Weird roof leak during rain
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Elforbo1987, May 18, 2021.
  1. May 18, 2021 at 7:35 AM
    Elforbo1987
    Elforbo1987 [OP] Member
    Hey guys, i got 2 leaks going on right now and i think i found one but im not sure about this roof leak. I posted a picture of the location. I checked the roof rack stripping. Even pulled stripping back and poured water. Thought maybe it was the third brake light but that seemed fine and poured water on it. Plus someone else had a third brake light leak and it leaked in the back. Mine is in the front. Now you might be thinking its the front windshield but shouldn't it run down my windshield onto my dash? Theres only 2 tiny rust spots and they dont seem to go deep at all. Its also not anywhere else on my roof but in the picture.
    Any thoughts? Thanks!
  2. May 18, 2021 at 7:59 AM
    Natetroknot
    Natetroknot Experiencing TW at several WTFs per thread
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    Windshield is the only possible intrusion point, how the water should run once past the seal is speculative
    Good luck with it!
    Gunshot-6A and Elforbo1987[OP] like this.
  3. May 18, 2021 at 8:03 AM
    Elforbo1987
    My other leak is on driver floor. Only happens during rain. Weather stripping looks fine but if it is bad can i just put adhesive underneath or do you replace it? It looks fine but it is an 07.
    Update: apparently its on passenger side too. Maybe its all from windshield.
  4. May 18, 2021 at 8:10 AM
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    That I don’t know. Somewhere there’s a thread about running caulk backing inside the hollow portion of the weatherstripping to “balloon” it out and seal better but no experience personally.
    My best advice would be to let someone professional do the windshield, tell them to pay special attention to sealing it good because you suspect a leak, then see how much rain still gets on your floorboard.
    Elforbo1987[OP] likes this.
  5. May 18, 2021 at 9:52 AM
    Elforbo1987
    I played with it some more. Put a water hose on it and i think it might be the front end of weather strip where it meets the windshield. I think it then runs to the middle. I glued this part up with Flex Seal. This part isnt suppose to drain is it? Picture where I'm pointing is where it was dripping. Weather stripping for the door is dry inside.
  6. May 18, 2021 at 10:17 AM
    spitdog
    spitdog Well-Known Member
    2015 Access Cab V6 4x4 SR5 MGM
    If the windshield was replaced,that’s most likely your problem. They failed the installation. Water migrates and ends up somewhere else.
    wilcam47 likes this.
  7. May 18, 2021 at 10:29 AM
    Natetroknot
    Nate
    Dubuque, IA
    19 Sport AC-6MT
    I bet you have it fixed, nothing up there but a sunroof (which on a 2nd gen you definitely don’t have) should drain inside the A pillar.
    Curious if the Flex Seal takes care of it, I hear that’s some good shit but I’ve never used it!
    Nice job troubleshooting!
  8. May 18, 2021 at 10:33 AM
    Elforbo1987
    Yea i hope so. Im going to let it dry and throw some more water on it and see if that did the trick. Windshield is original as far as i know. Now the rear one was replaced i think. Correct my if im wrong but didnt most if not all Tacomas have a sliding back window? Mines solid... Which means maybe not all do but other things make me think it was replaced.
  9. May 18, 2021 at 10:56 AM
    ace96
    ace96 Well-Known Member
    Western KY
    '11 SWB DC TRD SPORT
    AVS bug deflector, Weathertech digital fit floor mats, TRD skid plate w/ Sockmonkey decal, SOS Cocept sliders w/ Line-x, Pioneer 3500, Hybrid Audio Technology Mirus 6X9s & 6.5s, back up cam mod, Wet Okoles-front & rear, TRD exhaust, 17X9 XD Spy w/ Falken Wildpeaks, Avid light bar
    Check the corner of the windshield. It should tell you the brand.
  10. May 20, 2021 at 8:43 AM
    Elforbo1987
    So it rained on the side a i plugged up and didnt leak but water did come out when i made some turns so i think it come in the passenger side. I blasted water down the passenger side today and got a lot of water in the cab so I'm even more convinced this is the source.
    Something i noticed though was a lot of dirt and tiny crack lines. I went ahead and washed and dried the whole area and sprayed some clear coat in there to prevent any further rust. Yall might want to do some maintenance under yalls cargo rack weather guards.
  11. May 20, 2021 at 8:54 AM
    JdevTac
    JdevTac Well-Known Member
    Josh
    GA/WA
    2nd gen
    Check down near the base of the windshield too at its lower corner. There is a spot of sealant there under the black trim/cowl plastics that can fall apart over time.
  12. May 20, 2021 at 8:58 AM
    Elforbo1987
    I'll do that but for sure it's leaking higher up than that.
  13. May 20, 2021 at 10:17 AM
    kingston73
    kingston73 Well-Known Member
    North eastern Ohio
    09 SR5 4.0L 4x4
    I had that exact same issue in my 09 and it was fixed when I replaced my windshield. My state has windshield replace as a non-deductible item so it was free for me.
  14. May 21, 2021 at 9:18 AM
    Elforbo1987
    Well I'll find out later tonight if its the windshield or not. I hope it isn't.
  15. Nov 10, 2024 at 5:26 AM
    jcesp
    jcesp Member
    Gary
    Tacoma TRD Off Road 2023
    What was the SOLUTION
  16. Nov 10, 2024 at 5:59 AM
    Clearwater Bill
    Billy
    Largo Florida
    OP hasn't been here since June 2023.
    You may not get a response.
    Kolter45 and wilcam47 like this.
