Weathertech floor mats - Trimming to fit a manual transmission
Discussion in '2nd Gen. Tacomas (2005-2015)' started by JMcLMorrow, Jan 29, 2016.
  1. Jan 29, 2016 at 11:34 AM
    JMcLMorrow
    JMcLMorrow [OP] Member
    Justin
    2010 AC
    I've always liked the Weathertech floor mats for their fit and quality. I recently picked them up for my 2010 AC, but turns out if you have a manual transmission the clutch pedal catches the edge of the mat.
    I searched but couldn't find much other than a few comments about it, and it seemed that with every person that says it catches somebody else says it doesn't. To clear up any confusion one might have in the future when thinking of ordering these mats, I wanted to create this thread to say the clutch pedal does catch the edge of the mat. Also, its a simple fix! Couple minutes of trimming and it fits perfect.
    I installed the floor mat, depressed the clutch pedal until it made contact with the mat, and using a sharpie outlined where it hit.
    I then cut that section off.
    Voila! I took off a little more on the left side due to the bit of lateral play the pedal has.
    steelhd likes this.
  2. Jan 29, 2016 at 12:01 PM
    steelhd
    steelhd Well-Known Member
    Eastern WA
    2011 DCSB TRD OR
    Did the same. 30 seconds of effort with a pocket knife and problem solved. They could sell more mats if they would just provide instructions for the slow kids instead of advertising that the mats only fit auto transmission Tacomas.
  3. Jan 29, 2016 at 12:30 PM
    bdevr
    bdevr Well-Known Member
    Brian
    Blue State He**
    '10 4 popper
    Floor mats + Toyota + Pedals + potential interference = Legal team going apeshit
    awylie0321 likes this.
  4. Jan 29, 2016 at 12:49 PM
    steelhd
    Eastern WA
    2011 DCSB TRD OR
    Unfortunately very true. But it the interference doesn't cause a hazard. It just causes an annoying little hitch in the rebound of the clutch pedal. Even with clear instructions they would still probably lose sales due to angry internet warriors and spend a fortune answering complaints about the (non)issue.
  5. Jan 29, 2016 at 1:58 PM
    Sna
    Sna Well-Known Member
    Alberta
    ‘15 trd sport 6MT dcsb, mostly stock?
    Maybe they changed things for newer trucks....I don't have any issues with my weathertech mats in my '15 6-speed.
  6. Jan 29, 2016 at 2:12 PM
    george3
    george3 Well-Known Member
    New Jersey
    2008 2.7 Manual Trans Tacoma
    Seat belt beeper, Cabelas (Weathertech) floor liner gray, Covercraft Seat Savers in Taupe, Protecta Heavy Duty Rubber Truck Bed Mat, Pop n Lock PL5200, Pace Edwards Full Metal JackRabbit, Wolverine oil pan heater, Scangauge2, afe pro dry s filter, Remote Underbody 4 Piece LED Light Kit (White) used as Bed light, DIY Washable Cabin Air Filter, PA15-TOY, 4x4 Illuminated Switch, full synthetic, Redline Tuning Hood Support, Smittybilt Nerf Steps black powder-coated
    They say you can't use them so if they get sued they can say "told you so" . I cut mine years ago - never had a problem.
  7. Jan 30, 2016 at 3:49 AM
    ausfahrt
    ausfahrt Well-Known Member
    FL & VT
    2015 SR5 MT 4X4 V6
    Thanks for the info. This is odd though because this picture taken from the Weathertech website clearly shows a manual transmission Tacoma.o_O
  8. Feb 1, 2016 at 9:13 AM
    JMcLMorrow
    Justin
    2010 AC
    That is odd. The placement of the hooks is off as well:
  9. Feb 1, 2016 at 9:48 AM
    mschein1
    mschein1 Well-Known Member
    Lincoln, NE
    2021 Tundra OR CM
    It is for the 12-15 hooks in the pic.
  10. Jan 24, 2022 at 5:34 PM
    Tromezze
    Tromezze Active Member
    Antonio
    Arizona
    2011 Toyota Tacoma TX-PRO 6MT
    Thank you for this! I was bummed out that they only made them for Autos. Now will order some and do this trim for my MT.
    steelhd likes this.
