Water pump gasket
Discussion in '1st Gen. Tacomas (1995-2004)' started by gherkin, Jan 21, 2014.
  1. Jan 21, 2014 at 5:37 AM
    gherkin
    gherkin [OP] New Member
    I just finished the timing belt/water pump project on my 2000 Tacoma (177k).
    There is a water leak- looks like near the thermostat side.
    I used an Aisin pump with the supplied gasket that had what I assumed was a ridge of black sealant on both sides so I didn't apply any additional sealant.
    The gasket surface was meticulously cleaned and the pump was torqued to specs.
    Any thoughts on this?
    Looking forward to re-doing this little task...
    Thanks
  2. Jan 21, 2014 at 6:47 AM
    tacomataco2
    tacomataco2 A dude
    Mass
    15’ ACLB
    Some of this Some of that
  3. Jan 23, 2014 at 3:43 AM
    gherkin
    In this case I did the easiest thing first, which was to remove and reseal the thermostat housing. Lucky for me, that's where it was leaking.
