Water pump/ timing belt cost
Discussion in '1st Gen. Tacomas (1995-2004)' started by sasamuli52, Jun 26, 2023.
  1. Jun 26, 2023 at 10:08 AM
    sasamuli52
    sasamuli52 [OP] New Member
    2023 TRD off road
    I’m looking into a diy water pump and timing belt replacement for my ‘01 v6 taco. I’ve seen some cheap parts on eBay but held off on pulling the trigger due to the old “you get what you pay for.” Just wondering what the ball park is for a quality part but due to it being my fun truck I’m not trying to spend too much on parts. Thanks
  2. Jun 26, 2023 at 10:47 AM
    O'Silver_Taco
    MD
    98 Dlx Sr5 ext AT Rwd
    sasamuli52[OP] likes this.
  3. Jun 26, 2023 at 10:51 AM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    AirCabinMan on Ebay sells OEM kits for ~$300. I just bought one for my '98 4runner. I was very impressed with how neatly packed the box was with every OEM Toyota part needed to do the job right (timing belt, tensioner, camshaft seals, water pump, water pump gasket, thermostat, etc (probably more stuff I can't remember)). Many on here will recommend his kit too.
    jetbuilt and sasamuli52[OP] like this.
  4. Jun 26, 2023 at 10:57 AM
    O'Silver_Taco
    MD
    And unfortunately if you pay a shop to do this....
    you should engrave your old parts .....to keep everyone honest....
    sad but true....
    light tap each part with a cut-off wheel.....
    sasamuli52[OP] and Lord Kanti like this.
  5. Jun 26, 2023 at 2:43 PM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    AirCabinMan Auto Parts Supplier on ebay the best price all good parts .
    I bought several kits a few years back If i needed another they would be my go to.
  6. Jun 26, 2023 at 8:11 PM
    Greysuit
    Greysuit New Member
    2000 Tacoma 3.4L 4x4 TRD
    3” Lift, 31” Tires
    I’m looking at doing the same to my truck. My AC sucks. The RPM’s idle up when I engage the AC via the button on the dash. But the air just gets slightly cooler than room temp. I tried recharging it but it wouldn’t take, as it was already full of refrigerant. Would it be worth the minimal extra effort/money to just replace the compressor while I do the timing kit/belts/water pump? Or is it unlikely to help since the compressor obviously turns over? Thanks in advance.
    1997TacomaSR5 likes this.
  7. Jun 26, 2023 at 10:29 PM
    treyus30
    treyus30 70% complete 70% of the time
    Trey
    Mesa / AJ, AZ
    '99 5VZ-FE Twin K03s w/Haltech
    Historic plates and 2 bar
    It's probably overcharged
    Greysuit[QUOTED] likes this.
  8. Jun 27, 2023 at 6:18 AM
    Bivouac
    Figure out the problem!!
    Fire the AC parts cannon replace the whole system.
  9. Jun 27, 2023 at 9:12 AM
    O'Silver_Taco
    MD
  10. Jun 27, 2023 at 9:17 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    if you are buying a kit on eBay, make sure to check where the seller is based out of. China is notorious for knockoff parts and they will even replicate the OE packaging. If the price is too good to be true then it probably is.
    I would source an Asin kit over a risky eBay OEM one, previous owner put an Aisin kit in my 96 4runner some years back and it's still ticking along great.
  11. Jun 27, 2023 at 9:21 AM
    1997TacomaSR5
    1997TacomaSR5 OG TACO - 3ook+ ...where 2 wheel next
    I am having this issue as well
    It should be MUCH colder running the highway
    And I am leaning towards the evap part under dash being filthy AF since no cabin filter to keep decades of dirt buildup from occuring from fresh air inlet
    But IDK!
  12. Jun 27, 2023 at 9:30 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Aisin is my first choice. If not then a Contitech kit or even Gates would be decent enough
  13. Jun 27, 2023 at 10:52 AM
    Greysuit
    Greysuit New Member
    3” Lift, 31” Tires
    You may be onto something, as this truck has spent a ton of it's life in the brush. There was a lot of dirt pulled from the cabin during a detail. Appreciate the responses.
    1997TacomaSR5[QUOTED] likes this.
  14. Jun 27, 2023 at 12:19 PM
    sean.hwy
    sean.hwy Well-Known Member
    Sean
    1st choice local dealer; 2) toyota online dealer some dealers online will sell cheaper. 3) rockauto has OEM parts
  15. Jun 27, 2023 at 12:59 PM
    O'Silver_Taco
    MD
    You can get oem parts thru Napa too.
