Washers and nut for center support bearing
Discussion in '1st Gen. Tacomas (1995-2004)' started by 1stgentacoma808, Nov 10, 2021.
  1. Nov 10, 2021 at 11:04 PM
    1stgentacoma808
    1stgentacoma808 [OP] Member
    Sheldon
    Arb bumper snorkel
    I’m looking for a new nut and washer for the center support bearing been looking online and can’t find it anyone know where I could find them I have the one that goes below the nut need the one in between bearing and flange
  2. Nov 11, 2021 at 1:42 AM
    theswarm
    theswarm Well-Known Member
    https://4xshaft.com/products/toyota-drive-shaft-bolts
    (These are flange bolts for the driveshaft, the nut size is the same for the studs; so you can use just the nuts if needed. Washers are M10 crush washers.)
    Ive called Toyota parts dept. near me. They wanted $8+ per nut..
    So I ended up buying these, same grade - same size.
    or are you referring to the (2) bolts that hold the carrier bearing to the mounting bracket / frame of veh?
  3. Nov 11, 2021 at 8:04 AM
    1stgentacoma808
    Sheldon
    Arb bumper snorkel
    Looking for the nut and two washers that go in between bearing and flang center support bearing washer flange washer and nut
  4. Nov 11, 2021 at 10:03 AM
    Bivouac
    Bivouac Well-Known Member
    Northern Lehigh Valley Pa
    2000 Tacoma 5 speed 3.4
    Remains to be seen I bought the tires and wheels the rest came along
    Take the nut and washer you have a go to the hardware store and Hope they have JIS hardware . Japanese Industrial Standard
    It is always good to take a picture when asking about hardware
    I would just replace all the hardware while your doing this.
  5. Nov 11, 2021 at 11:05 AM
    Andy01DblCabTacoma
    Andy01DblCabTacoma Well-Known Member
    Andy
    San Diego, CA
    01 Double Cab v6 4x4 TRD
    F: Kings SPC, R: 5100s+J59s. Custom armor.
    It's a little difficult to understand what you're asking for, but I think it's either one of these three things.
    1) 90179-18009 / 37120B (nut), 90201-18182 / 37120A (rear washer), 90201-25006 / 37230E (front washer x2)
    2) 90119-10865 / 37230F (bolt for center support bearing)
    3) (not annotated- bolts and nuts for the prop shaft to the intermediate flange) 90080-10294 / 37110A (bolt), 90560-10H00 / 37110E (spacer/washer), 90080-17239 / 37110D (nut)
    If it is 90179-18009, be aware, that this is a staked nut (which is why I assume you're replacing it) and that there is a funky torque process when you're reinstalling it, before you stake it.
  6. Nov 11, 2021 at 11:18 AM
    Andy01DblCabTacoma
    Andy
    San Diego, CA
    Most places don't even carry Metric let alone JIS. Further, JIS use on the Tacoma is pretty limited to smaller fasteners, and not the bolts and nuts throughout the driveline (which the OP was referring to in this case) and engine.
  7. Nov 11, 2021 at 12:10 PM
    Bivouac
    Hardware stores can be hit or miss OP might get lucky My Hardware store does .
    Well like I said a few times most all my Toyota experiences is mid eighties so What year did Toyota quit using JIS hardware in the Drive Line so I can purchase the proper hardware .
