WeBoost antenna mount
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nhm6408, Feb 4, 2021.
  1. Feb 4, 2021 at 11:58 AM
    nhm6408
    nhm6408 [OP] Active Member
    2020 Quicksand DCLB Sport
    Where do you think the best place to mount a WeBoost antenna is? I bought a mount for the back of the truck but am worried about it whipping around like my CB antenna did on my Jeep. Was thinking of going on the roof rack like Mike from LLOD did. Thoughts? Drew my options in orange.
    cthoma70 likes this.
  2. Jul 20, 2021 at 3:19 PM
    Tatoryota
    Tatoryota Member
    2021 TRD Pro Lunar Rock
    Tires, seat cover, switch pro 9100 with blue seas/power plate , ONX6 Dual light bar, Rigid industries flood lights, dual battery
    I too am looking at those two mounting locations for my weboost, I'm leaning more towards the roof rack mount and towards the front. The rear location seems like a better spot for a CB antenna and the weeboost may get in the way of a rooftop tent in the rear if one is ever mounted. Just my thoughts though, like I said I'm trying to decided this very same thing. Did you end up choosing a spot? if so where and why if you don't mind
    Merling likes this.
  3. Jul 20, 2021 at 4:04 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    If performance matters then mount to roof center where it will have a metal ground plane.
  4. Jul 20, 2021 at 6:28 PM
    ca08tacoma
    ca08tacoma Well-Known Member
    LLOD, Mike had a clean install that collapsed as needed if I recall. I’d give that a try. Less wire to run too?
  5. Jul 21, 2021 at 7:07 AM
    nhm6408
    I ended up mounting mine to the roof rack on the rear passenger side. Like Mike from LLOD with some ram balls and a mount. Works super well. Ran the wire up front and down the groove between the windshield and A Frame. Was super tight getting it down there but it's super clean now. I was going to but it in the back like my picture but for some reason my topper very slowly likes to slide back. It's really annoying.
  6. Jul 21, 2021 at 7:26 AM
    SRBenjamin
    SRBenjamin Well-Known Member
    Benny
    Rims look great on that sand color.
    If it's for SW? center of cab.
  7. Jul 21, 2021 at 7:17 PM
    djacri
    djacri Well-Known Member
    cthoma70, geobontaco and Tatoryota like this.
  8. Jul 21, 2021 at 7:47 PM
    Double Down
    Double Down Well-Known Member
    Colorado Springs, CO
    '23 ACLB TRD OR
    Magnuson, King, OVRLND, Deaver, Method, BFG
    Ive been thinking of doing the same. Do you have any pics of how you mounted it? And are you saying you just pulled up the stock windshield gasket and tucked the wire in?
  9. Jul 21, 2021 at 7:50 PM
    2012TacomaGuy
    2012TacomaGuy Well-Known Member
    Hayden
    Goodyear AZ
    2012 Pyrite Mica DCSB TRD Sport
    Empty wallet
    I also mounted mine on the passenger side roof. Waiting to put on a RhinoRack Aerial bracket when I get time so it can swing down 90 degrees and be below my gun cases for clearance
    86B75E4E-B9D4-43B3-B0E8-1D73CEED546C.jpg 9117D048-5C99-45EF-B239-C46B1BCE525A.jpg
  10. Feb 9, 2022 at 7:11 PM
    Williamstaco
    Williamstaco Member
    William
    2019 TRD PRO
    Looks solid man. I have been trying to figure mine out as well. Wanted to do something similar to Mike with it adjustable to lay flat when needed with RAM mounts. Haven’t been able to find/figure out the exact hardware and RAM configuration to do so. Any details you could share or close up pics of it attached to the Prinsu? Thanks for the help!
    2012TacomaGuy likes this.
  11. Feb 10, 2022 at 3:08 PM
    2012TacomaGuy
    Hayden
    Goodyear AZ
    Empty wallet
    If you're asking me, I ended up getting the newer version antenna that WeBoost came out with... it now sits only 3 inches above my roof gun cases so I didn't get swinging mount. You could look into the RhinoRack Aerial Folding Bracket however. Seems fairly straight forward
  12. Jun 17, 2022 at 11:20 PM
    xB0WZ3Rx
    xB0WZ3Rx Member
    Johnny
    2019 4Runner Pro
    Do you mind if I ask which Weboost model you purchased? Without the swinging mount, are you not able to fold it to lay flat?
  13. Jun 18, 2022 at 3:56 AM
    ClassyTacos
    ClassyTacos National Treasure 3, Times a ticking Nickolas
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
    Mine is up on the rack as high as possible within reason. I'm on my second mount, I have not been able to find a mount that fits my needs. I need the mount to found back down flat with the cab and then 90 degrees in order to lock it into a Rhino Grip for daily driving.
    On the trails --
  14. Jun 18, 2022 at 10:46 AM
    2012TacomaGuy
    Hayden
    Goodyear AZ
    Empty wallet
    I bought the Drive Reach OTR Fleet one for multiple users. When I bought it, it came with their older style antenna, but it looks like the kit now comes with the one I have currently on the truck. Both are linked below. As for the mount, I mounted it as low as I can go on the rear most bar of my prinsu rack. The antenna only sits a couple inches above the gun mount I always have on my truck so I'm not worried about it hitting anything. It's also still on the supplied spring so it goes have some give to it, it anything does run into it.
    https://www.weboost.com/products/drive-reach-otr-fleet
    https://www.amazon.com/gp/product/B08LM5WYH7?ie=UTF8
  15. Jun 18, 2022 at 11:02 AM
    2012TacomaGuy
    Hayden
    Goodyear AZ
    Empty wallet
    Off topic, how to do you mount your spare tire in your bed?
  16. Jun 19, 2022 at 4:16 AM
    ClassyTacos
    Papalote
    Florida
    2017 TRD Sport 4x4
    Stockish
  17. Jun 21, 2022 at 9:01 AM
    Blueberry.Taco
    Blueberry.Taco blueberry.taco (IG)
    Ryo
    SE MI
    LT, triple locked, 35s, custom aluminum utility bed with FWC
    some welding required
    since i sometimes carry a camper that goes over most of the roof i placed it on the front bumper.
    Probably not getting the most i can out of it but it still makes a huge difference when signal is weak
    284200419_10101786246105347_705152737902_870f5e0ccad362b8a7c721a8dc619abe6164bba4.jpg
  18. Jul 30, 2022 at 5:21 AM
    OverlAnderson
    OverlAnderson A dude playing a dude disguised as another dude
    Anderson
    San Antonio, Tx
    14 TRDS DCSB 4X4
    stuff and things
    Anyone have any info on the weboost ram ball mount? Set up
  19. Jul 30, 2022 at 5:55 AM
    Bishop4WD
    Bishop4WD Well-Known Member
    San Diego until I escape Communist California
    2019 MGM Off Road
    I tried the ram ball setup for quite a while beforehand and it was only so-so for me. No matter how hard it was hand tightened there was still some laxity so I felt the need to secure the antenna with a strap when it was lying flat. It was fine when upright for driving on trails but it wouldn't hold up great going up to higher speeds on the street.
    Eventually I bit the bullet and ordered the stupidly expensive Rhino Rack antenna mount for my weboost antenna. I've been running it for around a year and it has been excellent, actually recently bought a second one for another antenna. I have to admit it works really well, easy to mount to my Prinsu rack with minor modification, folds to multiple angles including the 90 degrees I usually secure it at. I know FrontRunner makes a different version that rotates more like the hands of a clock, depending on which way you want the antenna to fold down. I haven't looked at the mounting points for that one but I'm sure anything can be modified to work on non-Frontrunner racks.
  20. May 1, 2023 at 2:29 PM
    bshammer0
    bshammer0 Well-Known Member
    Brandon
    Nashville, TN
    2017 DCSB TRD OR 4x4
    Prinsu, TruckCovers USA, Coverking, OVTuned
    Reviving old thread - has anyone now bought the Overland mount that weboost now sells that rotates similar to other antenna mounts? I bought the mount, but as others have found, the t-slot plates are too wide for a Prinsu. Anyone have a good part number for good t-slot plates so I can mount it properly without having to return this and get another brand? :)
