Weatherstripping........2001 Tacoma
Discussion in '1st Gen. Tacomas (1995-2004)' started by csxrailfan, Jan 17, 2010.
  1. Jan 17, 2010 at 12:59 PM
    csxrailfan
    csxrailfan [OP] Active Member
    North Cackalacky
    2021 Toyota Tacoma DBL CAB TRD / GONE: 2002 Toyota Tacoma Access Cab TRD, 2011 Tundra TRD
    I have used the search function already and have not had any luck. Does anyone know of a place to purchase oem type weatherstripping for a 2001 Toyota Tacoma TRD Xtra Cab? My truck started out life in the desert and now 80,000 miles later it is suffering from dry compressed weatherstripping. In other words, when you close the doors or roll down the window the weatherstripping does not contact the surfaces that it should to seal it up. I would like to replace the entire setup around both dorrs and windows. Thanks in advance for any help.
  2. Jan 26, 2010 at 12:07 AM
    Cheesycook
    Cheesycook Geek with a gun
    Hermiston, OR
    01 4x4 DC Tacoma V6
    Bump..... I would like to know as well.
    Rachelsdaddy likes this.
  3. Jan 26, 2010 at 4:14 AM
    PharmerJon
    PharmerJon Member
    Jon
    Nebraska
    '03 Xtra Cab SR5 4x4, 2.7L 4cyl
    Deck-plate, black undercoating of pinch weld, clear corners and new tails, weathertech liners, billet grill w/ "TOYOTA" FJ emblem, OME all around, AAL, ashtray cb mount (Uniden), fender mount Wilson firestick antenna, Powerslot rotors, Hawk pads, Moto Metal 951 black, 265/75/R16 Duratrac's, Sockmonkey "SR5 w/ Mountains" bedside decal
    toyotapartscheap.com
    Part Number: 6231104020 - Door w strip Door w strip Right 2001 - 2004 $78.01
    Part Number: 6231204030 - Door w strip Door w strip Left 2001 - 2004 $78.01
    Part Number: 6233104010 - Rear door - Door w strip Door w strip Right 2001 - 2004 $60.77
    Part Number: 6233204010 - Rear door - Door w strip Door w strip Left 2001 - 2004 $60.77
  4. Jan 26, 2010 at 10:54 AM
    Cheesycook
    Hermiston, OR
    01 4x4 DC Tacoma V6
    Is that the door weatherstip or the window weatherstrip?
  5. Jan 26, 2010 at 10:56 AM
    Lentsnh
    Lentsnh Well-Known Member
    2007 Hummer H3 Tactical Edition
    None yet- Future: HIDs, Tinted tails, LED interior lights,
    I should replace meine soon as well. My doors are cracked or have slits in them and my windows dont even have contact.
  6. Jan 26, 2010 at 3:47 PM
    scocar
    scocar hypotenoper
    If you mean the weatherstrip across the bottom of the window (which the FSM calls "weatherstrip"), it cost about $30 for each side at the dealership. I just got a 2001 and they were totally shot, too: hard, bent out, alligatored.
    I did it in November and took pics (including part numbers), but I have just been too damn busy to post a write-up yet. It seems common, and is a really easy job and well worth it. But the FSM really shows no detail, and I think people get worried that they are going to break and bend stuff.
    Will try to post tonight after work.
  7. Feb 6, 2010 at 7:47 PM
    csxrailfan
    North Cackalacky
    Well I ordered the drivers side weatherstripping first. I got both the large stripping that goes all the way around the door and then the small drip guard that goes at the top of the doorframe. I went to the dealership and both of them together cost me $153. That being said.... man did I need them. Now when the door is closed and I pull up on the handle the door, for lack of better terms, pops open. They are really sealed up now. I will get the other side on my next paycheck. I used 3m super black weatherstripping adhesive to make sure they stay in place. Several weeks back I got the weatherstripping for the windows too. The strip that goes on the outside and wipes the window when you roll it up or down. Man mine were shot. I guess that is what I get for buying a desert (AZ.) truck. I does give me something to do on boring days though.
    PharmerJon Thanks for the links and the part numbers. I only wish I would have checked back here before I went to the dealer. To be honest though I only paid about $20 more for the drivers side. I guess it wasn't that bad. Thanks again for your reply.
  8. Feb 6, 2010 at 9:42 PM
    Cheesycook
    Hermiston, OR
    01 4x4 DC Tacoma V6
    How difficult is it to replace the drip rail?
  9. Feb 12, 2010 at 8:14 PM
    csxrailfan
    North Cackalacky
    Well, when I say drip rail I may be using the wrong term. There are two pieces of rubber weatherstripping around the door opening. The larger one goes all the way around the opening. The other, the one I called the drip rail, goes up at the very top of the cab above the larger one . It goes all the way across the top of the door opening down the a pillar and ends up just inside the edge of the fender. It was very easy to replace this piece. It was not glued on and it sort of snaps into place.
    *** On a different note......the damn thing still leaks. Guess I am gonna have to take the fender off and look there for the leak. If I put just a little more silicone on it I think I could probably float it across the river.***
  10. Feb 12, 2010 at 8:59 PM
    Worm
    Worm Well-Known Member
    Scott
    Southern Maryland
    I would like to see that, because mine have had about enough.
  11. Aug 22, 2011 at 9:29 PM
    pidro_el_pirata
    pidro_el_pirata Well-Known Member
    Thread revival. I have a 2000 2-door Xtra Cab taco and I think the weatherstripping is due for a replacement. Wind noise is getting worse, to the point that every time I get on the highway I feel like my windows/doors are cracked open. I was just going to get the generic weather stripping at an auto parts store but everyone here is talking about the OEM stuff... Is it worth it?
  12. Aug 22, 2011 at 10:30 PM
    scocar
    scocar hypotenoper
    Ithink this thread is now talking about 2 different weatherstrips. The "weatherstrip" as Toyota calls the part is the pice of trim at the bottom of the door window, and it is notorious for turning to shit.
    http://www.tacomaworld.com/forum/1st-gen-tacomas/154485-simple-how-fix-crappy-door-trim.html
    I think these other guys started talking about door seals, which sounds like your issue. Mine are good, so, sorry, can''t help.
  13. Aug 22, 2011 at 11:19 PM
    pidro_el_pirata
    I understand the difference between the two. What I want to replace is what you call the "door seal." Can I do that with generic stuff from the auto store?
  14. Dec 4, 2014 at 2:11 AM
    TashcomerTexas
    TashcomerTexas My truck is a whiner
    2003 TRD DC Supracharged
    Refuckingvive subd for later
  15. Dec 4, 2014 at 12:54 PM
    TashcomerTexas
    Unnecessary revive bump
  16. Aug 4, 2015 at 9:47 AM
    Houston
    Houston Well-Known Member
    Texas
    2015 MGM DCSB TRD Off-Road
    Anyone done this?
  17. Aug 4, 2015 at 11:19 AM
    TashcomerTexas
    Yes check out my build, I replaced the rear driver side door stripping. Thanks for the bump
  18. Aug 5, 2015 at 5:22 AM
    Houston
    Texas
    How hard was it to scrape the weather stripping and glue off before you installed the new stuff? I can't imagine it would be that hard to do, the whole process taking maybe 30 minutes?
  19. Aug 24, 2020 at 6:17 PM
    yotajoe99
    yotajoe99 Member
    Joel
    Ottawa, Ontario
    2001 TRD Off-Road Double Cab
    Fabtech lift
    Bump.....
    I've been looking for these things everywhere as mine are completely finished. I finally got a price from toyota for the front seals and they were 230$ CAD each. I have to replace all 4 of mine because the water keep pooling on the bottom and it almost seems likes the rubber has expanded over time (probably from 20 years of undercoating). I'm probably looking at almost a thousand bucks to replace all 4 but I was just wondering if you guys would know of any decent/more affordable aftermarket options.
  20. Aug 24, 2020 at 6:57 PM
    onakat
    onakat Well-Known Member
    Canada
    2000 indestructaco!
    wow, holy thread revival... but welcome to Tacoma World anyway :)
    Yes, the door weatherstrip/seals are expensive as frig, I know... but you can find rolls of automotive weatherstrip on ebay, Amazon, aliexpress. Just be careful about choosing the right one because there is many different shapes and sizes available
