Wet Floorboard passenger side
Discussion in '1st Gen. Tacomas (1995-2004)' started by BrotherJohnny14, Mar 24, 2021.
  1. Mar 24, 2021 at 3:27 PM
    BrotherJohnny14
    BrotherJohnny14 [OP] Well-Known Member
    Johnny
    Virginia
    1995 Tacoma extended cab SR5
    Few months ago I noticed my floorboard was soaking wet so I immediately thought my heater core was leaking since my heat sucked anyway. Got it changed out and then noticed the floor board was still getting a little wet. So then I figured it was a bad door seal because of the way my truck sits on a hill I thought water was leaking in and settling in the passenger floor board. So I turned my truck around to have the passenger side facing down hill to let any potential fluid leak out of it instead of sitting in the floor board. After letting it sit the floor will dry but once I drive it and it sits on level ground the floor board then gets pretty wet again? Does anybody have any clue what the heck is going on? I’m just worried at this point about my floorboard rusting out at some point. It’s been going on for months so idk if it’s rainwater getting in somewhere or maybe the wiper fluid leaking? The radiator fluid is fine and the carpet doesn’t smell sweet at all
  2. Mar 24, 2021 at 4:04 PM
    TWJLee
    TWJLee Well-Known Member
    Jay
    Midwest
    2001 Tacoma 4X4 2.7 5spd access cab 2020 Tundra DC LmTD 2020 F150 5.0
    2020 Tundra GFC 33’s Borla Pro XS FOX 2.0 2020 F150 33’s Magnaflow FOX 2.0 2001 Tacoma 4x4 2.7 5spd access cab new frame 217k 2” lifted Always for sale.
    Big rains recently? The top of the windshield gasket can leak. Check to see it is laying flat
    Is one suggestion
    Sklar likes this.
  3. Mar 24, 2021 at 4:11 PM
    Black DOG Lila
    Black DOG Lila Well-Known Member
    Virginia
    2003 Tacoma SR5 2.7 5 speed 4WD
    Stock. EZ pass.Dump pass.Inspection sticker.Convict printed lic.plates.FG cap.
  4. Mar 24, 2021 at 5:22 PM
    Xperivent
    Xperivent Well-Known Member
    ‘24 Supersonic ORP & '04 Impulse Red DC OR
    Another possibility
    Make sure the A/C evap box drain is properly seated into the gromet & tube that go through the firewall to the drip tube. Passenger side.
    From engine bay you will see a metal tube pointing down to the frame rail.
    Look around there inside.
    If you have A/C of course.
  5. Mar 24, 2021 at 7:48 PM
    Madjik_Man
    Colorado Front Range
    Running the AC or defrost?
    The evap box is along the firewall just above the passenger side foot well.
    It's probably clogged and filled with water... that sloshes out when you're driving.
    Find the drain nipple on the firewall in the engine bay, take a coat hanger or something of the likes, and give it the business.
    This is the drain on the engine side (mine is missing the 90* aluminum elbow):
  6. Mar 28, 2021 at 2:19 PM
    02blancotaco
    02blancotaco Well-Known Member
    Colby
    02 Toyota Tacoma 4x4 Trd
    It may be the seam where the firewall and inner fender meets. Thats a common spot for out trucks to leak.
  7. Mar 28, 2021 at 3:55 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    if it is not the AC drain or the firewall/inner fenders seam, it could be a leaky windshield. The result is water seemingly appearing from nowhere soaking your carpet
    A leaky windshield means that the urethane glue used to glue the windshield to the cab is dried up. The external black molding/seal/gasket (whatever it is called) purpose is to protect the glue seam and cut down windnoise but this one can get dried up or get cracked as well. It cannot be replaced on its own and you have to remove the windshield to replace it
    anyway, here's a quick way to find windshield leaks
    https://www.youtube.com/watch?v=Hd-DFhOAlKk
    Taco2021LB likes this.
