Weight of Leer 100xr
Discussion in '3rd Gen. Tacomas (2016-2023)' started by RicZ, Aug 19, 2018.
  1. Aug 19, 2018 at 12:09 PM
    RicZ
    RicZ [OP] Member
    Ric
    2017 Blue SR5
    Leer 100xc cap
    Can anyone tell me the weight of a Leer 100xr cap. No fancy adds except headliner. I need to remove the cap to fix the leaking at the gaps at front rail, but will need to get some help if the cap is too heavy. My local installer is no help.
    Thanks 8n advance.
    RicZ
  2. Aug 19, 2018 at 12:16 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    I can't give you an exact weight, but best guess is around 180 lbs. I wouldn't try to completely remove it by myself. 180 lbs isn't terribly heavy, but would be awkward.
    About once per year I remove the clamps on mine and get inside and with my back against the top lift up slightly and move mine back 6-8". This gives me room to clean the front of the shell and back of the truck. I then move it back. Never had any issues doing this alone. You should be able to do the same to access the front bed rails.
    ThreeBeers likes this.
  3. Aug 19, 2018 at 12:19 PM
    bv8ma
    bv8ma Well-Known Member
    Bill
    MA
    2017 TRD OR
    It's pretty heavy, maybe a couple hundred pounds. I wouldn't try taking it off myself, it's too akward.
  4. Aug 21, 2018 at 9:57 AM
    RicZ
    RicZ [OP] Member
    Ric
    2017 Blue SR5
    Leer 100xc cap
    Thanks, guys. Sounds like I need to get a few friends to help.
  5. Aug 21, 2018 at 10:06 AM
    bv8ma
    Bill
    MA
    2017 TRD OR
    My wife helped me, it's really just akward to get off on your own more than anything.
  6. Dec 17, 2021 at 8:13 PM
    Taco89032
    Taco89032 New Member
    With all that weight, how much did it lowered your Tacoma?
  7. Dec 18, 2021 at 8:00 AM
    Tacoma091919
    Tacoma091919 Well-Known Member
    Tim
    2019 OR DCLB
    I have a LB with a fully optioned out ARE with Martin off-road racks cap and cab, and about 50lbs constant gear and ended up installing sumo springs (612-40s) and I ride on them all the time so guessing 1” or more. Deavers expiation stage 2s are being built to match up with Eibach pro 2.0s coilovers and rear shocks. Definitely recommend something though. A friend has a LB sport with a Leer and was sagging and added Timbrens. These trucks don’t handle much weight without sagging on factory leafs.
  8. Dec 18, 2021 at 8:05 AM
    jacpa
    jacpa Well-Known Member
    Jim
    2021 4Runner TRD ORP
    I get one scrawny friend to help me take my cap on and off. It's not too heavy but you will hurt yourself trying to maneuver and lift something that large and awkward. No good way to really lift it yourself. Just get one guy to assist and you'll be good.
  9. Dec 22, 2021 at 11:01 AM
    herrindude
    herrindude 1996 2.4 extra cab auto
    Fairhope al
    2021 dclb sr5
    ARE camper shell
    I went to junkyard and pulled 2 roof racks off 2 cars and mounted 1and used crossbars from the other to have 4. The corners will be used to lift the shell off all by my self. Just lift it up a couple inches and pull truck out from underneath. 80122BBB-1509-4EF3-AF50-F7D20A0111F0.jpg
  10. Dec 22, 2021 at 11:03 AM
    herrindude
    Fairhope al
    2021 dclb sr5
    ARE camper shell
    As far as weight, i would say about 200 lbs and had 2 people helping.
