuckle seals 710573 New SKF wheel bearings/hubs BR930978 New Moog stabilizer links K80946 & 948 New MOOG K80819 Suspension Stabilizer Bar Bushing 28mm New Dorman rear wheel bearings using complete axles 926-139 & 140 New Radiator support bushings Dorman 924-267 (front body mounts)
    Just wanted to say:
    No center diff in Tacomas as that would allow different speeds on wheels or as some call "auto" or "autotrac" for all pavements.
    This is one area where Toyota has been lacking.
    Ricardo13x and Raylo like this.
  10. Jan 21, 2023 at 12:16 AM
    dfanonymous
    dfanonymous Well-Known Member
    2019 Voodoo Blue Tacoma TRD Pro.
    -Shmellfab rocksliders.... -BD ditch lights -Cali raised ditch light brackets -Sway bar discos -Auxbeam aux 6 gang -Uptop Bravo -Rci trans skid -Rci cat guards -Trd pro eibach lift springs -Hypertech speedo calibrator Etc.
    Mountain highways are anything but straight…or flat.
    Pretty sure the landcruiser used an actual center diff back when suvs didn’t have air bags.
    It’s lacking because they don’t really make any other awd with low range 4x4s
  11. Jan 21, 2023 at 12:20 AM
    TacoMoose
    TacoMoose Well-Known Member
    2017 Tacoma OR
    Really depends on your level of experience driving in such conditions and how well you know your vehicle. In those two pictures you posted, I would feel more then confident driving in 2wd
  12. Jan 21, 2023 at 4:00 AM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I use 4X4 as needed. Over half of the vehicles on the road don't even have 4X4 and they are getting along just fine. If you need help getting moving, especially on an incline, it only takes a second to flip the switch. Once on level ground 4X4 isn't helping that much. The bigger problem is stopping and 4X4 doesn't help that at all.
    If the snow is 4-6" or deeper everywhere then leaving it in 4X4 all the time won't hurt and if you feel better then leave it in 4X4 all the time. With light or patchy snow I don't do that. I flip back and forth as needed. If you choose to just leave it in 4X4 on surfaces where there is no snow you probably won't break anything, for now. But you are over stressing components that will eventually fail sooner than they should.
    BC Hunter and pahaf[OP] like this.
  13. Jan 21, 2023 at 8:35 AM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I switch in and out of 4WD, but am not too worried if I hit a little wet pavement before I do.
  14. Jan 21, 2023 at 9:34 AM
    ShimStack
    ShimStack Well-Known Member
    Ben
    NC
    '91 Truggy, '98 Project, '16 DC OR M/T Locked F/R
    I'll correct this (again) only because it's so widely misunderstood. You have a traditional part-time transfer case with no center diff. A center diff is an add-on to a traditional transfer case. A traditional transfer case is functionally the same as a locked diff but it simply mates the two outputs together through a direct drive using a chain or gear set.
    In this configuration the transfer case does NOT send power 50/50, nor does it send torque 50/50. What it does do is send equal speeds F/R and biases torque output F/R from 0/100 to 100/0 and anywhere inbetween. The power output is just the torque each axle receives multiplied by the rotational velocity (speed).
    On snow or partial snow roads leaving it in 4HI is fine. You will know when it binds as you can feel it. Bind increases with tighter turns at slower speeds and as traction levels go up. Pay attention, turn off 4HI when on higher traction surfaces turning tightly and you'll be fine.
    Ricardo13x and wi_taco like this.
  15. Jan 21, 2023 at 10:27 AM
    nd4spdbh
    nd4spdbh Well-Known Member
    SoCal
    13 DCSB TRD OR v6 Auto
    4wd isnt going to help in any of those situations unless its steep enough to need the extra traction to keep you moving forward.
    due to the lack of a center diff you could actually start pushing in corners. Id personally be in 2hi till its needed to get me moving forward.
    Ricardo13x likes this.
  16. Jan 21, 2023 at 11:07 AM
    Bishop84
    The problem is if the rear loses traction it spins rapidly at a different speed than the front and you are more likely to spin out. This is the most common thing to happen at highway speeds in trucks on ice.
    If you lock front and rear it won’t induce understeer on low traction. I have no idea why so many people on here think 4x4 is crazy to use at highway speeds on low traction.
  17. Jan 21, 2023 at 11:13 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Seriously, that how guys end up in the ditch
    Unless you've got hundreds of lbs of sand in the bed and sticky snow tires, lock that shit in and forget about it. If it's binding you'll feel it, cycle it off and back on, keep driving
    racerX969, BC Hunter and ShimStack like this.
  18. Jan 21, 2023 at 11:43 AM
    ssd2k2
    ssd2k2 Well-Known Member
    Keith
    Minnesota
    2019 Tacoma TRD Sport M/T
    As someone from the north who drives in the snow a lot, my technique for when to use 4x4 is any time there is snow covering the pavement or the instant the truck squirms around on the road turn 4hi on and leave it on.
    The problem with turning it off and on is when you need it you need odds are you need it faster than you can switch it back on.
    I have done thousands of miles driving in snow/icy conditions leaving 4hi on all the time and never had anything break.
    Doing normal right or left hand turns onto different roads has never given me any binding issues. The only time I have ever experienced binding problems is when doing a full lock turn, usually when pulling into a parking spot.
  19. Jan 21, 2023 at 11:48 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Put it in 4wd
    It's not complicated, it's not going to hurt anything.
  20. Jan 21, 2023 at 11:57 AM
    stickyTaco
    stickyTaco Fuck Cancer
    Zack
    Reno/Tahoe
    '12 DCSB TRD-OR
    Fox/Dakar with Relentless goodies and stuff
    It's really about comfort levels but, as others have said, I'd leave it in 2wd in those conditions (with traction control turned off). My snow driving is rarely straight flat roads but I understand steering into a slide, have tires with the M&S snowflake rating and replace them every 4 years (well before I hit the wear bars), and a good amount of weight in the back (2 spares, a HC rear bumper, skids, sliders, a GFC, a fridge & recovery gear).
    Unless I cannot keep forward momentum or I'm constantly having to counter-steer, I prefer to keep it in 2wd as I'm more in tuned with the available traction. The pic below is at the top of the mountain after climbing from 4k ft to 8k ft in the snow using just 2wd. It's also worth noting that you'll have a much easier time correcting a slide at 50mph that at 65 or 70mph.
    BC Hunter likes this.
