WATER PROOF THE INTERIOR??
Discussion in 'Off-Roading & Trails' started by F'N_POG, Oct 27, 2018.
  1. Oct 27, 2018 at 7:32 AM
    F'N_POG
    F'N_POG [OP] New Member
    Joaquin
    2016 Tacoma SR5 XP
    Got about an inch of water inside my cab. Carpet and padding has to be replaced due to mold and mildew from brackish water (thank you Galveston). Anything anyone recommend to help keep water out of the interior (assuming I have no choice but to ford through flooded roads)?
  2. Oct 27, 2018 at 7:34 AM
    FuzzysTacos
    FuzzysTacos Well-Known Member
    Corey
    Wichita, KS
    Sold: 2017 TRD OR/2012 TRD Sport
    There's some speculation as to whether the rubber flooring from a 2nd gen will fit a 3rd.
  3. Oct 27, 2018 at 7:37 AM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    Detriot locker rear ARB air locker front 4.56 gears OME 3" lift, SPC uca's , moto metal 951 wheels 315/75/r16 Treadwright guard dogs, homemade front plate bumper with smittybilt 9.5k winch, homemade skids, homemade Bed bars, Mobtown offroad high clearance rear bumper with tire carrier, Homemade rock sliders , U-bolt flip, Wheeler's super bumps, BORA 1" wheel spacers , Black headlight mod , black tail lights, Satoshi Grill , autoPage C3 RS-665 alarm with remote start, flowmaster 40 series exhaust, cruise control,bed/ground effect lights, wet okole seat covers, tinted,windows, weather tech floor mats, AVS vent shades, debadged, hidden cobra 19 cb, 7" offroad lights behind grill, rear diff breather relocate, abs kill switch
    Don’t put carpet back in.
    put vinyl flooring in it. Like work trucks have
    lynyrd3 and F'N_POG[QUOTED][OP] like this.
  4. Oct 29, 2018 at 9:03 AM
    choijw2
    choijw2 Member
    what do you mean by vinyl flooring?
    as in whole base carpet? or just floor matte like the one from weathertech and husky?
    lynyrd3 likes this.
  5. Oct 29, 2018 at 10:12 AM
    jbrandt
    jbrandt Made you look
    Justin
    '04 TRD Tacoma 4x4 DC
    Only way to prevent your interior from getting wet is to not go in deep water...
    Seriously, I don't think there's really a way to truly prevent water from getting inside. It may not seem like it, but the bodies are like swiss cheese. Holes everywhere. The BBC Top Gear guys couldn't even do it with filling every crevice with foam and welding the doors shut.
    If you make a habit of crossing deep water, the best thing you can do is waterproof your low hanging electronics and rip the carpets out and spray it with rhyno lining or something. Make sure there's an easy way the water can get OUT, too.
    xtremewlr and lynyrd3 like this.
  6. Oct 29, 2018 at 3:56 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    not a floor mat. carpet is going to mold and mildew everytime you get it soaked so you have to replace it with vinyl or rubber flooring.
    this is for a 2nd gen but something like this
  7. Oct 29, 2018 at 4:01 PM
    jbrandt
    Justin
    IMO, this is still not a good idea. At least as far as dunking the thing in rivers, this would be only marginally better than carpet. You are still going to trap a whole bunch of water in very inaccessible places under this mat which will still mold.
    These mats are good if you always have muddy/wet boots, but not for swimming with the truck.
    Truck bed liner isn't even a "water proofing" solution...
  8. Oct 29, 2018 at 4:07 PM
    jwctaco
    jwctaco Retired, going slow in the fast lane
    Jim
    SW Michigan
    23’ T4R
    If I’m not mistaken the vinyl floor coverings for work type trucks has insulation attached to the bottom of the vinyl. It still would hold water and mold.
  9. Oct 29, 2018 at 4:09 PM
    bagleboy
    bagleboy Well-Known Member
    Scott
    Norcal, Santa Rosa
    2014 5-lug AC 2.7L VVTI
    Snug top Rebel, Thule tracks, ditch tracks, Bagged rear suspension, F/R anytime camera, intermittent wiper switch...
    Probably a bad idea to repeatedly flood the air bag connectors under the seats but there are several unsealed grommets on the cab floor as well as under the center console. The cab body also has grommets in the tubes under the thresholds that should be drained as well. I'd say if it's a regular issue then rip it all out and use bed liner.
    jwctaco likes this.
  10. Oct 29, 2018 at 4:10 PM
    la0d0g
    running for the hills
    For crawling not hauling
    Not to mention, the vinyl flooring has pads with fabric on it underneath just like the carpet does.
    jwctaco likes this.
  11. Oct 29, 2018 at 4:12 PM
    mynewtoy
    mynewtoy I like men
    greg
    Mississippi
    09 double cab 4x4
    I didn't relize they had pads under them. yep bad idea
