Weird brake/ turn signal problem?
Discussion in '1st Gen. Tacomas (1995-2004)' started by fortiz619, Jul 26, 2017.
  1. Jul 26, 2017 at 8:25 PM
    fortiz619
    fortiz619 [OP] yeh i drive a 2wd big woop wanna fight about it?
    Southern California , IE ,SD
    04 Tacito 5lug, 16 tundra, 07 tundra
    Well as u can read from title I'm having an issue with my 2004 Tacoma, after installing new battery my left turn signal began acting up now everytime I press the brake pedal it lights up where should I begin I searched the forum but nothing any suggestions would be much appreciated
    **updated** FIXED
    Battery had nothing to do with it BAD GROUND on rear driver side taillight
    (turn signal socket)
    Dalandser likes this.
  2. Jul 26, 2017 at 8:50 PM
    2stroketrush
    2stroketrush Well-Known Member
    Tyler Addison Rush
    Baltimore
    Built 97 ExtraCab
    Overland Purpose Built 97 going on 190K.
    I would check your trailer light connection if you have one.
  3. Jul 26, 2017 at 9:02 PM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    ^ what he said. something could have shorted.
    fortiz619[QUOTED][OP] likes this.
  4. Jul 26, 2017 at 9:24 PM
    fortiz619
    No trailer connection it's a base model tacoma no tow package , already checked battery grounds , fuses and everything checked out turn signal relay was replaced 5 months ago could that be it ?
  5. Jul 26, 2017 at 9:29 PM
    mechanicjon
    mechanicjon They call me "Jonny Stubs"
    Jon
    Scottsdale Arizona
    04 Taco SC 4dr SR5 TRD Prerunner
    Supercharged, AEM FIC/6, Meth Inj, ION Alloy's, Radio & Phone steering Wheel controls,Fabtech AAL, Billie's wrapped with 880's , Tundra big brake conversion, bully bars and Pioneer DDin Stereo/dvd with exterrnal usb ports. 290K and going strong.
    Just your front left turn signal lights up? Do all the other lights wotk correctly?
  6. Jul 26, 2017 at 9:33 PM
    fortiz619
    My hazards , right turn signal all working fine it's my left turn signal that acts up when the brake is pressed
  7. Jul 26, 2017 at 9:40 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    Front and rear light? Left turn signal is normal?
  8. Jul 26, 2017 at 9:42 PM
    fortiz619
    LEFT( DRIVER side ) signal is the one that comes on when brake is pressed , u can actually see it light up in front LEFT signal light and REAR LEFT taillight
  9. Jul 26, 2017 at 9:48 PM
    tw0leftskis
    tw0leftskis Well-Known Member
    0xApes
    Meta Verse
    With out pressing on brake pedal, l key on engine off or running doesn't matter.. Does the turn signals operate properly?
  10. Jul 26, 2017 at 9:49 PM
    fortiz619
    Withought pressing brake pedal the turn signal works fine
  11. Jul 26, 2017 at 9:58 PM
    fortiz619
    One little Detail I left out is that after battery was replaced I took it for a quick spin around the neighborhood I had to turn left when I pressed down on the switch it made the the left turn signal act up thats when the brake problem began
  12. Jul 26, 2017 at 11:10 PM
    mechanicjon
    Jon
    Scottsdale Arizona
    You either have a bad body ground or a problem in the tail light assembly wiring or wiring harness for rear lights. Because the turn signal and brake lights are seperate circuits.
    fortiz619[OP] likes this.
  13. Jul 26, 2017 at 11:23 PM
    MikeWH
    MikeWH Well-Known Member
    Colfax, CA
    1999 TRD 4x4 (x2)
    Exactly this. I have had these exact symptoms on 2 Tacomas. The ground is tied to the body near the rear tail light housing. Fix this and all will be good.
  14. Jul 27, 2017 at 2:17 PM
    fortiz619
    **UPDATE** well the problem has been fixed , the problem WAS a ground , the ground was the one connected to the turn signal socket in the rear tail light it was corroded so I removed, cut and recrimpped
    Want to thank all of u guys for being super helpful thanks again
    snakedriver, frizzman and wilcam47 like this.
  15. Jul 27, 2017 at 3:20 PM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
  16. Dec 6, 2018 at 5:50 PM
    snakedriver
    snakedriver New Member
    2004 Toyota Tacoma 4wd
    I had the issue exactly except that it was either turn signal flashing quickly when the brake was pressed and a search brought me here. I resolved mine today after removing the trailer converter box wiring (they ought to call it what it is: an isolator. It isolates the trailer and vehicle wiring). It wasn't that. It was a ground. I ran a jumper cable from the light socket body on the tail light to the trailer hitch receiver for troubleshooting and the lights behaved. A more permanent jumper was installed subsequently. I don't know the location of the original ground on the vehicle end. The bulb socket ground was okay, as in not corroded and it had continuity from the socket through the connector but not to the vehicle ground. Thank you to all who contributed here; it led me to the resolution.
