Waterspot removal
Discussion in 'Detailing' started by pinktaco808, May 8, 2021.
  1. May 8, 2021 at 12:21 PM
    pinktaco808
    pinktaco808 [OP] Hot Steppa
    .. what are the best ways to remove waterspots on glass and paint???
  2. May 8, 2021 at 12:28 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    On the glass you can use 50/50 vinegar/water and some 0000 steel wool will do the trick. Chemical guys makes a good one for the paint .
    pinktaco808[OP] likes this.
  3. May 8, 2021 at 12:34 PM
    verlaryder
    verlaryder Well-Known Member
  4. May 8, 2021 at 12:35 PM
    PhenixFord
    PhenixFord Well-Known Member
    Randy
    Arkansas
    2019 MGM SR5 4WD DCSB
    Clay Bar works great. But get that elbow greased up and ready first.
  5. May 8, 2021 at 12:36 PM
    Evostaco
    Evostaco Jack of some of the trades, master of maybe 2
    Nebraska
    2021 tacoma offroad, mt, superwhite
    On glass I've used spot not. Be careful though as it's an acid.
  6. May 8, 2021 at 2:45 PM
    Gus
    Gus Well-Known Member
    Wayne, Pa.
    2020 Access Cab SR Utility Package Barcelona Red
    Rear sliding window, intermittent wiper switch, center console tray, glove box organizer shelf, WeatherTech front mats and mud flaps, 3D MaxSpider behind-the-front-seats mat, bed lights, MESO climate control rings, XPEL tailgate protection, Desertdoesit.com seat jackers, RAV4 radio knobs, glove box letters.
  7. May 8, 2021 at 2:51 PM
    JackSparrah
    JackSparrah Well-Known Member
    1999 SR5
    For paint a good old fashioned clay bar does the trick. Just be sure to reapply wax or something because the clay strips off most protective wipe on things like wax or ceramic
  8. May 8, 2021 at 5:31 PM
    rotarylift
    rotarylift New Member
    If you're in Da 808 I recommend dropping by Don Quixote and picking up a bottle from the auto section of MX7 glass water spot remover and the MX7 for paint. Its made in Waipahu so you know its designed for the water spots out here. I just recommend washing your car before and after applying MX7. The window spot remover is really gritty and the paint one is acidic so just make sure you follow the instructions on the bottle. I use it on my truck and it works great.
  9. Jun 20, 2021 at 8:17 PM
    El Cucuy
    El Cucuy Well-Known Member
    Paul
    2020 TRD PRO Super White "CHINGAO"
    stockish for now
    the best stuff I have ever used, easy to apply with little pressure and I am probably the pickiest person ever in regards to water spots on windows. Can purchase on Amazon too61wtjPYp6XL._AC_SL1500_.jpg
  10. Jun 21, 2021 at 12:25 AM
    verlaryder
  11. Jun 21, 2021 at 8:23 AM
    El Cucuy
    Paul
    stockish for now
    I realize that however I have used it for multiple cars that had bad water spots from sprinkler systems that were tough and baked on. It worked like a charm, have not used it on tile, bathrooms, paint, etc. I used it on windshields, side windows and even the side mirrors with zero issues. I would recommend it as I will use it in the event I get spots again. I also followed it up with Rainx
  12. Jul 16, 2021 at 3:57 AM
    Rainman443
    Rainman443 Well-Known Member
    A Big Island
    2021 TRD OR
    50/50 water Vinegar is always a great choice for glass.
    For paint, it's more complicated if you want to do it right. Ideally, you start with the least aggressive and work your way up to the most aggressive on a test spot so you're not taking off more paint than you need to. If you still see it after a wash, one option is to clay bar it (not an option if you're coated). Just be aware you'll want to follow up with a polish if you don't like the microscratches it'll very likely leave. The next step up (will work on coated cars) is to use a waterspot remover like kamikazee or optimum made (chemical guys makes one too). If that doesn't work, you're probably too late and it etched into your paint. You'll now need to machine polish it. If that doesn't work, you'll need to compound it.
    If you're lazy or coated, skip straight to the waterspot remover.
  13. Sep 3, 2021 at 4:31 PM
    mose1117
    mose1117 Well-Known Member
    Sacramento,CA
    2015 DCSB TRD SPORT
    KLASSE All in One....best thing on the market....Works on glass, paint and non-porous (smooth) plastic. Makes the plastic look better than new!
