Weathertech deflector auto window issue
Discussion in '3rd Gen. Tacomas (2016-2023)' started by TRDCLMB, Mar 12, 2020.
  1. Mar 12, 2020 at 4:41 PM
    TRDCLMB
    TRDCLMB [OP] Well-Known Member
    2019 Cement TRD Off-Road
    Has anyone installed the Weathertech Deflectors and had them cause an issue with their automatic windows? That backs go up just fine, but the fronts will get up to the top where they make contact and it seems to cause just enough pressure to send the windows back down. After rolling down and up a few times they went up fine, but they seem to have the issue every now and then now. Any pointers other than get another brand?
  2. Mar 12, 2020 at 4:45 PM
    Devious6
    Devious6 Not your Average College President Emeritus
    Mark
    Northeast Pennsyltuckyvania
    2020 Army Green TRD Pro
    How long have you had them in place? Where are you located? (What's the temperature they are sitting in?). I had a similar problem at first with mine when I was installing the fronts - make sure you apply back pressure on them to pull them into the channel. You are also supposed let them sit for at least 2 hours without putting the windows up/down - and I'd leave them closed longer if the average temps are below 50. Mine work fine now.
  3. Mar 12, 2020 at 4:51 PM
    P-Dawg
    P-Dawg Factory 2 Seater
    Pete
    Chicago
    2020 SR AC MGM Utility Pckg.
    I've seen issues on numerous vehicles with the in Channel vent visors. Besides deforming the window seal they sometimes put extra stress on the motor and on occasion do enough to activate the down feature. Between this and the visual distortion (the curved part is out of view with external mounts) I only use the external mounts. I believe they have a good return policy, they are a great company.
    jwcox72 likes this.
  4. Mar 12, 2020 at 5:03 PM
    Tacomike18
    Tacomike18 Well-Known Member
    J
    I wasn’t sure about the in channel visors either when I first installed them but no problems yet.
    Devious6 likes this.
  5. Mar 12, 2020 at 5:37 PM
    TRDCLMB
    -Located in Monrovia CA,
    -in place 5 days
    -temps have been in to 60’s-70’s
    -did not wait to role up Windows
    -did use the tool to make sure the clips were set and deflectors pushed up and out
    -it broke a piece of the corner that most likely wasn’t seated when I rolled up the window so not sure on them accepting the return
    I figured after a few days with the windows up it would keep them where they should be, but no joy
  6. Mar 12, 2020 at 6:51 PM
    Devious6
    Mark
    Wow, sorry to hear that. Mine seated perfectly - just took a few times for the fronts to settle in.
    FishnTx likes this.
  7. Mar 12, 2020 at 7:01 PM
    TRDCLMB
    I emailed them to see if the have any tips because I followed the instructions and even watched the video to see if I was that dumb to mess something so simple up but I did it all to a T. I could careless about the cracked off piece since it’s somewhere you can’t see, but the rolling down issue is pretty annoying in the rain.
    Devious6[QUOTED] likes this.
  8. Mar 12, 2020 at 8:49 PM
    TRDCLMB
    This is what they sent me back so I’m going to give it a shot and see what happens when I get my truck back tomorrow. Hopefully it works and the post can save someone else some headache.
    BudFriendguy and Temutaco like this.
  9. Mar 12, 2020 at 9:11 PM
    JG358
    JG358 Well-Known Member
    Jake
    Colorado
    16 Tacoma TRD OR DCSB
    One of mine did that when I first installed them. I had it stuffed to far into the seal channel. Pulled it out and installed it a little farther out and havent had any issues since.
  10. Mar 12, 2020 at 10:09 PM
    TRDCLMB
    As in it was pushed up into the rubber to much, and you took it out and lightly put it in?
  11. Mar 13, 2020 at 5:01 AM
    JG358
    Jake
    Colorado
    When I installed the first time, the flat surface that goes into the window seal was all the way into the seal so the curved part of the window deflector was tight to the seal. It twisted the deflector causing contact with the window when it was rolling up. I reinstalled so their was a tiny reveal of the flat part that goes in the seal and everything worked fine.
  12. Mar 13, 2020 at 5:06 AM
    electricdgm
    electricdgm Well-Known Member
    Doug
    Florida
    2019 Cement TRD XSP Sport 4x4
    That is why I have the ones that mount above the windows. I live in Florida and with all the rain I didn't want any issues.
  13. Mar 13, 2020 at 5:10 AM
    JG358
    Jake
    Colorado
    I've used the out of channel before too but I've had enough of them come off or start flapping in the wind a bit when the 3m failed that I tried the in channel on my last two trucks. Other than a 30 second issue during install on my current truck, I've never had any problems with in channels.
  14. Mar 13, 2020 at 6:55 AM
    beergeek
    beergeek Well-Known Member
    RI
    2017 Black Tacoma Limited
    Same here.
    I’ve had Weathertech in-channels on 4-5 vehicles and never had an issue.
  15. Mar 13, 2020 at 6:58 AM
    Tocamo
    Tocamo .
    Ottawa
    Bug-out vehicle
    Temp problem, for a great product.
  16. Mar 13, 2020 at 7:01 AM
    M4sshole
    M4sshole Well-Known Member
    Evil
    Marshfield MA
    2019 Tacoma Limited
    Same here, no issues. The first few times up and down the window did back down, but once seated it hasn't happened again.
  17. Mar 13, 2020 at 7:25 AM
    mullett757
    mullett757 Well-Known Member
    Joe
    Virginia Beach
    2020 White TRD Sport DCLB
    There was a thread on the 4Runner forum i used to fix the same problem, I just can’t remember what it was exactly since it was 5 years ago lol
  18. Mar 13, 2020 at 7:31 AM
    mullett757
    Joe
    Virginia Beach
    https://www.rav4world.com/threads/a...ith-weathertech-side-window-deflectors.89865/
  19. Mar 13, 2020 at 8:11 AM
    Carny1
    Carny1 Well-Known Member
    2019 DCSB TRD OR
    When I installed mine, I cut some cardboard strips that I placed between the window and the deflector to provide better contact between the adhesive tape and the window seal. Let it that way a couple days, and never had an issue.
  20. Mar 13, 2020 at 9:06 AM
    Rick111
    Rick111 Well-Known Member
    Rick
    2019 DCSB TRD OR 6M
    ARE Z series cap w/Bedrug
