Waterproofing Roof After Roof Rack Removal
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Road_Warrior, Feb 3, 2022.
  1. Feb 3, 2022 at 12:21 PM
    Road_Warrior
    Road_Warrior [OP] There is nothing on my horizon except everything
    East Coast
    2021 Black SR5 4x4
    The roof of my 2021 SR5 has been leaking since I removed my Prinsu roof rack. I’ve filled the pre-drilled holes with rubber push screws and sealed those with commercial grade silicon.
    Unfortunately no matter what I try, the headliner above the A-pillars is still soaked and drips onto me and the passenger when it’s raining. I never had this issue before I removed the roof rack so I have no reason to believe there is any issue causing this other than the missing pieces of rubber on the roof.
    At this point I am going to just replace the entire weather stripping on both sides.
    I’ve located the parts and part numbers for the left and right side weather stripping.
    My question(s):
    Do I need anything else? Are there any type of screws or plugs that are installed in the pre-drilled holes from the factory that I will need to also order?
    I had a professional shop install the Prinsu and they threw away literally everything besides the roof rack itself when they were done, so I have no idea what (if anything) was under the weatherstripping before the roof rack was mounted.
    Thanks in advance.
    Ngneer likes this.
  2. Feb 3, 2022 at 11:55 PM
    bursthead
    bursthead Well-Known Member
    2019 Tacoma TRD Pro
    I would use a piece of vinyl and silicone it down and then cover the top of it with more silicone. From the factory there is a piece of tape they use to cover the holes. You want to try and replicate. The roof moulding isn’t meant to create a waterproof seal.
    Lt. Dangle and Road_Warrior[OP] like this.
  3. Feb 4, 2022 at 3:01 AM
    VaToy
    VaToy Life Long Member
    Parts Unknown
    2018 TRD DCLB Sport 4x4 Silver Sky
    Bilsteins 5100s on the top setting, 4runner Gray TRD Pro Sema wheels, 285/70/17 Toyo AT3s, Sumo Bump stops, TRD exhaust, ECGS Clamshell bushing, 1/4 shim for the lean and one inch rear block, OEM Pro grill and garnish OEM TRD Skid plate, TRD CAI, Demon Brackets, Rigid Industries Pro fog lights, OEM Trail Rails sidebars, Diode Dynamics LED SL1 high and low beam lights, OEM Roof racks, Clazzio leather heated seats, Remote Start, TRD Pro shift knob, tinted windows, Rockford Fosgate 4 channel amp for the headunit and sub and amp combo, OEM Puddle lights, OEM tailgate lock, OEM bed mat, LED interior lights, OEM blackout kit for letters, JLT catch can, upgraded 27F toyota True Start battery, Vleds led tail light kit with Pro tail lights, OEM Rave4 side mirrors with convex spotters,just to name a few mods.
    Tyr the flex seal tape. Cut it to size. That is some strong stuff and will fix your issue. Make sure you didnt develope a 3rd brakelight leak. Good luck!
    Ngneer, averagejp, Mark77 and 2 others like this.
  4. Feb 4, 2022 at 5:25 AM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Thank you guys! I’ll just dig out all the silicon I’ve put down and do what you both suggested.
    and yeah, I’ve read about the third brake light leak and I’m really hoping that’s not the issue.
    Ngneer likes this.
  5. Feb 4, 2022 at 5:46 AM
    dually
    dually Low and slow
    Interstate underpass
    '16 Inferno SR5 DCLB
  6. Feb 4, 2022 at 5:59 AM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    That looks like a great idea.
    I know the rubber weather stripping itself isn’t supposed to be waterproof, but it is safe to say that any water that enters the pre-drilled holes would leak into the cab?
    If that’s the case, it blows my mind that Toyota would only use a small piece of tape to cover each hole under the weather stripping.
  7. Feb 4, 2022 at 6:02 AM
    Sig45
    Sig45 Well-Known Member
    Mark
    Maine
    In addition to above suggestions, would it be worthwhile adding some of these allen head screws to the existing threaded holes? Maybe add some thread sealer?
    SR-71A likes this.
  8. Feb 4, 2022 at 6:04 AM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    The above suggestions are spot on, but to add to these, prep... clean off the old silicon. Then clean the area with rubbing alcohol with a lint free cloth before applying anything. If it isn't perfectly clean, it won't seal.
  9. Feb 4, 2022 at 6:04 AM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Thanks for the suggestion! I actually put a solid plastic thumb screw into each hole and then sealed over top of it with silicon.
    That’s why I can’t figure out how the water is getting in…the holes are filled with plastic screws and then I sealed each one in with silicon. So it should be totally sealed.
    Sig45[QUOTED] likes this.
  10. Feb 4, 2022 at 6:09 AM
    Sig45
    Mark
    Maine
  11. Feb 4, 2022 at 6:10 AM
    dually
    dually Low and slow
    The suggestion for the set screws is a great idea. Placing silicone on the threads, screwing them in, placing a layer of butyl tape the length of the track and then installing the weather strip would probably be a great solution.
    Road_Warrior[OP] and Sig45 like this.
  12. Feb 4, 2022 at 6:15 AM
    Sig45
    Mark
    Maine
    Maybe redo it and add some silicone (good marine grade) into the hole before putting in the thumb screws.
  13. Feb 4, 2022 at 6:23 AM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Thank you guys all for the suggestions, you’re all life savers!
    On a somewhat related note, has anyone experienced the third brake light leak? If so, where does the water enter the cab?
    I’m going to have to start looking at that as a possible culprit if this fix doesn’t work.
  14. Feb 4, 2022 at 6:24 AM
    Mark77
    Mark77 Well-Known Member
    Mark
    2021 White TRD Off-road
    Nothing yet
    This. Ive used the gorrilla glue brand for some things with my homes sump pump and it works brilliantly.
    Road_Warrior[OP] likes this.
  15. Feb 4, 2022 at 6:24 AM
    dually
    dually Low and slow
    Yes, Toyota just sent out a warranty repair mailer for that issue. However, the years affected are 16-19. Very surprising you're having that problem on a '21
  16. Feb 4, 2022 at 6:27 AM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    I’ve checked the VIN already and it says I don’t have any recalls. At this point I’m still fairly positive it’s coming in through one of the spots where the roof rack used to be mounted.
    I’m just curious if the water entry points for the 3rd brake light leak match up to what I’m experiencing.
    Ngneer likes this.
  17. Feb 8, 2022 at 9:32 AM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    Mission accomplished. Thank you everyone for your help and suggestions. Now I just have to wait for rain and see if it works.
    Pics below are in order from start to finish. These are also good for anyone wondering what’s actually under the weather stripping on the roof.
    My half assed original attempt at silicon:
    Stripped out all the silicon down to the bare holes. Cleaned them out with Q-tips and dried them with a hair dryer.
    New commercial-grade silicon applied directly into the holes:
    Gorilla-Glue brand weatherproof tape on top of silicon to seal it all in:
    Ngneer, Sig45 and Mark77 like this.
  18. Feb 8, 2022 at 10:54 AM
    Sig45
    Mark
    Maine
    Didn't realize there was such a large opening around the holes. Might be too late, but I'd apply that tape over that whole rectangular area.
  19. Feb 8, 2022 at 11:05 AM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    yeah, why didn't you put one large piece over the whole area?
    Clean up the old silicone. It's really bothering me...
    Ngneer, 44-16 Taco, got4wd and 4 others like this.
  20. Feb 8, 2022 at 11:06 AM
    Road_Warrior
    East Coast
    2021 Black SR5 4x4
    That’s a really good point. I actually considered doing that, but my thought process was that the lip between the painted and unpainted part could allow some water to get under the tape.
    I would hope that wouldn’t be an issue since the silicon is fully sealing the hole underneath but I figure better safe than sorry.
