Welder
Discussion in 'Garage / Workshop' started by MitchHamwich, Jul 23, 2021.
  1. Jul 23, 2021 at 12:53 PM
    MitchHamwich
    MitchHamwich [OP] Well-Known Member
    Mitch
    SLC, Utah
    2004 double cab SR5 TRD sport 4x4
    I want a lot of custom stuff on the Tacoma that requires a welder. I have never welded before and know basically nothing about it. Is there a welder that I could buy to learn on that won’t break the bank? Also I don’t know that difference between ark/mig etc. just looking for some advice. Thanks
  2. Jul 23, 2021 at 5:25 PM
    ksJoe
    ksJoe Well-Known Member
    Joe
    Kansas
    2020 TRD Off-Road
    I'm not a pro, but I can throw out some opinions. That way the pros will have to chime in to correct me :)
    A quality arc welder is cheaper than a quality mig welder. But the mig is much easier to use. Especially if you get a real mig welder (with gas) rather than cheap wire welder that doesn't use gas. Instead of gas, you can use flux core wire. Flux core wire is more expensive wire and doesn't weld as nice (more spatter). On steel with C25 gas I often don't bother to put on gloves unless I'm welding something thick.
    I have on formal training on welding, but I grew up arc welding and got decent at it. When I needed to weld some sheet metal I tried my dad's harbor freight flux core wire welder and just made a mess on sheet metal (sheet metal is harder to weld than thicker metal). So I got a factory refurbished Hobart Hander 140, which is about as large as mig welders get that plug into a standard 120v outlet. It worked great for me. As I recall its rated for up to 1/4" steel. If you can live with the power limitations of a 140, I highly recommend it. Find the refurbs if you want to save a few $.
    If you need to save $ you can wait to buy the gas bottle and start out with flux core wire. But if you intend to do much welding, I suggest you start with a mig welder that it is set up for gas (you can always use flux core and skip the gas).
    A few years ago I sold the 140 for almost what I paid for it and bought a Hobart 210MVP mvp. The MVP will plug into either a 120v outlet or 240. For welding thicker metal it must have 240. On 120v power, its basically the same machine as the 140. The 210 is also big enough to weld aluminum. Even though aluminum has a lower melting point than steel, it takes much more power to weld because aluminum conducts heat much better than steel. So you have to put a lot of heat on it to keep up with how fast the heat is transmitted through the aluminum. Aluminum is also harder to weld than steel.
    If you're wanting to weld 1/8 - 1/4" steel, under optimal conditions (clean and laying on a bench rather than dirty and upside down under your truck), there is a good chance that with a mig welder you can practice a little then just do it. Mig welding is by far the easiest type of welding. Spend some time on youtube and weld some scrap metal in various configurations and you'll catch on quick.
    Your other choice is old tech transformer based welders or the newer style solid state transistor powered welders. The transistor powered welders are much lighter weight. But I read a few reports of the transisters failing (even on Miller), so I decided to go with transformer based welder. I may be way off with this, maybe the transistor powered ones are fine for decades. But I wanted something that will still work great in 30 years. The weight of a transformer welder is not an inconvenience for me.
    that ought to be enough to flush out the welder pros to tell you what you really should do.
  3. Jul 26, 2021 at 12:42 PM
    Grossomotto
    Grossomotto Complete 3rd Member
    39.9526° N, 75.1652° W
    2017 4WDV6LB6MT
    You can get a used Miller mig welder on craigslist, it'll do everything you want
  4. Aug 21, 2021 at 9:48 AM
    aviorperformance
    aviorperformance Well-Known Member
    Alex
    Houston,Texas
    2023 TRD OR - Electric Lime
    I would highly recommend getting a Miller MIG machine even if it’s the smallest one they offer. I think it’s like the millermatic 141 nowadays. A nice machine will save you the trouble of buying things twice. Trust me I’ve learned this the hard way.
    With the MIG welder you’ll need “75/25” gas to go with it. Yes there is gas less welding but it doesn’t look good. If you were welding thick plates that didn’t matter what they look like I’d say just get a cheap stick welder and be done with it. But I’m sure u want these truck pieces somewhat appealing.
    After you have your machine and bottle just watch youtube - seriously. There is so many videos to help out beginners. Very easy to get the hang of MIG.
    I started my fab shop with a Millermatic 140 ages ago. That original machine was a workhorse. We have stayed loyal to the brand since.
    Bivouac and Grossomotto like this.
  5. Aug 21, 2021 at 9:57 AM
    WarrenG
    WarrenG Well-Known Member
    Go to the “anything welding” thread on here. There are lots of people to help answer your question
  6. Sep 9, 2021 at 6:55 AM
    Talon2006
    Talon2006 Well-Known Member Vendor
    I bought a Hobart MVp210 about 3 years ago and taught myself to weld. I found it used but still new in box. Got a great deal on it. I would try to avoid a 120V only machine. Most off road fab requires a lot of 3/16 and 1/4” welding. You will need a 200 amp machine IMHO.
    I also have an AHP alpha tig from Amazon. If I was buying today, and not using it for production I would look really hard at the HF line of welders. They seem to have stepped up their game.
    As far as learning, I would hit up YouTube, find some videos you like and go to town on them.
    Roberto123 likes this.
  7. Sep 9, 2021 at 9:35 AM
    azreb
    azreb Geezer
    TN
    '20 SR5 crew cab; gray
    camper shell, front camera, floor mats, cheap bed mat, dash camera, catalytic converter cover, fumoto
    I took a course about 35 years ago. The instructor insisted we avoid wire welders because they were too easy. He insisted we learn with gas and stick welders first. Bought all three later. Prefer the wire welder for lighter tasks; stick for heavier welding.
  8. Sep 9, 2021 at 11:08 AM
    JMcFly
    JMcFly Well-Known Member
    Central FL
    2012 Tacoma SR5 4x4
    check out your local technical college and see if they offer weekend welding courses and or local makerspaces that have intro to welding classes.
  9. Sep 9, 2021 at 11:20 AM
    Siebermd
    Siebermd It’s all about the journey
    Virginia Beach
    2016 TRD Off Road
    Alu-Cab canopy Camper, Dobinson's Suspension
    Take a look at Everlast equipment. They make very good machines and at reasonable cost. I am a full time welder. All of my Equipment at work is Miller. I personally own an Everlast Tig machine and a Lincoln mig. Miller makes industry leading equipment, but it definitely comes at a premium.
  10. Sep 9, 2021 at 11:23 AM
    ndmak
    ndmak Well-Known Member
    http://catalog.slcc.edu/preview_program.php?catoid=14&poid=6266
    see if you could swing this program into your work/family/hobby balance. instruction time from knowledgeable people will put you further ahead with your money because you will be able to know what you are looking at when you buy a machine, have a better idea to layout and prep a project, have less re-work and less wasted resources that could have been used on more projects
  11. Sep 9, 2021 at 11:29 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    One gets what your budget can afford !
    Harbor Freight has a decent line of Machines for the cost.
    I would not be scared off of using any name brand 120VAC machines to do any welding on a Tacoma .
    More output is always a good thing.
    Schools now days for the most around here don`t teach Gas welding or brazing unless it is in a HVAC class .
    Always good to get some hands on instruction
  12. Sep 9, 2021 at 11:29 AM
    Roberto123
    Roberto123 Well-Known Member
    robert
    2018 Tarcoma SR 4X4 Dbl Cab
    A lot of great responses here! A few years back I bought a cheap wire welder at Lowes. Watched a few YouTube videos, burned holes in several clothing items and had a lot of fun. I have the helmet with the automatic adjuster to darken when welding.
    And if it needs to look pretty, I put the grinder to use. Sometimes I spend a lot more time grinding than welding!
  13. Sep 12, 2021 at 6:11 AM
    Wsidr1
    Wsidr1 Well-Known Member
    Indiana
    2 x 95.5 Ext 2.7L & 3.4L A/T 4x4
    You're not alone. There is even a jingle for this: "A grinder and some paint makes me the welder I aint!".
    Roberto123[QUOTED] likes this.
  14. Sep 12, 2021 at 6:43 AM
    Bivouac
    Then it goes the other way as well" i am a grinder not a welder!"
  15. Sep 12, 2021 at 6:52 AM
    ZColorado
    ZColorado Well-Known Member
    Near Boulder Colorado
    13 DCSB OR 6MT
    35's,Kings, NWF, 488, Harrop, SPC, Archive, Method, RCI, C4
    Mig welding is basically a metal glue gun, could not be easier. I have a Hobart 190 and it will do everything I want it to. C25 gas and .035 wire for most everything steel. I'd not really suggest a Flux core welder or most 120v welders.
    Currently working on welding on Archive Garage extended shock towers. I've done Solid axle swaps, tube cross members, trailer frames, and more.
    TIG may be better with Aluminium and Stainless, but thats much more of an art form then a mig welder. Although it's possible to weld stainless and aluminium with a mig (I've seen both done) it's not nearly as clean.
