What’s the “best” Onboard Air Compressor
Discussion in '3rd Gen. Tacomas (2016-2023)' started by doc76, Apr 11, 2021.
  1. Apr 11, 2021 at 1:58 PM
    doc76
    doc76 [OP] Well-Known Member
    B.C. Canada
    2021 Tacoma Sport, 2020 Honda Pilot Black Edition
    Hey there
    Looking for input into brands of onboard air compressors.
    Looking to be able to air up tires, if needed, and my Firestone air bags as well.
    Seen a few guys mount them everywhere but I like the mounting in the rear right storage bin in the box by the inverter the most.
    I know nothing of the brands and reliability and that’s what I am after.
    Any inputs?
  2. Apr 11, 2021 at 2:04 PM
    tcjacado
    tcjacado Well-Known Member
    Arb single or twin
    Or viair are the 2 most popular.
    Skydvrr, JDKred, waltuo and 1 other person like this.
  3. Apr 11, 2021 at 2:10 PM
    doc76
    B.C. Canada
  4. Apr 11, 2021 at 2:15 PM
    tcjacado
    Skydvrr and doc76[QUOTED][OP] like this.
  5. Apr 11, 2021 at 2:21 PM
    Cudgel
    Cudgel “Tonka”
    Live in: An Ocean of Plastic Trash
    2017 OR DCLB
    ICON8 Lift -285s. upTOPoverland rack.
  6. Apr 11, 2021 at 2:25 PM
    doc76
    B.C. Canada
  7. Apr 11, 2021 at 2:30 PM
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    tcjacado and doc76[QUOTED][OP] like this.
  8. Apr 11, 2021 at 2:31 PM
    doc76
    B.C. Canada
  9. Apr 11, 2021 at 2:33 PM
    Thunder Fist
    Thunder Fist Well-Known Member
    David
    Birmingham, AL
    2017 MGM TRD OR DCSB
    Like, so many.
    Don’t they need to be run from the battery?
  10. Apr 11, 2021 at 2:34 PM
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
    Yes:
    1. Close to battery.
    2. Save and secure.
    3. Convenient to use.
    4. Out of the way (it is not a frequent use item for me)
    5. Zero mod install.
    Skydvrr and pltommyo like this.
  11. Apr 11, 2021 at 2:37 PM
    doc76
    B.C. Canada
    I was thinking possibly stealing power from somewhere out back or running power back there but I just looked at that inbox storage compartment and there’s no way that unit is fitting in there.
    Maybe I’ll fabricate an aluminum box on the left where Toyota used to put the larger storage box or just under the hood. I just wasn’t too fond of the access under the hood vs in the box
    Thunder Fist[QUOTED] likes this.
  12. Apr 11, 2021 at 2:37 PM
    Cudgel
    Cudgel “Tonka”
    2017 OR DCLB
  13. Apr 11, 2021 at 2:37 PM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Get the ARB Twin you will not regret it, the extra $ = time saved airing up
    Glueman and doc76[OP] like this.
  14. Apr 11, 2021 at 2:38 PM
    RyanDCLB
    RyanDCLB Well-Known Member
    4/19 DCLBOR
    Do you want to remotely air up the airbags? If so, @spectacolar.adventures did something like that over here
  15. Apr 11, 2021 at 2:38 PM
    doc76
    B.C. Canada
    I have a tonneau so not too concerned on the security but good call on the zero mod for sure.
    I did plan to fab in a storage box on the rear left so maybe I’m just doing it a little sooner than planned
  16. Apr 11, 2021 at 2:39 PM
    maineah
    maineah Well-Known Member
    Tim
    Maine
    4X4 SR5 V6 6spd
    Big compressor CFM low pressure you don't need 100psi in your tires
  17. Apr 11, 2021 at 2:40 PM
    doc76
    B.C. Canada
    Yes I don’t want to have to find air or air up before I pick something up. That’s gonna be a pain in the #ss
  18. Apr 11, 2021 at 2:41 PM
    RickyG1
    RickyG1 Active Member
    2020 Tacoma pro
    My buddy uses desert armor compressor. Works good
  19. Apr 11, 2021 at 2:42 PM
    12taco12
    12taco12 Well-Known Member
    rochester NY
    2012 TX Pro
    Billy 5100s OME 886 Billy remote resi 5125 rear General hd packs TImbren superbumps/flipkit Pelfrey steel full hoop front SOS bolt on sliders Baja squadron amber fogs Baja 20" bar Aux fuse panel and switches custom 10 sub box double din
    Power tank or diy
  20. Apr 11, 2021 at 2:43 PM
    jakethesnake97
    jakethesnake97 Active Member
    Jacob
    Somerset KY
    2012 Reg cab Tacoma base 4x4
    -OME Nitrocharger lift, Dakar leafs -U bolt flip kit with timbren bumps in rear and durobumps in front -9” bobbed bed -3” cut fenders and cab mount relocation -315/75r16 -LCE long tube headers and Magnaflow muffler -URD maf sensor calibrator -fully skidded with RCI off-road steel plates -dobinson snorkel w/K&N drop in and charcoal delete -Demello off-road steel flat top front bumper w/smittybilt 9.5k winch
    I have a single arb compressor in the toolbox of my truck. Been using it for a couple years without issues
