Warrenty vs. Not Covered
Discussion in '2nd Gen. Tacomas (2005-2015)' started by stryder, Mar 28, 2010.
  1. Mar 28, 2010 at 10:52 AM
    stryder
    stryder [OP] Member
    I am about to buy my 1st Tacoma (with a 3 month warrenty) - It's an 05 with the window "ballon squeak" noise at 65-75 mph that has been documented on other threads on this site.
    In these threads it has been documented that owners were able to get the noise fixed under warrenty. However the dealer, that I am buying that Tac from, has said that Toyota said the will not fix it under warrenty.
    I don't quite understand the process. Isn't there alraedy a list that Toyota maintains of what is/is not covered under warrenty?
    Is there a way I should bypass the dealer and go directly to Toyota?
    In general, what is the best way to get a dealer / Toyota do what they should, fix a known problem that should not exist in a Tacoma under warrenty?
  2. Mar 28, 2010 at 10:59 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    No- It shouldn't have the problem if the original owner had the problem and took care of getting it fixed. You are paying for the car at this point-not for the warranty. Toyota is only on the hook for so long in regards to repairs- which is why the warranty is for a specific period.
    All that being said- You can buy the truck and 1) Try to get it fixed by a dealer for free, or pay the dealer to do it. 2) You can look up the TSB here and try the fix yourself.
  3. Mar 28, 2010 at 11:00 AM
    choptop
    choptop Molōn labe!
    Scott
    Austin, TX
    2014 4Runner TEP
    Tell the dealer to fix it or no sale (but be prepared to walk away from the deal if they say no).
  4. Mar 28, 2010 at 11:14 AM
    stryder
    stryder [OP] Member
    Sorry - I should have mentioned, that as it is "certified", it has a 3 month bumper to bumper warrenty. The dealer says this is a full warenty but they also say that Toyota said this is not a warrenty repair. Which from other posts, it has been shown that Toyota will fix this under warrenty.
    So how do I get them to honor thier warrenty as they have in the past with other owners?
  5. Mar 28, 2010 at 11:17 AM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    If it's a 3 month bumper-to-bumper warrantee, then they need to fix it FREE as warrantee work.
    Unless they can prove to you in the fine print that they don't have to fix it free.....then they are required to fix it.
    If they don't fix it....than DON'T BUY THE TRUCK. Go elsewhere!! That dealer/dealership isn't standing behind their products/warranty.
  6. Mar 28, 2010 at 11:18 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    The "certified" warranty is from the dealer- It is NOT the Toyota Corporate warranty. Additionally, most of the TSBs say "3yr/36K warranty" in them. So even the first owner past the original warranty but with an extended warranty can (and probably will) get turned down.
    Best you can do is ask...If they say no-The discussion is over with them.
  7. Mar 28, 2010 at 11:20 AM
    dexterdog
    dexterdog My pee parts itch
    Oly WA
    2012 F150
    You mean this warranty?
    This is quoted straight from Toyota's website. I would say the squeak is related to a defect in materials or workmanship. You can either take the TSB to the dealer and tell them you want it fixed before purchasing and if not you'll walk or try to fix it yourself.
