WeatherTech floor mats allowing salt water through!
Discussion in '3rd Gen. Tacomas (2016-2023)' started by jkcashin, Feb 4, 2017.
  1. Feb 4, 2017 at 8:32 AM
    jkcashin
    jkcashin [OP] Well-Known Member
    Jamie
    Ottawa, Ontario, Canada
    2017 TRD OR AC MT
    I searched for the WT poor fit threads, but can't find them. Maybe it's just a symptom of my bad day. Went to a friends garage to try, for the third time, to get the wiring for my off-road lights through the firewall, and had no luck. Took the drivers side, yes, drivers side WeatherTech floor mat out only to find the carpet underneath COMPLETELY SOAKING WET with salt water. Anyone else experiencing this? Have a suggestion for mats that actually fit right?
    And yes, I know I wrote in another thread a month or so back that my mats were fitting right... I guess I was wrong
  2. Feb 4, 2017 at 8:38 AM
    Sterling_vH111
    Sterling_vH111 Go do something real instead.
    Sterling
    socal
    2012 DCLB Prerunner V6
    Secretly Long Travel & Supercharged
    Were you getting in/out with wet shoes a lot?
    If not where you driving through water frequently? In my second gen, there's a hole in the cab right under the drivers seat, and if that seal was moved/loosened for wires to lights and not put back, water could be coming in through there. Or maybe it just came loose?
    If that's the case I don't see the WT being at fault. :notsure:
  3. Feb 4, 2017 at 8:42 AM
    smitty99
    smitty99 I also bought a 4Runner
    Scottsdale
    16 TRDORDCSB 4x4 A/T (loaded w/ JBL)
    6112s/5160s & 3-leaf AAL;ubolt flip kit;Superbumps
    Sounds like a third gen cab leak
    2017TacoMan, over60 and shakerhood like this.
  4. Feb 4, 2017 at 8:49 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    That was my thought too, sounds like a leak, l would be feeling all around the inside of that truck.
  5. Feb 4, 2017 at 8:49 AM
    jkcashin
    Jamie
    2017 TRD OR AC MT
    Was I getting in and out with wet shoes a lot? Umm, yes... it's winter in Canada.... that's why I bough the mats in the first place. Nope... it's not getting in from somewhere else. It's the WT mats not being made high enough. In my Hyundai, VW, and BMW, the mats were tall enough to contain the water... these are not.
  6. Feb 4, 2017 at 8:50 AM
    jkcashin
    Jamie
    2017 TRD OR AC MT
    Also, the water is salty... so it's coming off my boots. It's localized to one place too... about 4 O'Clock position on the mat.
  7. Feb 4, 2017 at 8:51 AM
    shakerhood
    Southern Ohio
    Is it leaking through the mat hold down clips?
    over60 and RIDERED67 like this.
  8. Feb 4, 2017 at 8:56 AM
    Sharpish
    Sharpish Well-Known Member
    Brian
    Victoria, British Columbia, Canada
    2012 Tacoma TRD OR 4x4
    Might be salt water coming up through the body and soaking the carpet. The roads are heavily salted right now.
  9. Feb 4, 2017 at 8:59 AM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    This.
    over60 likes this.
  10. Feb 4, 2017 at 9:01 AM
    SOSHeloPilot
    SOSHeloPilot My 1st Muscle Car
    S.E USA & S.E. Asia too
    2024 4Runner SR5
    Missing My Last Tacoma --- Had 11 Toyota trucks in the past and many other Toyota cars too.
    Had WeatherTechs for years and in many vehicles and never had a leak.
    I would think that the water would have to come around the WT's or under them from cab leak or your shoes. Just a guess :confused:
    Like they said above check mat locking holes for pooled water going through too.
  11. Feb 4, 2017 at 9:11 AM
    RIDERED67
    RIDERED67 Well-Known Member
    2017 TRD OFFROAD QUICKSAND, DCLB, TECH
    Ding ding ding
    ABA180 and shakerhood[QUOTED] like this.
  12. Feb 4, 2017 at 9:34 AM
    Sagebrush
    Sagebrush Well-Known Member
    Gens 1, 2, 3, and 4
    I like my Weathertechs. Much better than the OEM mats I more or less gave away.
    But hey, it's winter. As my wife would say, "knock the damn crap off your boots before you get inside."
    SB
  13. Feb 4, 2017 at 11:20 AM
    over60
    over60 Over70 & still a "Grumpy Old Guy"
    Muskoka, Ontario
    2016 Inferno (Punkin) TRD 4X4 Sport DCLB w/upgrade & tech pkg..!!
    Toyota running boards/Solid Fold 2.0/custom stickers/Anti-Dark LED light under hood/Derped grill/Scoop, etc.
    When my W/T's get a lot of water in them, I put down a few paper towels to absorb the water. Next time I get in they are full and frozen... remove them and go. I find that if you allow the water to build up you will have humidity issues and possible leaks around the clip holes...
  14. Feb 4, 2017 at 12:56 PM
    pyankura
    pyankura Well-Known Member
    17 TRD SPORT QUICKSAND
    Well if you think they're leaking, fill them with water outside the truck of course. Since you said its licalized at 4 o'clock (4am or pm) I'd say the hold down clips. I make it s habit to kick my feet together to get excess crap off then rely on the mats.
  15. Feb 4, 2017 at 1:09 PM
    Abragus
    Abragus Well-Known Member
    Adam
    Suffolk, VA
    Hoping by now you've already done this but make sure you get that water picked up with a shop vac or carpet cleaning machine.
    I noticed I was getting my carpet wet when I'd relax my right foot and it'd hit the carpet sometimes. Not enough to soak the carpets, but I also do the little tap-tap on my sliders before I get in.
    jkcashin[OP] likes this.
  16. Feb 4, 2017 at 2:48 PM
    SOSHeloPilot
    2024 4Runner SR5
    I had a car that got soaked inside from trunk left open on a hill in a rain storm ... seats & carpeting wet and I got it bone dry in 24 hours.
    Put a dehumidifier inside and electrical cord in open-rolled-up window with a bath towel to seal open window with electrical cord.
    That dehumidifier sucked all the moisture out of everything in that new car and put all that water in the dehumidifier drip pan.
  17. Feb 4, 2017 at 2:51 PM
    Kennedyusmc
    Kennedyusmc Well-Known Member
    Christopher
    2017 Cement Pro
    Still waiting for it
    Yup.
    Trade it in.
  18. Feb 4, 2017 at 3:22 PM
    CusterFan
    CusterFan Well-Known Member
    Southeastern Illinois
    Silver Sky 2019 Tacoma SR, AC, 4X2, 2.7
    https://www.walmart.com/ip/DampRid-RV-and-Boat-Moisture-Absorber/16627481
    Then stop at Walmart or a home center and pick up a 4lb. pail of Damprid. I keep one on the floor behind the passenger seat all year around. You don't have to worry about it spilling. It has ground up corn cobs in the bottom of the pail that soaks up the moisture. Just take the lid off and you are in business.
  19. Feb 4, 2017 at 7:05 PM
    jkcashin
    Jamie
    2017 TRD OR AC MT
    Yep... that appears to be the case. My Hyundai WT mats had a ridge around the hold down clips..... the Tacoma ones have a ridge but it's tiny. Not very effective.
    over60 and shakerhood[QUOTED] like this.
  20. Feb 4, 2017 at 7:06 PM
    jkcashin
    Jamie
    2017 TRD OR AC MT
    Thanks!
