Weatherproofing the Bed
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Anchovy, Aug 29, 2019.
  1. Aug 29, 2019 at 3:01 PM
    Anchovy
    Anchovy [OP] Rule #1: Never take me seriously
    TRD Ferguson
    2016 TRD Off Road (OVTuned)
    I would like some tips and tricks to weatherproof the bed of my truck before I get a cap put on it. I tried to search but either I didn’t find anything or I’m searching with the wrong words. Any links to other threads would be appreciated!
    Mikenewgun87 likes this.
  2. Aug 29, 2019 at 3:03 PM
    Anchovy
    TRD Ferguson
    I’m talking about sealing gaps so dust and water won’t ruin anything in the bed
  3. Aug 29, 2019 at 3:05 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Most cap mfg supply weather stripping to seal the cap.
  4. Aug 29, 2019 at 3:07 PM
    plurpimpin
    plurpimpin Well-Known Member
    PDX
    2010 TRD Off Road 4x4
    alittle weatherstripping around the tailgate is pretty much all you neeed
    boston23 and pudge151 like this.
  5. Aug 29, 2019 at 3:09 PM
    Anchovy
    TRD Ferguson
    Yes I understand that, I’m talking about the gaps between bed rails, gaps by the tailgate, the gaps in the front corners of the bed, etc. I keep reading that people do that but they don’t say what the use RTV? Silicone? Bubblegum? Or how they get to certain spots
    SilverBulletII likes this.
  6. Aug 29, 2019 at 7:15 PM
    Go Fish
    Go Fish Well-Known Member
    2022 SR5 4x4 DCLB
    Yes, the gaps at the front corners of the bed need to be sealed. My canopy dealer used some black putty like stuff that I believe is known as dum dum. I have seen where people have used black silicone caulking. You should remove the front bed rail and seal under it as well.
  7. Aug 29, 2019 at 7:23 PM
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    I believe I’ve seen people use caulking, but not 100% sure. I’m interested as well.
  8. Aug 29, 2019 at 8:02 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    They make an automotive caulk...3M... you can get it at NAPA. It works.
  9. Aug 29, 2019 at 8:18 PM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    This has worked great so far:
    https://www.amazon.com/dp/B00R8KBV9Y
    It comes with enough to do the sides an extra time.
  10. Aug 29, 2019 at 8:27 PM
    Pyrotech
    Pyrotech Well-Known Member
    Dum dum.. guessing you work in the electrical field...
    We use to seal.conduit and risers at work
  11. Aug 29, 2019 at 10:01 PM
    Mtn Mike
    Mtn Mike Well-Known Member
    Spokane, WA
    2017 TRD OR AC
    Here's what I did, in order of importance/priority. There are separate threads on TW describing each step.
    1) seal the huge gaps at the top-front of the bed, where the side rails meets the front rail. Use putty (black putty or RV style putty tape)
    2) seal underneath the black plastic side bedrail caps. Use silicon sealer or something better (I used Geocel Proflex) The caps need to be removed. The sealer is applied to the metal side.
    3) seal the gaps in the plastic bed near the tailgate. I used RV putty tape.
    4) use weatherstripping to seal the tailgate itself (there are kits you can buy for $20-30)
    5) hope your canopy doesn't leak.
  12. Aug 29, 2019 at 10:17 PM
    Bunk Moreland
    Bunk Moreland Well-Known Member
    Bunk
    It's complicated.
  13. Aug 29, 2019 at 10:35 PM
    MtnFisher
    MtnFisher Well-Known Member
    ZeroDrift
    2019 Tacoma TRD ACLB V6 MT
    Currently running Goodyear DuraTracs with "ghetto" wheels
    My dealer has used GE Silicone in black for years, once cured its pretty durable. Take the front bed rail off, lay a bead and reinstall. Seal the corners too.
    https://www.homedepot.com/p/GE-GE-S...ck}:rt+dln:{583613}+qu:{ge+silicone+black}:qu
    Da Boogie Man likes this.
  14. Aug 29, 2019 at 10:41 PM
    Desolate
    Desolate Well-Known Member
    tonered[QUOTED] likes this.
  15. Aug 29, 2019 at 11:25 PM
    Navigator1
    Navigator1 Assistant to the Regional Manager
    Spokane WA
    18 TRDORDCLBCEMENT
    Don’t forget the drain holes in the bed storage boxes. Mine are always getting dirt in them.
  16. Aug 30, 2019 at 5:11 AM
    Hemlocktherm78
    Hemlocktherm78 Well-Known Member
  17. Aug 30, 2019 at 6:13 AM
    Anchovy
    TRD Ferguson
    Bunk Moreland and Pyrotech like this.
  18. Aug 30, 2019 at 6:28 AM
    Bob Laublaw
    Bob Laublaw Well-Known Member
    This is my experience. The overwhelming majority of dust and water come in between the tailgate and bed on the sides of the truck. You can see daylight between them.
  19. Aug 30, 2019 at 8:05 AM
    plurpimpin
    PDX
    Damn didn’t realize 3rd gens had all these gaps. Didn’t have to do all that on my 2nd gen.
  20. Aug 30, 2019 at 8:06 AM
    tonered
    tonered bartheloni
    tony
    Lynnwood, WA
    ?? The 2nd Gen is nearly the same except your header rail is different, I believe.
