Weird beeping, won't start.
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1985 4runner, Jan 28, 2016.
  1. Jan 28, 2016 at 9:13 PM
    1985 4runner
    1985 4runner [OP] Member
    Gulfport, Mississippi
    02 Prerunner DC
    Had an issue today that I've never had on any of my Toyotas over the years. Truck is a 2002 Tacoma Prerunner 2.7 Auto, 135,000mi
    I maintain this truck regularly and have never had any major issues. Has been starting & driving normally recently except for one of the three belts (power steering, A/C, Alternator) just starting squealing about three days ago. I stop for gas & when I try to start the truck back to leave-nothing. No audible clicking at all, no dash warning lights either, just a fast pitched beeping that I've never heard before.
    Battery was replaced in 2012, I have not checked the voltage because I loaned my multi-meter to a friend a week ago. I removed both battery terminals and cleaned a very small amount of corrosion from the positive terminal and tapped on the starter. Truck started up like nothing was wrong. I've have dead batteries before, bad starters, alternators and corrosion on terminals, but there was never any weird beeping. Any other owners experience this?
    truckchic likes this.
  2. Jan 28, 2016 at 9:21 PM
    DustStorm4x4
    DustStorm4x4 BBC 2020
    U S A
    04 Jeep LJ
    I've had two first gens so far and have never heard that noise before. I'm intersted to see what it turns out to be.
  3. Jan 28, 2016 at 10:09 PM
    Snowman
    Snowman I have a problem for your solution…
    Craig
    Somewhere in Canada
    Check out my build
    Sounds like an aftermarket alarm or immobilizer. Disconnecting the battery may have reset it somehow.
    Maybe a remote starter gone haywire?
  4. Jan 28, 2016 at 11:13 PM
    CodeSeven
    CodeSeven LOC: 33.781461, -115.867251
    Serge.
    Coachella Valley
    '00 Taco 3.4 4x4 TRD ( <3), '06 Taco Prerunner 4.0 (totaled)
    3 inch lift. bluetooth stereo. blue transparent skulls shift knobs
    best i can come up with is just a bad connection. and the odd beeping was your standard "key in cylinder while door open" warning beep. But since the bad connection feigned a dead battery, the beep alone would actually sap all the power from the battery and the battery would feed power back immediately, causing the beep to be faster than normal.
    but that is a stretch.... to say the least......
    cruxofthebisquit likes this.
  5. Jan 29, 2016 at 10:04 AM
    Digiratus
    Digiratus Adventurer
    Roaming the PNW
    The RedHead
    2002 XtraCab TRD 4x4 SCv6 AutoTrans With Lots of Mods ADS COs w/Compression Adjusters Camburg Uniball UCAs Whiteline Lower Control Arm Bushings Kartek 7" Limit Straps Plastics Guy Front Bumpstops Total Chaos Sprindle Gussets Custom Alcan Springs +800 lbs +3" ADS 10" Stroke Triple Bypass w/Resi Rear Shocks Custom Rear Shock Relocate All-Pro U-bolt Flip w/Timbren Bumpstops 4.88 Nitro Gears ARB Front Locker ARB Twin Compressor Black 17x8 Konig Countersteer Type X 285/70r17 Falken A/T3w Gunmetal 16x8 SCS Ray10s 255/85r16 Maxxis Bighorns Limited Edition (Relentless) Elite Front Bumper Smittybilt X2O 10K Winch Diode Dynamics SS3 Sport Selective Yellow Fog Lights in the Bumper Diode Dynamics SS3 Pro 4,000 Kelvin SAE Driving Lights with Clear Lenses on the Bumper Morimoto D2S Projectors XB35 Ballasts + 4300K Bulbs Badland Sliders FrankenFab Tire Carrier Swingout bumper w/kitchen BudBuilt Front & Bellypan Skids BAMF Rear Diff Skid Dometic CFX 55im Fridge/Freezer Alpha II Hardshell RTT Badland Custom Bed Rack Denso 210-0461 105 amp alternator Dual Northstar 24F AGM batteries BlueSea 7622 ML-ACR Battery controller Peak DBI Dual Battery Voltage Monitor Haltech IC-7 Display with Mako Dash Insert Haltech Elite 2500 Standalone ECU Magnuson MP62 Supercharger w/URD 2.2" Pulley Denso 650cc Fuel Injectors Aeromotive Stealth 340 Fuel Pump TransGo A340F Reprogramming Shift Kit Doug Thorley Headers 2.5" Magnaflow Hi-Flow CAT Magnaflow 18" Muffler w/Vibrant Resonator 13WL Brake Calipers Braided Steel Brake Lines Kenwood TM-71A Dual Band Ham Radio Larson 70CM/2M Antenna Midland MTX275 GMRS Radio w/Roof Mount Antenna Uniden 520xl CB radio 3' Firestik Adjustable tip antenna Pioneer DEH-P9400BH HU Alpine Amps & Type R components (F) and coaxials (R) Wet Okole Seat Covers Weathertech Digital Liners Deck Plate Mod 1" Diff Drop Carrier Bearing Drop
  6. Jan 29, 2016 at 10:59 AM
    frizzman
    frizzman Well-Known Member
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    OME 2.5,Tundra 17s,Falken Wildpeak AT3W hitch w/ 7-pin, ARE cap, JVC HU w/BT, HID/LED lights
    that beeping is too fast for "key in door" chime. it also sounds higher pitched than the "ding"
    have you owned the truck since new? bought used?
  7. Jan 29, 2016 at 11:07 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
    My wife's Rav4 did something similar when her battery shorted out. But the gauges flashed also. It's a 2007. I would say the battery is toast. If it goes away after disconnecting the battery and using jumpers, well....there it is.
  8. Jan 29, 2016 at 11:25 AM
    wilcam47
    wilcam47 Keep on keeping on!
    Will
    Bourbon state
    Different vehicle but when my Nissan's battery started going out...it had some weird beeping/guages fluctuating etc. I went and got it tested somewhere and they said it was good...the next day I went to Autozone to get it tested there and it wouldnt even start...they tested it and said the battery was toast....got a new one and didnt have any problems after that.
  9. Jan 29, 2016 at 12:10 PM
    Razgriz
    Razgriz wtf am i reading
    San Jose, CA
    2013 White TRD 4x4
    When my truck battery started to fail, the horn will continually activate. First gen and dying battery's do all sort of weird things it seems. I'm curious what is actually happening with your truck.
  10. Feb 2, 2016 at 7:25 AM
    1985 4runner
    02 Prerunner DC
    Bought truck used, never had any issues. Truck has no aftermarket alarms, remote start or anything like that. Will check battery voltage today. Truck has started 5 days straight with no problem since this one time issue.
  11. Feb 13, 2016 at 1:50 PM
    1985 4runner
    02 Prerunner DC
    Battery checked out OK, only thing I can figure is the corrosion on the terminal
  12. Feb 13, 2016 at 1:54 PM
    teamhypoxia
    teamhypoxia MichelinMan
    Colorado
    '12 DCSB TRD OR
    If you had corrosion, check the cables.
    On an older truck, I had corrosion work it's way up the cables under the insulation. It caused all kinds of weird symptoms.
    Replaced the cables and all was fixed.
    1985 4runner[OP] likes this.
  13. Aug 6, 2017 at 7:52 AM
    ToyotaRoamer86
    ToyotaRoamer86 Well-Known Member
    Brandon
    Frisco, CO
    2007 Tacoma TRD Sport
    Figured out?
  14. Aug 6, 2017 at 5:35 PM
    SouthernYoder
    SouthernYoder If you skarred, say you skarred.
    Knoxvegas, TN
    01 dbl cab 4x4 3.4l SR5
    3" OME, 883 coils, Nitros, AAL, 07 FJ Trail team wheels, K&N CAI, Tundra brake upgrade.
    :popcorn: Here to see the issue.
  15. May 24, 2018 at 10:00 PM
    PobreFresh
    PobreFresh Active Member
    Taylor
    Dallas Texas
    2003 4dr 4wd 3.4L auto
    I have an 03 taco 3.4 liter and mine is doing the same thing. I'm also at a gas station. Had corrosion on positive terminal and cleaned it off. Still nothing other than acc power. No headlights.
  16. May 25, 2018 at 7:28 AM
    tan4x4
    tan4x4 Well-Known Member
    Rick
    Folsom, CA
    99 Tacoma EC 4x4 2.7L Auto
    Bilsteins, OME 881's, 3-leaf AAL, Detroit TruTrac, Tundra brake swap, Michelin LTX AT2, Tranny skidplate, TC skidplate, CBI rear bumper, TG sliders, UltraGauge, PowerTank, Reverse Camera
    6 years is a long time for a battery. You certainly got your money's worth.
    Time to retire it, and take it out of the discussion.
  17. May 25, 2018 at 7:33 AM
    Jckdnls
    Jckdnls Roads less explored
    Spicer, mn
    93 3.0 v6 sr5 5spd 08 ac or 6sp
    Dakar torsion bars
    Sounds like a battery with a bad cell or an alarm system shorting out.
  18. May 25, 2018 at 10:21 AM
    frizzman
    Pittsburgh, PA
    04 XCab 4x4 TRD/OR
    I got a little over 7 out of my factory battery :D
    not sure if Cold Climate got a higher CCA but was still same family of battery. My 2nd battery lasted about a little over 4½ years :|
  19. May 25, 2018 at 10:45 AM
    Jckdnls
    Spicer, mn
    Dakar torsion bars
    Depends upon how someone maintains the battery. Sell alot of batteries. Some folks get acouple of tears some get up to 10.
  20. May 25, 2018 at 7:55 PM
    PobreFresh
    Taylor
    Dallas Texas
    I checked my battery. It showed 12.7 so I took it out and put it on charge. I changed my alternator out with a refurbished one. Thats all O'Reilly's had. Waited for battery to charge. I got it to 90% and put it back on and hooked up. Started the truck and it had a rough idle at about 300 rpm. Then it died. Couldn't get it started without using a jump box. So I guess next step is to test battery. Maybe it has a bad cell. Its less than 2 years old.
