Washing undercarriage?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by guywithahog, Jan 4, 2022.
  1. Jan 4, 2022 at 3:13 PM
    guywithahog
    guywithahog [OP] Well-Known Member
    Francisco
    LA
    21 MGM OR DCSB
    I recently went to Zion over the New Years weekend & it was snowing/icy. They said that they plowed and sanded the roads. I’m from SoCal so I’m not used to snowy roads, but from what I understand, you should wash your undercarriage to prevent rust from roads treated for the snow. I drove around the park for two days, should I wash my undercarriage? Are sanding and salting the roads the same?
  2. Jan 4, 2022 at 3:19 PM
    MIDTNTACO
    MIDTNTACO Well-Known Member
    Middle Tennessee
    2020 Midnight Black TRD Sport 4x4 DCSB
  3. Jan 4, 2022 at 3:20 PM
    RLMoody
    RLMoody Well-Known Member
    2017 Toyota Tacoma SR
    I wouldnt worry about it if its just sand unless you just want to clean it up. Here in Ohio they salt the roads and also use a brine solution that attacks the bottoms of our cars. I pressure wash mine once a week .
    Tacowin1013 likes this.
  4. Jan 4, 2022 at 3:21 PM
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    sanding is different than salt. Most in the west don't use salt from my understanding.
  5. Jan 4, 2022 at 3:23 PM
    MGMDesertTaco
    A Bidet for your truck. :rofl:
    Yes, wash that funk off. Either with a garden hose or a pressure washer attachment linked above. The longer it sits the more difficult it will be to remove.
  6. Jan 4, 2022 at 3:25 PM
    Late Camaro
    Late Camaro Well-Known Member
    Central Ohio
    22 TRD Sport Barcelona Red Access Cab MT
    Brought it home 3-16-22
    Salt and brine will rust exposed steel, as well as melt snow & ice. Salt just adds some grip/traction to ice. Sand could collect in areas, and hold moister…
  7. Jan 4, 2022 at 3:25 PM
    MGMDesertTaco
    guywithahog[OP] likes this.
  8. Jan 4, 2022 at 3:26 PM
    17tacotrdor
    17tacotrdor Well-Known Member
    SOCAL
    2019 TACO
    Grab some cheap metal ramps from harbor freight and hit a dollar car wash
  9. Jan 4, 2022 at 3:27 PM
    Dubdaddy86
    Dubdaddy86 Well-Known Member
    I’m from the south, I use and have used several diff methods. My truck doesn’t get washed at all during hunting season. 4+ months. After hunting season is over, I’ll take the tires off and rotate them. While I have them off, I do a thorough washing of the wheel wells too. I also pull the truck up on some of the oil change type ramps and get under it with a pressure washer. When all is said and done, you won’t be able to tell the truck has even seen a dirt road.
    Another trick I used to do, might be helpful for you, is put a sprinkler under the truck and sit back and wait.
    MIDTNTACO likes this.
  10. Jan 4, 2022 at 3:39 PM
    guywithahog
    Francisco
    LA
    21 MGM OR DCSB
    What’s the difference between them sanding and salting the roads? It’s just for traction isn’t it?
  11. Jan 4, 2022 at 3:40 PM
    guywithahog
    Francisco
    LA
    21 MGM OR DCSB
    Should I even be worrying about it then?
  12. Jan 4, 2022 at 3:40 PM
    guywithahog
    Francisco
    LA
    21 MGM OR DCSB
  13. Jan 4, 2022 at 3:41 PM
    guywithahog
    Francisco
    LA
    21 MGM OR DCSB
    So I should just give it a rinse to be safe? I just don’t want to be surprised by any rust or anything I check it out in the future haha
  14. Jan 4, 2022 at 3:42 PM
    Speedfreak
    Speedfreak Member in poor standing
    Dave
    Canada Eh!
    2017 Tacoma TRD Sport DCSB 6MT, Blazing Blue Pearl
    Manual Mall Crawler
    Every year I get under my truck and pressure wash the under carriage because all the salt laid down on the roads around here. If you were in a State that puts anything down for icy conditions then getting under that to wash it down will not hurt it. If anything it will give you peace of mind. Get under there and wash it. 20220104_154115.jpg
  15. Jan 4, 2022 at 3:42 PM
    guywithahog
    Francisco
    LA
    21 MGM OR DCSB
    The sprinkler idea doesn’t seem to bad… neither does the ramp idea.
    Dubdaddy86[QUOTED] likes this.
  16. Jan 4, 2022 at 3:54 PM
    Montana_Actual
    Montana_Actual ;)
    Go to the car wash, get on your knees and spray under the truck.
    and it's only Tuesday.
    Sig45 and RustyGreen like this.
  17. Jan 4, 2022 at 4:02 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    TDImark, Montana_Actual and Sig45 like this.
  18. Jan 4, 2022 at 4:10 PM
    RustyGreen
    sleeping in a chair
    2017 AC 4x4 Sport 6M Inferno
    Pavement Princess
    Go to the coin wash and wash the underside of the truck as good as possible. Pay special attention to the inside of the frame rails and box sections. Don't forget hidden areas like the bottoms of the doors and tailgate.
    The difference between salt and sand is that salt will chemically melt ice and also rust your truck, sand (or cinders) will give additional traction. Many areas use one, the other or a mixture of both. They may salt a straight section of road and also cinder the intersections and hills.
    Montana_Actual likes this.
  19. Jan 4, 2022 at 5:00 PM
    mquibble
    mquibble Well-Known Member
    Michael
    2021 TacomaTRD Pro
    Sand provides traction. Salt reduces freezing temperature.
    TDImark likes this.
  20. Jan 4, 2022 at 6:04 PM
    Tacowin1013
    Tacowin1013 Well-Known Member
    2017 OR DCSB 6MT MGM
    If you don't have access to a hose in your garage at home during the winter, do as others suggested and take it to a spray car wash and hose the undercarriage for peace of mind. I spray mine about once a week in the winter
