Water coming in through firewall rubber grommet?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by greentacosuace27, Oct 14, 2022.
  1. Oct 18, 2022 at 9:53 AM
    greentacosuace27
    greentacosuace27 [OP] Active Member
    Central MA
    2021 TRD Sport DCLB AG
    No I don’t. They claimed the water came in thru that grommet when testing it.
    doesn’t make sense as I see people cut wholes in these offer for light wires, etc
  2. Oct 18, 2022 at 9:54 AM
    JackSparrah
    JackSparrah Well-Known Member
    1999 SR5
    Yeah that sounds like bogus for the amount of water you're getting. I've run many wires through mine and never had a drop of water. Not saying it isn't that, but i don't think it's the cause. How are your windshield seals? Might be worth checking those out
    vicali likes this.
  3. Oct 18, 2022 at 9:56 AM
    JackSparrah
    1999 SR5
    Also just a thought, does your cab show any signs of rust? I can see you drive a newer rig but if some hardware or seal somewhere is failing that could also cause it.
  4. Oct 18, 2022 at 9:56 AM
    JackSparrah
    1999 SR5
    Sorry final thought, you could also silicon it, but then you wouldn't be able to run any additional wires through
  5. Oct 18, 2022 at 9:57 AM
    greentacosuace27
    Central MA
    I'm going to check with a hose. Wetness inside is limited to the top 2" or so around the wires coming in.
  6. Oct 18, 2022 at 9:58 AM
    greentacosuace27
    Central MA
    no rust that i can see
  7. Oct 18, 2022 at 9:59 AM
    greentacosuace27
    Central MA
    That's what the service rep told me to do when he showed me in the parking lot, 'off the record'
  8. Oct 18, 2022 at 10:01 AM
    JackSparrah
    1999 SR5
    I see. Sucks. I wonder if you could find some sort of longer rubber boot to put around the stock one to stop more water flow?
  9. Oct 18, 2022 at 10:04 AM
    MikeyD.25
    MikeyD.25 Well-Known Member
    Rather than pay thousands of bucks just to replace the grommet, try some FLEX SEAL or other brand of liquid rubber spray and liberally apply/spray around the grommet on the firewall, onto the grommet and into the space where that wire loom goes into the truck.
    I've used the stuff on the roof of my house to seal seams around a skylight and the stuff works great!
    ABA180 and JackSparrah like this.
  10. Oct 18, 2022 at 10:05 AM
    JackSparrah
    1999 SR5
    Second this OP, don't know why I didn't think of it. Probably a better option than a boot over it and you may still be able to stick wires through it if you want to run more stuff to the cab.
    greentacosuace27[OP] likes this.
  11. Oct 18, 2022 at 10:06 AM
    greentacosuace27
    Central MA
    Agree, the amount of water coming in is minimal.
    Not sure of its worth getting a second opinion from the dealer I bought my truck from or not.
  12. Oct 18, 2022 at 11:13 AM
    greentacosuace27
    Central MA
    Looking around online it looks like some 4Runner's leak when their grommets are cut to route wires through. Alot of water hits them due to the location of the 4R's wires. RTV Silicone seems to seal them up and have made a little roofs over it with success.
  13. Oct 18, 2022 at 11:38 AM
    JackSparrah
    1999 SR5
    Yeah i would definitely try that before a dealership or shop tries to extort you to replaced the whole wire bundle, grommet, etc.
  14. Oct 18, 2022 at 11:42 AM
    ABA180
    ABA180 It burns when I pee....
    East Bridgewater MA
    Pioneer CD, Megaloud/JBL amps, Rockford/Polk speakers.
    A wise idea, I fixed a hole in my roof temporarily with that and a slab of shingle until I could get a roofer to repair it correctly. Stuff works.
    MikeyD.25[QUOTED] likes this.
  15. Oct 18, 2022 at 11:44 AM
    #35
    JackSparrah
    1999 SR5
    At first I thought you meant the roof of your Taco, lol
  16. Oct 18, 2022 at 11:49 AM
    #36
    myn75
    myn75 Well-Known Member
    Nor Cal
    2021 TRD Off-Road 4x4 DCSB, 1996 4runner SR5 V6 4x4 auto
    ARB OME BP-51 2”, TJM sliders, AT3Ws, Diode Dynamics SS42"
  17. Oct 18, 2022 at 11:56 AM
    #37
    TRD Ted
    TRD Ted Well-Known Member
    2020 Army Green TRD Pro
    Get a second opinion from where you bought it.
  18. Oct 18, 2022 at 12:42 PM
    #38
    ABA180
    East Bridgewater MA
    Haha, no the back of my house has a small jog out and a flat roof that a tree limb hit
  19. Oct 19, 2022 at 4:08 AM
    #39
    JackSparrah
    1999 SR5
    Bin Laden meme?? Lol that's a first
  20. Oct 19, 2022 at 5:50 AM
    #40
    greentacosuace27
    Central MA
    The hood release cable moves freely in and out of the firewall causing the grey washer not to contact the grommet. Tried pulling the cable tight and sliding the grey washer but it’s doesn’t want to move and I’m a bit scared to break anything. When the grey washer is out it leaks slightly, when tight no leak found. Whatever silcone they used early this week never cured and was still wet. Thoughts on a good adhesive to secure this? There is a lot of play in the cable so I’m a bit hesitant to secure in a way that could rip the rubber if it moved somehow
