Weight of typical nerf bars vs sliders?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by old_and_in_the_way, Dec 5, 2020.
  1. Dec 5, 2020 at 2:20 PM
    old_and_in_the_way
    old_and_in_the_way [OP] Well-Known Member
    Somewhere hot, flat and brown.
    Anybody happen to know what the weight difference will be between these two? I had Nfab bars on my last taco, but am thinking about 0 or 5 degree bolt on sliders for my new one for use as steps also. I don't necessarily "need" sliders and I'm only likely to be in a place where I might find them useful a few times per year, but I figure if I'm going to hang a bunch of extra weight from the truck it may as well be dual purpose.
    I gather that sliders seem to come in around 100 lbs per pair, but does anyone know who much an average pair of nerf step bars weigh?
    thanks.
  2. Dec 5, 2020 at 4:14 PM
    Interbeing
    Interbeing A Canadian living in Texas
    Austin, TX
    2020 Tacoma TRD Off-Road 4x4 DCSB AT
    TRD Pro suspension with Headstrong 3 Leaf AAL, DV8 OR front slimline bumper & Engine Skid Plate, RCI OR high clearance bumper, CaliRaised Trail Edition Sliders, Spidertrax 1.25" Wheel Spacers, 265/75 16 GY Duratracs, wrapped the OEM wheels, OR Roof Rack, Extang Exceed Hard top Tri fold tonneau.
    I can't speak for NFab bars, but the OEM Toyota Predator bars are very light, perhaps 20lbs each. Although I use my truck as a daily driver, the Predator Bars were one of the first things I took off, after my first trip off road, I realized very quickly just how dangerous they were off road, not just the 3 inches of clearance you lose, but they also greatly enhance the risk of rocker panel damage. Even if you are only going off road a few times a year, it is worth, either getting sliders, or at the least, removing the body mounted bars before heading out off road to reduce the severity of potential damage to your truck.
  3. Dec 5, 2020 at 4:17 PM
    old_and_in_the_way
    Yeah. Agreed. Like I said, I don't expect to be doing and hardcore crawling but I did buy this truck to explore when I can. I know my limits, but things get pretty unpredictable sometimes out on the trail. I'm interested in 0 or 5 degree sliders to function as steps as well. I remember installing my old Nfab steps by myself but it wasn't easy. If the weight delta is minimal, I'm going slider but i just would like to know if anybody else has been down this road before.
  4. Dec 5, 2020 at 4:25 PM
    Interbeing
    Austin, TX
    I removed the Toyota Pred Bars and replaced them with Caliraised LED Trail Edition bolt on sliders. I was able to install them on my own in a couple of hours with the help of a floor jack. The install was pretty straight forward, and about the only difficulty I had was threading in the bolts on the front crossmember attachment, it took me probably 15 minutes of fiddling to get them to thread in.
    texas angler and SpicyTacoTRO like this.
  5. Dec 5, 2020 at 4:33 PM
    old_and_in_the_way
    That's what I'm wondering. When I installed my NFab bars, I didn't need floor jacks or anything to hold them up while I hand threaded bolts. I don't think sliders are *that* much heavier than aftermarket nerf bars but can't be sure because most manufacturers don't readily publish weights. Just trying to quantify added weight before I begin to think about suspension in the future.
  6. Dec 5, 2020 at 4:46 PM
    Interbeing
    Austin, TX
    Yes, I have been concerned about the exrta weight of all the amor and gear I carry regularly in my truck, however, at this point, even with the extra weight, there is no appreciable sag. I am waiting for Headstrong to get their progressive 3 leaf AAL's back in stock, which I hope to get some of the rake back I lost when I swapped out my OR Bilstein's for TRD Pro Fox shocks.
    This is with the truck almost fully loaded with gear during this year's Thanksgiving break. The rear looks a bit lower in the photo, but it is almost level with the front.
    ChipsCashedIn likes this.
  7. Dec 5, 2020 at 6:53 PM
    CaptainBart45
    CaptainBart45 Well-Known Member
    Bart
    2017 Tacoma Sport 4x4
    Work in progress...
    The weight of nerf bars and sliders vary by a great deal. A light pair of sliders may only be 50 pounds heavier than a heavy pair of nerf bars. A heavy pair of sliders my be 150 or more pounds heavier than a light pair of nerf bars.
    SpicyTacoTRO likes this.
  8. Dec 5, 2020 at 7:34 PM
    angerbot
    angerbot Well-Known Member
  9. Dec 5, 2020 at 9:40 PM
    SpicyTacoTRO
    SpicyTacoTRO New Member
    Somewhere between Florida and Alaska
    2020 Magnetic Gray TRD Off-Road
    I just installed some CaliRaisedLED sliders on my DCLB. Per the shipping receipt they had a total weight of 150 lbs, so about 75 lbs for each slider. I installed on my own but in hindsight probably should have had a helping hand because it was heavy. If you go that route and do it solo, a jack and some jack stands are pretty much a necessity to install safely.
    Like others have mentioned and through some quick google-fu, it looks like running boards that attach to the rocker panels would roughly be around 20 - 25 lbs per side depending on the brand.
  10. Dec 5, 2020 at 10:12 PM
    Modkingz
    Modkingz Active Member
    Manny
    Tacoma trd off road
    We just came with are own rock sliders for short bed 3 gen tacomas
    Loco_Driver and CaptainBart45 like this.
  11. Dec 5, 2020 at 11:12 PM
    KissmyTaco
    KissmyTaco Well-Known Member
    Eric
    Phoenix, AZ
    2017 Tacoma MGM DCSB TRD Sport
    I have a Gashole
    I have Lund nerf bars and per manufacturer specs they are ~20#each
    suaveflooder likes this.
  12. Dec 5, 2020 at 11:51 PM
    CaptainBart45
    Bart
    Work in progress...
    I went back to my earlier post to research, Wife Say's I Don't Need Sliders, anyways my sliders are 99.5 pounds while my nerf bars were 50 pounds. So you can get actual sliders for 49.5 additional, both sides, pounds if ya are going from a heavy nerf to a light slider. I was wondering myself so I did the research and math...My after market nerf bars were 25 pounds each and the sliders were 49.5 each. So actually 99-50=49 pounds. Yea, so 49 pounds heavier.
  13. Dec 6, 2020 at 1:10 AM
    ARCHIVE
    ARCHIVE Well-Known Member Vendor
    Eric
    Orchard Park, NY (Buffalo)
    '05 Taco, '22 Tundra, '91 Cummins
    2.5" Fox relocation * Hammer hanger * Archive MD springs
    CaptainBart45 likes this.
  14. Dec 7, 2020 at 12:48 PM
    Loco_Driver
    Loco_Driver Well-Known Member
    Connellsville, PA
    2018 TRD OR DCSB M/T
    Loco Driving Mode
    Tell me about them! I'm in the market.
    Chris_The_Red likes this.
  15. Dec 7, 2020 at 6:28 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    The only time my sliders see action is when I’m in the thick of a rock crawling trail and at the point you need more than sliders.
    Get them if you want them but I’d be surprised if you ever used them.
  16. Dec 7, 2020 at 6:51 PM
    old_and_in_the_way
    I know, and I fall into that category as well. From time to time, I do head out to the trails and I have come really close to trouble with my old nerf bars on my last truck but that's pretty rare. Nfab now makes some "trail sliders" that are body mounted but are a solid steel rail that may be what I really need. They look pretty good too. Good for a step, good for minor protection from some things, but who am I kidding...I'm not going to be doing any extreme "Mountain Dew Commercial" crazy wheeling. Sort of like my buddy who put hard back non-adjustable bucket seats and harnesses in his Porsche, when he may do one or two track day events - total - while owning his car.
    My thought was to have dual purpose setup (steps and protection) but I do want to avoid larding up my truck with a ton of weight that I realistically will not ever use hence the original question.
    Edit: I see you're in Co Springs...I live in Buena Vista part of the year and do explore some of the trails around there (Marshall Pass is my favorite) but I haven't done anything yet that would require any special equipment or even 4LO most of the time for that matter...just pick a good line and that's about it. The drop down steps on my old nerf bars came close a time or two.
    JoeCOVA[QUOTED] likes this.
  17. Dec 7, 2020 at 6:55 PM
    JoeCOVA
    Joe
    Colorado Springs
    I think the 0-5 degrees will work, mine are 20 and pretty tight. They weigh about 75lbs each. I recommend buying local if you can.
    Interbeing likes this.
  18. Dec 8, 2020 at 3:59 AM
    Alnmike
    Alnmike Well-Known Member
    PNW
    '21 4R
    My sliders haven't been used for rocks nearrrrrly as much as they have for trees (and garage walls lol).
  19. Aug 5, 2021 at 10:39 AM
    tgerno
    tgerno Well-Known Member
    Tom
    2021 Cement Tacoma TRD Sport
    I know this is an old thread but it describes what I'm looking for. What did you go with?
  20. Aug 5, 2021 at 11:05 AM
    old_and_in_the_way
    Didn’t do anything yet. Still interested in those nfab trail sliders purely for their looks, not protection but I haven’t seen any in the wild to tell whether they are any good as steps. Hard to tell from the pics I’ve seen.
