Water tank/shower for camping trips
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Hennebury, Oct 25, 2018.
  1. Oct 25, 2018 at 2:49 PM
    Hennebury
    Hennebury [OP] Active Member
    Nick
    2012 Tacoma TRD Overlander
    Too Much
    44853561_10156880527117422_3005411890886082560_n.jpg 43639066_10156880527212422_8580060105704210432_n.jpg 43712440_10156880527127422_5750577943642374144_n.jpg
    Made a quick little water holder for my Death Valley trip this weekend.... should hold 3.5 gallons give or take a few drops..... its abs so I'm not gonna pressurize it.... ill just let the sun heating it up and gravity do its thing..... lets see some pics of how you haul your water on wheeling camping trips
    Manfred, stickyTaco, Biscuits and 7 others like this.
  2. Oct 25, 2018 at 3:22 PM
    christian06
    christian06 Well-Known Member
    Cali
    Stockish 06 sport prerunner
    Grille, floor mats, navi, heated seats, bed cover, fj wheels, custom door cloth.
    Nice, I have an on board shower that I e made with a heat exchanger for hot water, I have 2 five gallon buckets I take full of water, or i can drop a hose to a water source, or hook a hose up to it, it's really nice to have a shower when camping
    Manfred and I married my tacoma like this.
  3. Oct 25, 2018 at 9:00 PM
    MolonLabeTaco
    MolonLabeTaco Well-Known Member
    Dude
    N. Texas
    '12 DC 4x4 OR
    I like where this is going. I built an off-road trailer that I plan on putting a 24g tank in, a 2.5gpm 12V pump and a large deep cycle battery.
    I married my tacoma likes this.
  4. Oct 25, 2018 at 9:03 PM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Looks similar.
    Also have a SWC that can be pressurized.
  5. Oct 25, 2018 at 9:11 PM
    13yota
    13yota Well-Known Member
    Colorado
    2013 2.7 single cab 4x4
    Nice! How are you attaching the pvc to the rack? I just ordered all the parts for my water setup in the camper, then going to move to the shower
  6. Oct 26, 2018 at 4:58 AM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    Can’t you use PVC that’s rated for pressure and pressurize it?
  7. Oct 31, 2018 at 2:49 PM
    rkl17
    rkl17 Well-Known Member
    Utah
    2018 TRD Sport
    I'm curious about this too. I like taking extra water when I go camping. Currently i just take a 6 gallon water container and throw it in the bed. Wonder if there's any water containers out there that are made specifically to fit the Tacoma beds. Like in front of or behind the wheel well cut outs.
    Geronimo1111 likes this.
  8. Nov 1, 2018 at 6:18 AM
    Hennebury
    Nick
    Too Much
    I attached mine with two hose clamps it worked great.... it was nice having the water to wash stuff with on our last trip... theres a company called road shower but there about $500. They are aluminum tanks and you can pressurize it and I think they are claiming get up to a 4 min shower out of it
  9. Nov 1, 2018 at 6:27 AM
    christian06
    Cali
    I get 4.5 min out of my 5 gallon bucket
    Skyway and MolonLabeTaco like this.
  10. Nov 1, 2018 at 9:58 AM
    Darkgoatracer
    Darkgoatracer Well-Known Member
    Nick
    Northern VA
    2012 trd sport tacoma
    Stock
    Here my setup. Pressurized with the on board air.
  11. Nov 1, 2018 at 10:06 AM
    Hennebury
    Nick
    Too Much
    How did you attach the pressure relief valve.... I got some tank threaded bungs for the hose bib that you drill and have a rubber washer and nut on and internal npt theard but nothing close to small enough for a prv there only like 1/4” smallest Bung I found was 1/2” and needed bushing down
  12. Nov 1, 2018 at 10:11 AM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    Pipe tape and threaded it in with thread sealant. It a 50 psi relief and i haven't had any issues. The schrader valve was a heavy duty one with a nut and rubber washers thay was through bolted.
    Biscuits and I married my tacoma like this.
  13. Nov 1, 2018 at 10:13 AM
    Hennebury
    Nick
    Too Much
    So you just taped the pipe itself ... I thought about that but there just didn’t seem like a lot of meat for it to stay in there
  14. Nov 1, 2018 at 10:16 AM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    Yep. My plan was to put a nut on the back, but the threaded part of the pressure relief was the same length as the pipe wall was thick.
  15. Nov 1, 2018 at 11:40 AM
    MolonLabeTaco
    Dude
    N. Texas
    '12 DC 4x4 OR
    Can you share links to the schrader valve, pressure relief valve, filling coupler?
  16. Nov 1, 2018 at 11:44 AM
    BassAckwards
    2009 Tacoma AWD Turbo 2TR-FE
    Whats the capacity like on this? I dig it!
  17. Nov 1, 2018 at 11:47 AM
    Hennebury
    Nick
    Too Much
    mine just being straight is 5' and its about 3.5 gallons give or take..... id say his is about 15ish gallons or there about
    BassAckwards[QUOTED] likes this.
  18. Nov 1, 2018 at 11:49 AM
    Woofer2609
    Woofer2609 Getting better all the time.
    Clancy
    Vancouver Canada
    2009 AC 4X4 2.7 5M
    My buddy has a setup that runs 1/4" or so copper pipe around the exhaust manifold. This is fed by a pressurized tank similar to what is seen here. One end of the copper has a quick release fixture for intake, the other for attaching a shower head. Works really well.
    BassAckwards likes this.
  19. Nov 1, 2018 at 11:50 AM
    BassAckwards
    Nice, 3.5 seems like plenty but if you ever go on extended camping trips, that extra capacity might come in handy!
  20. Nov 1, 2018 at 12:32 PM
    Darkgoatracer
    Nick
    Northern VA
    Stock
    Yeah give me a few.
    Around 13 gallons i think.
