Welding and Electrical Concerns
Discussion in 'Technical Chat' started by Arrowshot, Feb 19, 2017.
  1. Feb 19, 2017 at 12:24 PM
    Arrowshot
    Arrowshot [OP] Well-Known Member
    Alabama
    2014 Tacoma 4X4
    A Crap Load
    Wanted to see if I could get some comments on whether welding can cause electrical issues if you do not disconnect your battery first???
  2. Feb 19, 2017 at 3:56 PM
    jbrnigan
    jbrnigan Well-Known Member
    Midwest
    2015 TRD Sport, 4X4, 4.0L, Auto - Access Cab
    If you do a google search, it is generally recommended that the battery be disconnected before welding. Some even advise disconnecting the ECU.
    Seems like a no brainer - better safe than sorry.
  3. Feb 20, 2017 at 1:41 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    Better safe the sorry always disconnect the negative cable .
    What can happen is you can have welding current flowing all through the vehicles electrical system .
    There are some that will say you will not have any issues.
    Having to buy just one Computer was enough to always remove the negative battery terminal
    I had a friend that was some what lucky in his case if caused every light bulb in the vehicle to just melt the filaments far cheaper then the ECU
  4. Feb 21, 2017 at 8:29 AM
    tgear.shead
    tgear.shead Well-Known Member
    The only way that it can cause any issues, is if you hook up your welder cables incorrectly.
    Electricity follows the path of least resistance. ONLY. It CAN NOT flow through "all of your vehicle's electrical systems" unless you hook the cable up to place all of those systems INTO the circuit you are making with the welder.
    Always do your welding close to the ground clamp, and onto the SAME piece of metal to which the ground clamp is attached.
    cruxofthebisquit likes this.
  5. Feb 21, 2017 at 9:43 AM
    cruxofthebisquit
    cruxofthebisquit Well-Known Member
    Orange Texas
    2000 TRD
    OME and worth every penny.
    Yes, still a good idea to unhook at least the negative also. I'm worlds worst about wanting to do it and having to reset, relearn radios and tunes but it really is a good idea.
  6. Feb 21, 2017 at 12:20 PM
    Wyoming09
    New Tripoli Pa
    Super Springs
    I will call you on the current not being able to flow through the vehicles complete Electrical system .
    If you fail ***to remove the the negative battery cable !!
    Simple to check just see how many places you can measure OCV .
    So just which way should the cables be hooked up ??
    Some use self Shielded wire Last I looked that was straight polarity
    Some Run Hard wire That is Reverse polarity .
    In each case your work cable is different
    So which is correct ??
  7. Feb 21, 2017 at 12:37 PM
    tgear.shead
    That is about as close to indecipherable as anything...
    And also note something about polarity; it is IRRELEVANT unless the vehicle's ELECTRIC system shares a common reference voltage with the electric power grid to which you attach the welder. So thank you very much for giving me the prompt to come up with this meaningful insight!
    In other words, you would have to do something really stupid, like weld on it WHILE YOU HAVE A BATTERY CHARGER HOOKED UP TO THE BATTERY, or a block heater that is plugged in, or something like that.
    If you have a wire feed / mig welder hooked up in REVERSE POLARITY, while the vehicle is connected to a battery charger or plugged into a block heater, then if you so much as TOUCH the ground clamp to the chassis, sparks will fly.
    You can hook the ground clamp of an A/C ARC welder up to the chassis while a battery charger or block heater is connected, but probably not a good idea to actually weld.
    I wonder if that is where the whole "unplug the battery" paranoia originated? Somebody tried welding on a vehicle while it was otherwise plugged into the power grid, and sparks flew?
    If you're welding on a vehicle, the welder cables should be the ONLY connection between the vehicle and the power grid. NOTHING ELSE.
  8. Feb 21, 2017 at 3:18 PM
    cruxofthebisquit
    Orange Texas
    2000 TRD
    He's prob. right. I've never had an issue and remember I'm worlds worst about following my own advise.
