Water Pump for Potable Water - Off Truck Bed Outlet
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Teegs, Dec 19, 2019.
  1. Dec 19, 2019 at 11:28 AM
    Teegs
    Teegs [OP] Well-Known Member
    So my wife got me a submersible water pump for Christmas that will plug into a DC power outlet. She planned on using it to pressurize our water tank in the truck bed so that we don't have to unload it when we're setting up camp.
    I've got a couple things I want to do, but honestly, have no idea where to start.
    1) The pump only came with a DC power cable. What do I need to be able to power it with the AC outlet in the bed of the truck (would be the most convenient spot to power it).
    I don't have the pump with me, but I do remember it draws 6 amps.
    2) Going to need that outlet to be energized even when the truck is off. I feel like there was a mod for that somewhere, right?
    Anyone want to point me in the right direction?
  2. Dec 19, 2019 at 11:38 AM
    windsor
    windsor Just a guy
    Homeless in Oregon
    2008 Tacoma Super Duty aka Tundra
    Canopy, fitted seat covers, OBA with self leveling air bags, 100w solar, dual Rhino Rack Pioneer platforms, side & rear LED work/FU lights, CB, cell booster. 7x16 cargo conversion, 3" lift, 7'x6.5' fold down aluminum rear deck.
    Get a marine power outlet and run new wiring. That way you dont mess with factory wiring at all and you can mount the outlet where you want it.
    Teegs[OP] likes this.
  3. Dec 20, 2019 at 10:06 AM
    Teegs
    I guess I was wondering if there's some kind of AC/DC adaptor I can use?
    Kind of like this: https://www.amazon.com/Belker-Universal-Adapter-Household-Electronics/dp/B07J6RC43S?ref_=ast_slp_dp
  4. Dec 20, 2019 at 10:13 AM
    Rock Lobster
    Rock Lobster Thread Derailer
    Dee Eff Dub
    I drive a Miata.
    That would bother me on a weird personal level. You have a DC system inverting to AC, which you are then converting back to DC. It could be done I guess, but why? Its just as easy to either exchange the pump for an AC unit or run a new DC outlet, as @windsor said.
  5. Dec 20, 2019 at 10:18 AM
    dilbert
    dilbert AI Member
    PNW
    2019 DCLB TRD Off-Road
    The truck bed outlet will only have power when the truck is on. The "anytime" in the 400w anytime mod refers to being able to use 400W anytime it would normally limit you to 100w - since by default it limits you to 100w when the truck is in gear (400w only available with the truck in park).
    https://www.tacomaworld.com/threads/new-2nd-3rd-gen-tacoma-in-cab-120v-ac-outlet-order-now.622505/
    Teegs[QUOTED][OP] likes this.
  6. Dec 20, 2019 at 10:25 AM
    YF_Ryan
    YF_Ryan Well-Known Member
    Kent, WA
    2011 Silver Tacoma TRD Offroad
    Icon Coil Overs. Deaver U402 Stage 3 Leafs w/ Bilstein 5160s. ARB Deluxe Bull Bar. Fuel Boost wheels w/ Wrangler Duratracs. Brute Force Fab Sliders & HC Rear Bumper w/swingout
    Do you have a dual battery setup yet? Might be time to think about doing some electrical work and adding some 12v plugs out in the bed. I run my water pump off a 12v socket back there.
  7. Dec 20, 2019 at 10:28 AM
    Teegs
    Yeah I'm limited because it was a gift from the wife.
    No AGM yet. It's on the docket but I've got a lot of other mods taking priority first. Kind of looking into a simple solution for the meantime.
  8. Dec 20, 2019 at 10:31 AM
    Rock Lobster
    Dee Eff Dub
    I drive a Miata.
    I had a thought about it. Simplest solution is this:
    https://www.amazon.com/Extension-Ba...=12v+DC+extension+cord&qid=1576866378&sr=8-17
    Clips directly to battery, so truck doesn't need to run. I would also recommend keeping a simple voltmeter around to monitor the charge left on your truck.
  9. Dec 20, 2019 at 10:35 AM
    yotahunter
    yotahunter Well-Known Member
    Central Iowa
    2020 TRD Pro
    I have considered the same thing on the last few vehicle’s I’ve owned. I always end up running a new 12v.
  10. Dec 20, 2019 at 11:15 AM
    YF_Ryan
    Kent, WA
    Hey, this is a great solution! I have the below GOOLOO jump pack and the 12v adaptor. I've run my 12v pump off it before. You can use it as a jump pack, too. Last time I used mine I had three GoalZero lanterns chained to it for about 3 hours and barely used any juice. The cigarette lighter comes and goes on availability, you just have to watch for it.
    https://www.amazon.com/GOOLOO-18000mAh-SuperSafe-Starter-Portable/dp/B0748D8KT6/ref=asc_df_B0748D8KT6/?hvadid=312065537890&hvpos=1o3&hvnetw=g&hvrand=16421965360816430605&hvpone=&hvptwo=&hvqmt=&hvdev=c&hvdvcmdl=&hvlocint=&hvlocphy=9051868&hvtargid=aud-801381245258%3Apla-569205903066&psc=1
    https://www.amazon.com/GOOLOO-Cigar...H9DKG4BK31T&psc=1&refRID=EW01YA300H9DKG4BK31T
    EDIT - and I almost forgot, my wife uses her 12v heated blanket with it when camping. It'll run 15 minutes before some safety thing kicks off and you have to press the on button again, but it works great.
  11. Dec 20, 2019 at 12:33 PM
    Teegs
    Appreciate the input guys. I'll have to look into a couple of these ideas!
