Weathertech bug deflector attachment problems.
Discussion in '1st Gen. Tacomas (1995-2004)' started by Genekauaii, Mar 21, 2019.
  1. Mar 21, 2019 at 5:28 AM
    Genekauaii
    Genekauaii [OP] 01Toyota Tacoma TRD 3.4 supercharger.
    G.M
    Utah
    2001 Toyota Tacoma T.R.D. Green
    Supercharger T.R.D.
    Hi there anyone else has installed a Weathertech bug deflector ? I just bought it online it's very well made . I'M having trouble installing it with the screw inserts it came with. I destroyed them . I was wondering if it's fine to remove the hood weather stripping under the hood to make this fit ? It's a 2001 I don't see how the plugs they provided will fit.Instructions say to put it between the weather stripping. I read several post on this problem. I want to use it I can get new screws and put it on without any weather stripping on the front hood. Will I have any issues with this ? Should I find new clips and screws to leave the stripping on ?
  2. Mar 21, 2019 at 5:48 AM
    Kleenax
    Kleenax Well-Known Member
    Ray
    Michigan
    2001 SR5 4WD V6 Auto - Mica Green
    New frame & stuff CBI bolt-on Sliders
    IMG_0366.jpg I have a WeatherTech Deflector on my 2001. I decided to install one after I found stone chips all along the front edge of the hood. Seems like it used push-in fasteners, or something like that.
    I will check when I can get out there. Took me about 10 min to install as I recall. LOVE IT! You could probably find install instructiions on their website.
    GQ7227 likes this.
  3. Mar 21, 2019 at 5:54 AM
    Kleenax
    Ray
    Michigan
    Yep; just checked the website. You have to remove the stock fasteners, and then use their included push-in fasteners to install. If you ruined the 1st - 4 that were included, I'm sure Advance Auto or AutoZone has them. Taken one with you so you can get the exact type of fastener. Attached are the install instructions.
  4. Mar 21, 2019 at 5:54 AM
    Genekauaii
    G.M
    Utah
    Supercharger T.R.D.
    I do have the instructions. The screws and insert plugs are too short to use with the weather stripping. I will take it to the shop I ordered it from and see what my options are as I ruined the 5 or 6 plastic inserts it came with. The instructions mentioned 2 rubber washers in the package I don't have those either. I put one on before but was a different brand and it just a stick on type .Your truck looks great !
  5. Mar 21, 2019 at 6:01 AM
    Genekauaii
    G.M
    Utah
    Supercharger T.R.D.
    Thankyou , it's the same instructions I sure could get them in to both the stripping and the bug deflector. I will go to autozone and try to get replacements or maybe they will have a better type mine just couldn't catch to lock in both . Thanks so much !
  6. Mar 21, 2019 at 6:05 AM
    Kleenax
    Ray
    Michigan
    Glad to help! Good luck. On those push-in pins, you can sometimes make installation of them easier by using something like a 3/8" or so socket (holding it in your hand or on an extension) so you can push the pin in with more force. Will save your fingers too!
  7. Mar 21, 2019 at 8:23 AM
    Tacomaman63
    Tacomaman63 Well-Known Member
    Stan
    2004 tacoma TRD 4x4
    step bars grille guard
    I just put regular metal screws in mine worked just fine
  8. Mar 23, 2019 at 7:56 AM
    Genekauaii
    G.M
    Utah
    Supercharger T.R.D.
    That crossed my mind too . I'll check out what they have. Thanks!
