Was told my REAR AXEL HAS SHIFTED. HOW CAN I FIX THIS?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rimfire7, Jul 26, 2021.
  1. Jul 26, 2021 at 10:01 AM
    rimfire7
    rimfire7 [OP] I'm here for the tacos
    beth
    2021 army green taco
    Toytec lift, old man emu springs, Victory 4x4 front bumper and skids, light bar
    Took my 2021 OR to Firestone for an alignment, husbo said he thought it was tracking to the side in the rear and Firestone said my axel has shifted. Can someone help me understand what has happened and how do I fix it? tia
  2. Jul 26, 2021 at 10:06 AM
    Chunk
    Chunk I smell Ice Cream!
    2016 DCSB OR
    Baby Ruth
    Did firestone give you an alignment sheet? It should show the rear as well as the front.
    Was any work done recently? Rear leaf/shock upgrades? U-bolt flip? Bump stops?
  3. Jul 26, 2021 at 10:06 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Need more information. Shifted which way? The rear axle attaches to the leaf springs so if it were shifted left or right might have a bent leaf spring or were it connects to the frame. Not sure id have to see the truck.
  4. Jul 26, 2021 at 10:06 AM
    hyrule_trd
    hyrule_trd It’s a Secret to Everybody
    Eric
    Harford County, MD
    2020 Black TRD OR
    Ironman Stage 1 Foam Cell Pro lift kit, 255/85/16 Cooper ST Maxx, SCS BR6 Wheels, SPC UCA, Heated seats, MESO TRD start button, Meso Total Tail v1, Meso V5 mirror white DRL turns, bed decal, ditch and hidden bumper lights, screen protech, RAV4 radio knobs, steering wheel anytime camera kit, dash cam, ECGS bushing, Timbren Active Off Road bump stops with Wheelers flip kit. 35% Xpel CS Ceramic Tint, KD Max Tune, SumoSprings front bump stops, RRW Sliders ‌ ‌ ▲ ▲‌ ▲
    I’d suggest taking it somewhere else lol. Not saying that Firestone is bad… they just try and sell things like other places. As far as I know, there is no adjustment for the rear axle. Did they give you an alignment sheet? Maybe try the dealer and see what they say. Unless you lifted/modded nothing should have changed.
  5. Jul 26, 2021 at 10:08 AM
    eon_blue
    eon_blue Okayest Member
    Azusa, CA
    The leaf springs sit on the spring perches on your rear axle - there is a small hole on the spring perch that the center bolt through the middle of the leaf packs rests in. If the u-bolts worked themselves loose then the leaf packs could have moved off the spring perch slightly, which would make the rear axle skew more to one side.
    If both leaf packs are firmly centered in the spring perches then most likely something got bent. Assuming Firestone is correct anyway. I wouldn't put a whole lot of faith in their word TBH without a second opinion from a reputable shop.
  6. Jul 26, 2021 at 10:11 AM
    shakerhood
    shakerhood Well-Known Member
    Southern Ohio
    Maybe the bed is out of alignment which is a common issue and the tech at Firestone thought the rear axle is offset to one side.
  7. Jul 26, 2021 at 10:14 AM
    Chunk
    2016 DCSB OR
    Baby Ruth
    I'd put money on that for sure!
  8. Jul 26, 2021 at 10:20 AM
    mhornco
    mhornco Well-Known Member
    I had my previous truck take a hard rear end hit and it did throw the axle out of alignment. There is a pin on the leaf pack that sits in a hole on the leaf spring perch. Depending on the truck it is surprising how much movement you can get. Luckily I took it to a good alignment shop. He loosened the u bolts and jigged the axle till it lined up on the machine and truck started going on a straight line again. I never noticed it until driving on a snowy street and saw my rear wheel tracks were about an inch over from the front end
  9. Jul 26, 2021 at 10:23 AM
    Itchyfeet
    Itchyfeet Well-Known Member
    I wouldn't even take my sister's car to, Strippy Lube, Firestone or Midas.
    Those places are shady
    jetfishn and rimfire7[OP] like this.
  10. Jul 26, 2021 at 10:32 AM
    Skydvrr
    Skydvrr IG: @kalopsianick
    Nick
    YMH
    Black '17 OR
    DID YOU TRY UNSHIFTING IT?
  11. Jul 26, 2021 at 10:32 AM
    Clearwater Bill
    Billy
    Largo Florida
    If your profile stated ToyTec lift included rear leaf springs, odds are high the installer created the problem, and should be the one to fix it.
    If the rear springs have not been touched, check the bed alignment to the cab as @shakerhood suggests.
    Thatbassguy, Vlady, jayuu and 4 others like this.
  12. Jul 26, 2021 at 10:48 AM
    baldbeardedtaco
    baldbeardedtaco Well-Known Member
    FL
    18 TRD Sport DCSB MGM
    For me I think my axle favors the passenger side, I have more wheel poke on passenger rear and when looking at the bed to cab lines it’s looks like it might be slightly off center but in the opposite direction so if I were to adjust the bed center it would make passenger rear worse. Is it possible the axle can be adjusted left to right or is it set as is? If no adjustments can be made at all then I likely have my cab slightly off
  13. Jul 26, 2021 at 10:49 AM
    Enigma8246
    Enigma8246 Well-Known Member
    Lee
    Central Arkansas
    2007 4Runner Limited 4WD V8
    Seconded. I've never had a good experience at a Firestone.
  14. Jul 26, 2021 at 11:07 AM
    chuam
    chuam Well-Known Member
    Marcus
    San Diego
    2017 Tacoma SR5 DCSB 4x4
    Icon Stage 3 - 2.5 & UCAs front, Icon 2.0 rear Icon RTX Stage 2 leafs Icon 700lb springs RSI Smartcap Evo Sport KDMax Pro tune BAMF Hybrid front bumper Warn VR EVO 10s winch ARB Rear Locker Revolution 5.29 regear RCI Engine Skid RCI Trans skid RCI Transfer case skid RCI Diff Skid RCI Cat guards RCI Rock sliders RCI roof rack R4T LCA Skids DRT Fabrication Hitch Skid Exhaust reroute ARB Dual Compressor w/ Slee Mount OR Black Fenders Diode Dynamics SS3 Pro fog lights Rigid D-SS Pro Ditch lights Rigid SR Amber PRO Edition 30” light bar Rigid SR-Q floods A/C drain mod Differential Breather Mod Supralee Traction Board mount Liftd Gas cap holder Taco Garage DMM 2.0 Total Chaos bed stiffeners TRD SEMA Pro 17" wheels Falken Wildpeaks 275/70r17 TRD Pro Grill Gecko shell lighting Ecological Bumper shells Fumoto valve Toyota aluminum oil filter cap DesertDoesit Seat Jackers Waterport Day Tank - Rago Fab bed mount Yakima Double Haul OVS 270 Awning Wet Okole seat covers Overland Equipped/Blueseas Bracket/fusebox Toyota OEM tailgate lock Rogue Offroad poly body mount bushings ZPrecision cup holders H9 headlight bulb upgrade Lambtek innovations winch switch
    Made the mistake of having them do a simple oil change. A couple of days later I opened the hood to do something and there was the oil cap sitting on top of the engine. They couldn't even remember to put it back on after filling it up......
    rimfire7[OP] and shakerhood like this.
  15. Jul 26, 2021 at 11:17 AM
    Hank Heel
    Hank Heel Well-Known Member
    WA
    You won’t say it, I’ll say it, Firestone is bad.
    rimfire7[OP] likes this.
  16. Jul 26, 2021 at 11:52 AM
    rimfire7
    beth
    DUH! That's the first thing I did. What a dumb question!
  17. Jul 26, 2021 at 11:53 AM
    rimfire7
    beth
    Are you kidding??!! :annoyed:
  18. Jul 26, 2021 at 11:56 AM
    rimfire7
    beth
    I had all the stuff done to it. And then I beat the poop out of it in Moab and the sand dunes lately. :facepalm:
    Thatbassguy likes this.
  19. Jul 26, 2021 at 11:58 AM
    rimfire7
    beth
    Not sure. Dropped it off this morning and have been at work all day. Maybe when we pick it up I will have that info.
    Thatbassguy and Brian422[QUOTED] like this.
  20. Jul 26, 2021 at 11:59 AM
    rimfire7
    beth
    I modded. its lifted.
