Water pump timing belt kits
Discussion in '1st Gen. Tacomas (1995-2004)' started by Zerofear66, Apr 17, 2019.
  1. Apr 17, 2019 at 3:28 PM
    Zerofear66
    Zerofear66 [OP] Well-Known Member
    2022 TRD Off Road Lunar Rock, 2014 Tundra Crew Max TRD 5.7L
    What are the best manufacturers?
    I was looking at this kit.
    Mitsuboshi timing belt, an Aisin water pump w/ gaskets, a Koyo tensioner.
    Thoughts?
    CS_AR likes this.
  2. Apr 17, 2019 at 3:30 PM
    thenodnarb
    thenodnarb Well-Known Member
    California
    2001 TRD 4x4 379k and counting
    that's the one to get. make sure it's a reputable seller. apparently knock offs exist. I've bought things on Amazon that were advertised as oem that were not.
    CS_AR likes this.
  3. Apr 17, 2019 at 3:34 PM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    search around this forum, there's an ebay seller in one of the timing belt threads that sells a whole kit, all OEM parts for around $250 iirc...
    It's what I got. I'd post the link to ebay myself, but I don't have it bookmarked...
    CS_AR likes this.
  4. Apr 17, 2019 at 3:43 PM
    Zerofear66
    CS_AR likes this.
  5. Apr 17, 2019 at 3:44 PM
    underaroof
    underaroof ember
    Eastern Sierra
    2004 Xtracab 4x4 V6 TRD
    I recently installed this one from AirCabinMan:
    15 Piece 3.4L engine TIMING BELT KIT WATER PUMP Genuine OE Manufacture Parts
    There is other stuff you may want to replace while you're in there, depending on what's been done before. My timing belt and everything was original at 196k, so I replaced just about everything I could, including fan bracket (Aisin), crank pulley bolt, A/C belt idler pulley, and radiator hoses.
    SJTaco4x4, OneWheelPeel and CS_AR like this.
  6. Apr 17, 2019 at 3:46 PM
    ahkouchi
    ahkouchi Well-Known Member
    Andrew
    Big Island Hawaii
    2016 Magnetic Gray Metallic Tacoma
    Front Elka 2.5 non resi with 650lb spring Rear Serviceable 5160's with AAL 265/75/r16 BFG KO2
    I used this company for my moms 1st gen. everything is OEM equivalent and comes with everything you need
    https://www.timingbeltkit.com/
    also was the best price i found for OEM
    CS_AR likes this.
  7. Apr 17, 2019 at 3:49 PM
    Zerofear66
    Awesome!
    Thank you!
    CS_AR likes this.
  8. Apr 17, 2019 at 4:05 PM
    Kwikvette
    Fresno County
    4 run, 2 don't
    Noticed that there's a kit for vehicles equipped with an oil cooler and without; wonder if mine has one or not.
    Going to be replacing my radiator soon (upper plastic has a tiny crack), so I may as well do everything else.
    CS_AR likes this.
  9. Apr 17, 2019 at 4:16 PM
    jbrandt
    Justin
    CS_AR likes this.
  10. Apr 17, 2019 at 4:17 PM
    ahkouchi
    Andrew
    Big Island Hawaii
    if you call them (https://www.timingbeltkit.com/)
    and provide them with your vin, they can tell you if it is oil cooler or not
    Kwikvette[QUOTED] and CS_AR like this.
  11. Apr 17, 2019 at 4:22 PM
    BarnBoy
    BarnBoy Well-Known Member
    96 Tacoma 2wd
    I put one of those kits (Aisin) with mitsuboshi belt, blah blah blah on our '05 Sienna. Still running strong 30k later. High quality components, that is the only kit I would use on my vehicle.
  12. Apr 17, 2019 at 4:30 PM
    ahkouchi
    Andrew
    Big Island Hawaii
    Or u can email vin and get the right kit
  13. Apr 19, 2019 at 2:34 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    If I can make a suggestion. Timing belt job is an excellent time to replace all those tiny hoses that goe to the engine oil heat exchanger. I'm still kicking myself for not changing them. Same with the fan mount, that should be changed sometime.
    My A/C belt tensioner bearing was pretty gone as well but fortunately, I had the Amazon $8 replacement bearing on hand.
  14. Apr 19, 2019 at 4:00 PM
    SJTaco4x4
    SJTaco4x4 Active Member
    Charlie
    San Jose, California
    2004 DC 4x4 TRD
    I also used this kit. Its working out great.
    Edit: Installed at ~194k. It’s been in for ~12k. I also replaced the crank pulley bolt.
  15. Apr 19, 2019 at 5:07 PM
    thenodnarb
    California
    what's the 8 dollar one? mine was 13. just put it on today.
