Washer fluid spray nozzle question
Discussion in '1st Gen. Tacomas (1995-2004)' started by Rctmontana, May 22, 2021.
  1. May 22, 2021 at 10:12 PM
    Rctmontana
    Rctmontana [OP] Well-Known Member
    Bozeman, Montana
    2003 5 speed M/T 2.7 sr5 4x4
    The spray pattern of the washer fluid spray nozzles on my truck are just two solid streams from each nozzle. Is this just how the spray nozzles are on 1st gen Tacomas or are mine just old and worn out? I’d like better coverage, that actually “mists” and wets my whole windshield, or near enough.
    are new spray nozzles just going to be the same? Are there third party options? Will new model nozzles fit/be made to fit? If none of the above is there a mod/fix for this? It’s a small and insignificant problem but one I’ve wondered about; I thought the answer might be here among the gurus. Thanks in advance!
  2. May 22, 2021 at 10:55 PM
    SLAPS 65
    SLAPS 65 Dirty deeds, done dirt cheap..
    Leif
    Nor Cal east Bay Area Ca.
    2000 Tacoma 4wd ex cab 3.4 auto.. manual hub, J shift
    Mine spray a single stream but I know what your talking about, my wife’s car and my beater Honda civic backup car spray in a fan shape. Not sure if it’s how there designed but they work, the blades distribute the fluid around just fine. If you want to try and fix em I would at first take an old toothbrush and some simple green and scrub them up good, a lot of nozzles get plugged up with car wax sludge. Beyond that, aftermarket is probably gonna be worse, usually just cheep copies.
  3. May 22, 2021 at 10:58 PM
    Captain Magma
    Captain Magma Well-Known Member
    Patrick
    Tucson, AZ
    2002 4wd DblCab
    Kings and desert pinstripes
  4. May 22, 2021 at 11:18 PM
    SLAPS 65
    Leif
    1997tacomav6 likes this.
  5. May 23, 2021 at 4:52 AM
    1997tacomav6
    Denver
    You need a tiny computer type flat head screwdriver so you can adjust the center Spray nozzle up or down and adjust for truck speed with wind pushing the spray down
  6. May 23, 2021 at 5:28 AM
    Wyoming09
    Wyoming09 Well-Known Member
    New Tripoli Pa
    Super Springs
    I built custom spray nozzles out of 1/4" pipe nipples.
    It allowed me to make any type of spray pattern I wanted.
    Someone had closed the holes in the hood for some reason.
  7. May 23, 2021 at 5:29 AM
    warmingupmymind
    warmingupmymind Well-Known Member
    Anmol
    San Francisco
    2000 Lunar Mist SR5
    33s and lockers
    I just used the tip of my nail.
    The Honda Odyssey nozzle spray pattern is way better than the Toyota's. This is definitely a worthwhile mod.
  8. May 23, 2021 at 5:35 AM
    KdF
    KdF Old Rednek Type
    East-ByGod-TEXAS!
    2000 Prerunner SR5 TRD 2WD
  9. May 23, 2021 at 9:21 AM
    turbodb
    turbodb AdventureTaco
    Dan
    PNW
    2000 Tacoma Xcab 4x4 SR5 V6 TRD
    AdventureTaco
    This is pretty similar to the existing replies, but has a few more photos and examples of why the Honda nozzles are better than the Ford ones:
    Modernizing the Windshield Sprayer Nozzles
  10. May 23, 2021 at 12:19 PM
    Rctmontana
    Bozeman, Montana
    Thanks for the responses everyone! Yes, the streams work just fine but I wanted better coverage, especially since I live in a buggy area. It’s annoying when you want to clean your windshield and the wipers just smear the bugs before any fluid hits them and then you can’t get it clean without scrubbing the windshield at a car wash/gas station.
    just ordered a set of the Honda sprayers, looks like they’re pretty well vetted in Tacomas so will be happy to get them installed when they arrive. Thanks again!
    SLAPS 65 likes this.
