Weird problem...dash beep sound
Discussion in '2nd Gen. Tacomas (2005-2015)' started by TACOsupremacy, Apr 9, 2012.
  1. Apr 9, 2012 at 1:35 AM
    TACOsupremacy
    TACOsupremacy [OP] Well-Known Member
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    Okay..so here is the issue..Im driving home, everything is fine. im bout to turn left so i signal left with my blinker and the dash beep makes noise as if my key was in the ignition with doors open :confused: wth!! so i ignored it. same thing taking another left?? so i stop at home, leave the engine running, turn on my signal right and no sound. Signal left and dash beep going again. Hopped out and its not my bulbs, front and tail is working. Its only when my left turn signal is on. Asked a few of my friends and none of them herd of this in their life. So if anybody can help me or know whats up, post up. I will really appreciate it. Feel free to ask me questions too. THANKS!!!
  2. Apr 9, 2012 at 1:39 AM
    the.sight.picture
    the.sight.picture Wishes he was in the woods.
    Nick
    Blue Ridge
    2018 QuickSand
    Check out my build thread (Beginning of Money Pit)
    must be gnomes man.....beeping gnomes
  3. Apr 9, 2012 at 2:50 AM
    hogeyphenogey
    hogeyphenogey Back in a Tacoma
    Dave
    Agawam, MA
    Lunar Rock 2023 TRD Sport 6spd
    Sounds like an issue with the multifunction switch? Possibly a short.
  4. Apr 9, 2012 at 12:22 PM
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    I have no idea, its only when im signaling left
  5. Apr 9, 2012 at 12:22 PM
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    Anyone else got ideas or may know??
  6. Apr 9, 2012 at 10:56 PM
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    Okay now it beeps once everytime i push on the brakes..
    Anybody know anything of this? I already tried the search bar and no solutions
  7. Apr 10, 2012 at 12:01 AM
    Blueberry
    Blueberry Well-Known Member
    Nick
    Newton, KS
    T/X Pro named Blueberry by my daughter
    Custom Roofrack, Satoshi, Ammo-can in bed, Hi-lift, 2 HID Hella 700's, 4 Automatcentral 7" Offroad Lamps, 2 Hella Work/Bed Lamps, "Derp'd" Radio and Shifter Console, Anytime Fog-light mod, Anytime Rearview Camera mod, DTRL mod, Awesome TW sticker mod.
    When it beep does it do it the entire time your foot is on the brake? (Brake on 10 seconds, beep beep beep...) or (Brake on 10 seconds single Beep)? Same for the turn signal? Does it go beep beep beep every time the blinker blinks?
  8. Apr 10, 2012 at 12:36 AM
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    No, it beeps once when im on the brake..and as for the turn signal, it beeps like twice every 5seconds when the turn signal is on
  9. Apr 10, 2012 at 12:51 AM
    Blueberry
    Nick
    Newton, KS
    Hmm. This is pure speculation but it does sound like some sort of short. I'll do some hunting around on the net and see if I can find a more definitive answer for ya.
  10. Apr 10, 2012 at 1:04 AM
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    Thanks bro..ive been tryna look all day myself and couldnt find anything. If you find something i would really appreciate it very much
  11. Apr 10, 2012 at 3:41 PM
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    Help now..i dont know what to do anymore but pull the beep chime out already
  12. Apr 10, 2012 at 5:21 PM
    Blueberry
    Nick
    Newton, KS
    Man I scoured the internet last night and today and couldn't find anyone with this problem. The only thing I'd say to do would be to take it to a dealer and see if they'll just look at it for free or a small charge. I wouldn't pull the buzzer, that might just mask a possible problem that could become worse over time leading to a more costly repair. Sorry I couldn't help much. :(
  13. Apr 10, 2012 at 5:38 PM
    jivewalker
    jivewalker Well-Known Member
    Jack MeHoff
    Chucktown
    2012 4RUNNER TE w/KDSS, 2017 LAND CRUISER
    I would start with the turn signal on reminder circuit and look for a short, etc. I would also research the timer that tells the reminder when to chime, is it solid state or is it in the computer, etc. If solid state, i'd say it could be faulty...if in the computer, i'd suspect faulty relay, short, or computer issue.
    Disconnect battery for 15 minutes then re-connect and see if go's back to normal...just some suggestions..good luck
  14. Apr 10, 2012 at 10:24 PM
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    Thanks you guys..i tried everthing BUT disconnect the battery. Ill give it a try
  15. Apr 11, 2012 at 7:09 PM
    landphil
    landphil Fish are FOOD, not friends!
    BC, Canada
    RIP 2006 Tacoma DCSB
    Tundra 5.7 mod
    If you have trailer wiring, check there. Especially at the 7 wire socket. Shorting between the left signal/brake pin and the reverse light pin will make the "reverse" beep work when it shouldn't. I'm talking about the one normal beep that happens when you shift into reverse on the 6 spd.
    If no trailer wiring, check your tail light wiring harness for any sign of rubbing or damage, especially the left side.
    clcurtis42 likes this.
  16. Apr 12, 2012 at 10:42 PM
    landphil
    BC, Canada
    Tundra 5.7 mod
    Any news or update?
  17. Apr 16, 2012 at 12:40 PM
    TACOsupremacy
    Gaven
    Aiea_Hawaii
    05taco
    Never satisfied
    Updates..popped out my whole das area, checked everything, moved some wiring around and found a dead roach between a bunch of wires :confused: took it out and no more beeps!!:D Oh man lol
    socpoolman and MuddyJackson like this.
  18. Apr 16, 2012 at 12:49 PM
    Blueberry
    Nick
    Newton, KS
    LOL are you shitin' me?
    wilcam47 likes this.
  19. Sep 17, 2014 at 1:11 PM
    FishaRnekEd
    FishaRnekEd Well-Known Member
    New Orleans, LA
    2005 4.0 6spd 4x4 Dbl Cb short bed
    Glad I foud this! Im having the same problem, but I think it may be from the shoddy stereo install job (previous owner)
    anyone have a write up on how to take the dash apart?
    Im getting the same Dash Beep and think i may have a "roach" as well...
    socpoolman likes this.
  20. Jan 22, 2018 at 7:13 AM
    clcurtis42
    clcurtis42 Member
    Cruise
    Omaha, NE
    01 TRD 3.4 5 speed Locker
    Dip
    YES! Finally! I've been having the same issues. I didn't think about looking at the trailer harness. Thats the first thing im doing when I get off work. Makes so much sense. Fingers crossed I don't have to go wire hunting under the dash.
