Waterproof electrical connectors
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Rujack, Jun 25, 2019.
  1. Jun 25, 2019 at 4:52 PM
    Rujack
    Rujack [OP] Stop Global Whining
    2016 Tacoma TRD Off Road 6 speed manual
  2. Jun 25, 2019 at 5:18 PM
    mutely
    mutely Well-Known Member
    TRD Pro in metallic primer
    Those work on 6 to 10 gauge from the description. Last time I checked 8 is in between 6 and 10:thumbsup:
    Don’t mean to be an ass, but you do know AWG stands for American Wire Gauge, or simply gauge for short.
  3. Jun 25, 2019 at 5:21 PM
    inwood customs
    inwood customs Roaming potato
    Dave
    2006 v6 potato bugTuRD
    K&n, flowmaster, plastidip, chipped, hids, daves
  4. Jun 25, 2019 at 6:13 PM
    cactushead
    cactushead Well-Known Member
    San Diego
    2017 MGM DCSB 4x4 TRDOR
    Front hitch, 5100's, 885's, Snugtop XV, Slimline II, Sumos, bed platform, AAL, interior LED lights in cab and bed, exterior camp/backup LED's, Rigid DOT Fogs and D2 Pro Spots, Mega Ultra +130 bulbs, heavy-duty fog light, spot light, and low beam wiring harness, Weathertech mats, Re-routed dif breather and A/C drip line, dash cam, front and side cameras, anytime rear camera and nav, Blue Seas fused bus bars to cab and bed, heavy-duty bus bar w/Anderson quick disconnects under the hood for powering winch, solar, air compressor, and other accessories.
    These Anderson SB50 type of connectors (6-10 ga) are not sealed/waterproof. You would need to buy a waterproof boot to achieve an IP64 rating. [​IMG]
    Gunshot-6A, Rujack[OP] and Boghog1 like this.
  5. Jun 25, 2019 at 6:30 PM
    Rujack
    Yea but I need waterproof.
  6. Jun 25, 2019 at 6:31 PM
    Rujack
    That should do it thank you
  7. Jun 25, 2019 at 6:34 PM
    golfindia
    golfindia Well-Known Member
    Yes.
    pickup truck
    Water "proof" is a myth. Unless you're in a submarine.
    Just let water get in and get out and you won't have any problems.
    Trapping water in a connector is the biggest problem with sealing the hell out of stuff.
  8. Jun 25, 2019 at 6:38 PM
    BigWhiteTRD
    BigWhiteTRD Official thread killer (only crickets remain)
    Ted
    Treasure/Space Coast Florida
    2017 AC TRD OR Auto 4wd, 2012 AC SR5 4.0 MT 4wd
    You wont find too many quick disconnect connectors at 8 awg. Really bolt on terminal lugs into junction blocks are the most common when you get big. With a properly crimped wire, and properly torqued lug, the joint is basically sealed. The clamp force is enough to form a gas tight seal and prevents water or anything getting into the joint. If you want to keep it out of saltwater, then put the wire thru an enviromental bulkhead fitting into a watertight box. https://www.amazon.com/Hilitchi-Plastic-Waterproof-Adjustable-3-5-13mm/dp/B01MDTUIIA/
    Alternatively
    There are mil spec connectors circular connectors, if you are really interested. They are significantly expensive, and you have to get the exact P/Ns to mate. Digikey has a decent variety of the more affordable ones. I will look some up, prefer crimp or solder?
    Rujack[QUOTED][OP] likes this.
  9. Jun 25, 2019 at 6:46 PM
    Rujack
    I'm just looking to wire up my fridge, which will be in my bed, semi covered. These connectors were just the first idea that came to mind. I'd really rather have the other half of the connector permanently mounted to the rack or bed instead of a plug on a wire flopping around. So far I see some other possibilities but nothing I'm sold on.
  10. Jun 25, 2019 at 6:48 PM
    golfindia
    Yes.
    pickup truck
    My fridge draws about 5a max. 10 or 12g is good.
  11. Jun 25, 2019 at 6:53 PM
    Rujack
    Good catch. I’m using 8 awg (edit: 6 awg) to run a 40 amp circuit to a bed mounted sub box, to which the fridge connection will be wired. Forgot about that. I’ll go 10 gauge for the fridge wiring.
  12. Jun 25, 2019 at 7:02 PM
    Rujack
    ***Ah! Screwed up! I’m using 6 gauge for the circuit. Original post has been edited.***
    Interesting. Crimp would be better for me, thanks. But as golfindia pointed out, I confused myself: the 6 awg wire (from Skycraft, per your recommendation) will be what I’m using to run the circuit to the sub box in the bed. What I need is some type of connection to plug the fridge into the circuit. I want the option of easy disconnect when I pull the fridge out.
  13. Jun 25, 2019 at 7:04 PM
    JoeCOVA
    JoeCOVA Well-Known Member
    Joe
    Colorado Springs
    Check out Delphi Weatherpacks
    Gunshot-6A and shakerhood like this.
  14. Jun 25, 2019 at 9:14 PM
    cactushead
    San Diego
    You should be able to mount these to your bed/rack. I've seen forklifts with the largest size of this style of connectors (SB350) mounted on the side of the lift. If you still wanted to use the hoods, you would have to drill holes through them to match the holes in the connectors.
    The picture above is an SB50, the smallest of the SB series of connectors. It is rated to 50A and 6 - 10 ga wire. The body of the terminals are solid, so they are not really made for crimping. The best way to attach the wire is to use a bottle torch and melt solder into the wire cavity. Insert the wire into the terminal and hold it until the solder hardens. Just make sure the terminals are positioned correctly before soldering.
  15. Jun 26, 2019 at 6:36 AM
    BigWhiteTRD
    Ted
    So, if I am understanding, you probably dont actually want a connection on the 6awg high power wire going into your sub panel.
    I am assuming you want to hard wire the heavy wire into a sub box, with fuses (no quick connect). Then from the sub box you will run a short run with (possibly) smaller wires to the fridge with a quick connector of some kind.
    Reason you can go smaller, is shorter run to the fridge (I assume)
    How exposed to damage will this connector be and how concerned with damage and cosmetics? The Anderson connectors are pretty good, but not water proof, but I doubt you really need waterproof up in the bed. The Anderson are also relatively standardized, depending on the size. (Popular with hams and amateur radio guys on some sizes)
    If you really want the 'high class', I would suggest metal mil circular connectors, or their lower cost but similar plastic alternatives. But they are expensive, and essentially impossible to find a replacement in a pinch. (Use these at work and at home on aircraft components that have them, but too expensive for my typical usage myself except some of the cheapest ones.) I always go for solder on these, due to the criticality of the crimp on these connectors. They make huge numbers of variations on these, partially to make it impossible to hook the wrong item to the wrong wire, so interchangability is kind of precluded...
    Some examples from digikey, there are literally about 10,000 options... NOTE, do not pull the trigger on these until 100% verify I gave you mating p/n. I have not double checked these, just intended to give you an idea of the options ...
    Plastic housing, crimping pins, up to 10 awg, 30 amp
    https://www.digikey.com/product-detail/en/conec/17-400153/626-1863-ND/6053938
    https://www.digikey.com/product-detail/en/conec/17-400123/626-1860-ND/6053935
    https://www.digikey.com/product-detail/en/conec/17-400260/626-1870-ND/6053945
    Mil spec metal, solder,
    https://www.digikey.com/product-det...tions/MS3102R10SL-4P/MS3102R10SL-4P-ND/378625
    https://www.digikey.com/product-det...ons/MS3106F-10SL-4S/MS3106F-10SL-4S-ND/378647
    https://www.digikey.com/product-det...trial-operations/97-60-10/97-60-10-ND/3777749
  16. Jun 26, 2019 at 7:04 AM
    Rujack
    ^ yep
    Yea, I was using “waterproof” pretty loosely to see what recommendations would come back. Mainly just looking for durability, UV stable, corrosion resistant, dust / dirt etc...
    Moderate risk of damage, but I’ll run the wire through some kind of conduit - probably the irrigation tubing we talked about in the other thread, maybe PVC pipe. I’m generally a fan of higher quality within cost reason, so depending on how expensive “high-class” is, I may go for the more expensive connectors and consider carrying a spare.
    For whatever reason the links didn’t show up in your post but I see they carried over into the quotes. Looking now...
  17. Jun 26, 2019 at 7:25 AM
    BigWhiteTRD
    Ted
    Refresh and they should show.
    Keep in mind there are just a multitude of similar, but I guessed you were looking for something like this, with a bulkhead/panel mount connector on one side.
  18. Jun 26, 2019 at 7:38 AM
    Big tall dave
    Big tall dave Well-Known Member
    Elora, Ontario, Canada
    2018 Tacoma TRD OR DCLB
    I’ve used those cheap, forklift-style, non-waterproof connectors on my work trucks for years. I just packed the wire end and connector end with a generous amount of silicone lube (not caulking) Never had a problem with water or rust.
  19. Jun 29, 2019 at 8:49 PM
    Rujack
  20. Jun 29, 2019 at 9:06 PM
    Itchyfeet
    Itchyfeet Well-Known Member
    If you go this route, buy the good crimpers if you plan on doing lots of them. The good ones are a $100 vs. $25. The inexpensive ones will work, but are a bit aggravating.
