Water leak
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Meneses14, Feb 5, 2025.
  1. Feb 5, 2025 at 12:57 PM
    Meneses14
    Meneses14 [OP] Member
    IMG_4379.jpg IMG_4377.jpg IMG_4370.jpg IMG_4369.jpg IMG_4367.jpg IMG_4379.jpg IMG_4379.jpg IMG_4377.jpg IMG_4379.jpg IMG_4377.jpg Is this coming from the 3rd brake light or the top of the rear window (recently had it repaired). When I got it back from repair, my 3rd reverse light wasn’t turning on so I’m assuming they replaced it? But now there is water leaking again. They had redone the window repair again. But now I’m thinking they caused this leak from the brake light.
    2021 Tacoma off road
  2. Feb 5, 2025 at 12:59 PM
    Phlogiston
    Phlogiston There are no victims, only volunteers.
    Not Karen
    The wild west
    2016 SR5 DCSB
    Aesthetically Challenged
    how are we supposed to know where your leak is coming from?
    Maybe you've got some pictures you'd like to include? *edit* you just added pics, good job.
    RIX TUX, Chew and Meneses14[OP] like this.
  3. Feb 5, 2025 at 1:00 PM
    Meneses14
    Just added some, sorry
    Phlogiston[QUOTED] likes this.
  4. Feb 5, 2025 at 1:08 PM
    jgarverick
    jgarverick Well-Known Member
    2021 DC SR
    Isn’t there a recall for the third brake light assembly well? I seem to recall a whole thread for that issue. Either way it seems like the shop that did the work forked this up my friend. Talk to them first and see if they can fix it. That’s what I would do.
    Meneses14[OP] likes this.
  5. Feb 5, 2025 at 1:12 PM
    TA2016
    TA2016 Well-Known Member
    Oregon
    2016 TRD Sport AT V6 4x4 ACLB P&T Package Red
    Meneses14[QUOTED][OP] likes this.
  6. Feb 5, 2025 at 2:02 PM
    Meneses14
    TA2016[QUOTED] likes this.
  7. Feb 5, 2025 at 2:05 PM
    Phlogiston
    Not Karen
    The wild west
    2016 SR5 DCSB
    You should be able to pop that liner off and get a better look at where the water is coming from.
  8. Feb 5, 2025 at 2:20 PM
    TAZMINATOR
    TAZMINATOR Well-Known Member
    2017 Tacoma
    Since you have wet spot all the way across top of window, it could be missing seal in window frame.. not sure if leak from brake light would spread out like that.. if you had window repair recently, take it back to shop and demand them to fix it at no charge since it’s their fault. After that done, you can replace brake light seal yourself or Toyota dealer.
  9. Feb 5, 2025 at 2:54 PM
    CT Yankee
    CT Yankee Well-Known Member
    CT
    2021 TRD OR AC AT MGM
    Only aesthetic mods so far Leer 180 cap & Clazzio covers on order.
    What do you mean by this?
    AFAIK there is no 3rd reverse light.
  10. Feb 5, 2025 at 2:56 PM
    Meneses14
    Thank you;
    I’m just trying to figure out is this from brake light or the window repair they have done
    Mind you this is series of events.
    1. Original issue was a dent repair in September 2024 on the pillar frame above my driver door. They had to take off the bed and the entire window assemble allegedly for paint access.
    2. When I picked it up 2 weeks later paint overspray and scratches on my truck. Also my reverse light on bottom left and 3rd brake light reverse light wasn’t working.
    4. Pick it up again, when I get home I find a bunch of screws in my cup holder and the storage behind my backseat is not put back correctly. Also, trim piece by the windows on the corners is popping out not put back correctly.
    5. Pick it up again and this time a week later this issue happened; but back in November. Water on headliner and around top of window.
    6. Now I’m here in February 2025 with more water leaking from same areas.
    would you take it back again to same place?
  11. Feb 5, 2025 at 2:57 PM
    Meneses14
    When u put the truck in reverse; the truck bed light turns on. It’s apart of the 3rd brake light assembly
  12. Feb 5, 2025 at 3:02 PM
    Chew
    Chew Not so well known user
    Chewy
    Midwest
    19 TRD OR
    Amazon dog poo bed mat mod
    ewfff, sounds like some hacks, sorry that sucks.
    As mentioned; it's hard for us to tell, GL
  13. Feb 5, 2025 at 3:02 PM
    forana
    forana Well-Known Member
    Kaneohe, Hawaii
    2022 DCSB OR Lunar Rock
    No money, all went to truck...
    either way, take it back, have them fix it.
  14. Feb 5, 2025 at 3:04 PM
    TAZMINATOR
    2017 Tacoma
    you have two options:
    1) take to the shop for leak fix which their fault…. Or
    2) take it to dealer but you may pay out of your pocket.. if the previous shop was a dealer, then take it to other dealer and go from there…. See if they can cover that with warranty if you have it. Otherwise, contact the corporation for the issues you have.
  15. Feb 5, 2025 at 3:09 PM
    auskip07
    auskip07 Well-Known Member
    Skip
    Atlanta, Ga
    2019 TACOMA SR V6 SC , 4X4, AUTO, 4.88, 265/75 r16
  16. Feb 5, 2025 at 3:09 PM
    Meneses14
    Caliber collision!!
  17. Feb 5, 2025 at 3:11 PM
    Chew
    Chewy
    Midwest
    19 TRD OR
    I have not heard glowing reviews, but have no firsthand experience either.
    Of course, they are a large operation, so with as many vehicles as they fix, there are likely to be bad stories. A good autobody shop is hard to find, many hacks.
  18. Feb 5, 2025 at 3:13 PM
    auskip07
    Skip
    Atlanta, Ga
    i had caliber collision fix an older vehicle after an accident, i had missing foam support in the trunk so when i got groceries the bags fell down to the spare tire, Missing plastic clips for the rear bumper, they glued the tow eye access panel to the frame with glue and it popped off when i put my foot on the bumper. Afrer my review they changed the shop name.
    They were more concerned with me giving a good review than they were about doing a good job. I wouldnt piss on their shop if it was on fire.
    Chew and Phlogiston like this.
  19. Feb 5, 2025 at 3:17 PM
    Meneses14
    My goodness
  20. Feb 5, 2025 at 3:17 PM
    Meneses14
    I agree. I’m in inland empire CA
