Warranties and Mods question
Discussion in '3rd Gen. Tacomas (2016-2023)' started by rosebud, Jul 9, 2018.
  1. Jul 9, 2018 at 12:27 PM
    rosebud
    rosebud [OP] Love that transmission!
    SE Texas
    2017 TRD OR
    Stock suspension, stock wheels, stock bumper, stock, stock, stock, dammit!
    I am shopping for a new truck, and almost grabbed a left over new 2017 from my local dealership, but before I could get over there, they put a ton of mods on it, which priced me out of buying it. So, I am working on talking them down on a 2018 4x4 TRD Offroad that won't come with many mods. I asked the guy about adding mods myself, and he said adding third party mods would void the warranty. Do most of you get your mods from the dealership when the truck is still under warranty, or is there a work around? The dealership is so expensive!
  2. Jul 9, 2018 at 12:36 PM
    necrodiety
    necrodiety Well-Known Member
    Orlando
    2018 Silver TRD Sport
    OV Tune, Bakflip F1, Redline hood struts, faux pro headlights and tails, Meso: bucket, map and dome lights, fuse cover.
    Mods don't void warranty unless the mod causes the problem. In other words, your lift won't void a warranty claim with the AC because the two have nothing to do with each other. But if your problem is directly related to the mod, they won't cover it.
  3. Jul 9, 2018 at 12:41 PM
    JJ Customs
    JJ Customs Supreme Leader!
    Jay
    NV
    Silverado Crew Cab Z71, 5.3 made from real Tornado's!
    A few additions to make me feel cool.
    Pro tip: Keep the stock parts you replace so if you have a big enough issue you can return it to stock and get the warranty work no matter what. I have never had a dealer turn down a warranty due to a modification I have done. This is just the dealer trying to get you to pay 4 grand for a spacer lift. and 3 grand for wheels and tires that cost $1,600.
    Long story short the burden of proof is on the dealer, to turn down a claim they must prove your modification caused the failure.
  4. Jul 9, 2018 at 12:49 PM
    OnHartung'sRoad
    OnHartung'sRoad -So glad I didn't take the other...
    Somewhere in the Mojave Desert...
    2017 Tacoma OR 4x4 (formerly 2002 OR 4x4, 1995 4x4 4Runner, 1985 4x4 Toy PU) ... and RIP’s (rust in pieces) to a Bronco II 4x4 & S10 Blazer 4x4
    A lot of us went ahead and put on our own mods partly because there’s a Federal law protecting our warranty from indiscriminate cancellation without cause. It does not allow a dealer to simply deny your warranty by just saying so, they have to prove and provide a explanation to you how your mod caused damage to void their warranty:
    https://en.m.wikipedia.org/wiki/Magnuson–Moss_Warranty_Act
    The law even protects your warranty if you remove those “warranty void if removed” stickers.
  5. Jul 9, 2018 at 12:50 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
    Lift Kits and Your Factory Warranty
    Many truck owners are understandably concerned about how a leveling kit or lift kit will effect their warranty. There are two answers to this question:
    1. The law protects vehicle owners. The Magnusson-Moss act makes it illegal for an auto manufacturer or auto dealer to void a warranty just because a vehicle has been modified. The only way that a vehicle warranty can be effected is if the lift or leveling kit is the direct cause of a failure.
    2. Some dealers are “cooler” about lift kits than others. Some Toyota dealers view themselves as the keepers of the sacred warranty flame, and they refuse to warranty anything unless a customer yells and screams. Other dealers, wise to the ways of the world, embrace owners who install lift kits and even install after-market lift kits themselves. If you can do your new vehicle service work at a dealer who sells brand-new lifted trucks, you’ll probably never have a warranty argument about your lift kit.
    Resource: Learn more about your legal protections warranty rights.
    Source: http://www.tacomahq.com/66/tacoma-leveling-lift-kit/
  6. Jul 9, 2018 at 12:52 PM
    tcjacado
    tcjacado Well-Known Member
    Dealing with a issue now, my power steering is done and they declined warranty due to lift. Estimate to fix $2447.00
    shakerhood likes this.
  7. Jul 9, 2018 at 1:00 PM
    OnHartung'sRoad
    Sorry! You may need a good warranty lawyer for that, but could win it. How did they deny it, just saying so? Did they give you any details explaining how it caused the damage as required?
    Part C of the law (Waiver of standards) states that: “The performance of the duties under subsection (a) of this
    section shall not be required of the warrantor if he can show that the defect, malfunction, or failure of any warranted consumer product to conform with a written warranty, was caused by damage
    (not resulting from defect or malfunction) while in the possession of the consumer, or unreasonable use (including failure to provide reasonable and necessary maintenance).”
  8. Jul 9, 2018 at 1:18 PM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    285's will void a power steering rack or pump warranty. It can easily be shown the constant increased pressure and load caused by the larger than stock tire. While the MM Act is good for consumers, it still requires common sense.
    For example, if you put on 285's and your radio fails, MM is there to protect you. If you put on 285's and your power steering goes out, then it gets murky quick. It's easy for Toyota to prove the 285's were a contributing factor. It's hard for the consumer (even with a lawyer) to prove it was not the cause. Plus, you will burn through the cost of a new PS pump really quick if you hire an attorney and lose.
    So, MM Act helps but it does not replace common sense. If you throw a lift in the mix, then it is no problem for Toyota to deny warranty on most, if not all of your suspension and drivetrain.
    Omar RVA and shakerhood like this.
  9. Jul 9, 2018 at 1:21 PM
    JJ Customs
    Jay
    NV
    If your power steering fails with 285's, quickly mount 265's before you take it to the dealer.
  10. Jul 9, 2018 at 1:26 PM
    OnHartung'sRoad
    Ah, good points. And I meant within reason. Also, there are lawyers who work on contingency if the pie is big enough, but for a warranty issue below $10k, youd only be in small claims and could only use their advice. I got help from one and collected a lot on each call, all 15 of them, from a robocalling collection agency that kept calling my phone for someone who had the number before me!
    hiPSI[QUOTED] likes this.
  11. Jul 9, 2018 at 3:15 PM
    tcjacado
    Yes, denied by just saying so, telling me to call corporate if I like, but as soon as they see or hear lift. Warrany gets voided according to service manager.
    No 285's here.... running the stock wranglers from 265/70/16.
    Icon 2.5 with maxtrac spindles in the front and a full steel winch bumper from go rhino.
    I am in no mood to fight corporate about this piece of shit that has given me nothing but headaches and problems.
    hiPSI[QUOTED] and sdsurfer like this.
  12. Jul 9, 2018 at 3:26 PM
    OnHartung'sRoad
    What state are you in? Definitely make some calls, sounds like you may have cause...
    tcjacado[QUOTED] likes this.
  13. Jul 9, 2018 at 3:27 PM
    tcjacado
    Same fucked up state you live in.:anonymous:
    sdsurfer likes this.
  14. Jul 9, 2018 at 3:29 PM
    sdsurfer
    sdsurfer @ODNAREM life...
    Dirk
    San Diego
    DCSB TRD 4X4
    5100s/OME 888s. Dakar leaf pack. Total Chaos UCAs. DeMello Sliders. BAMF Recessed Grille. Prinsu Cabrack and Toprack.
    Good luck Jay... :fingerscrossed: I do not envy your situation... :facepalm:
  15. Jul 9, 2018 at 3:29 PM
    lynlan1819
    lynlan1819 Well-Known Member
    Tacoma
    Lifted
    What year is your truck,and what problems are you having besides the pump?
  16. Jul 9, 2018 at 3:30 PM
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    Uh Oh... Look out for a long list... :crapstorm:
    tcjacado likes this.
  17. Jul 9, 2018 at 3:31 PM
    lynlan1819
    Tacoma
    Lifted
    So are you saying 3 rd gen suck.
  18. Jul 9, 2018 at 3:32 PM
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    No. I have a 3rd Gen and love my truck. I have 42k miles on it and have been very lucky (so far). Jay has had nothing but problems with his truck...
  19. Jul 9, 2018 at 3:34 PM
    sdsurfer
    Dirk
    San Diego
    DCSB TRD 4X4
    Jay has had his diff leak (at least twice). They had his truck in the shop for several weeks for that. He had the 3rd brake light leak (needed the headliner replaced). And I know he's had a few other problems in addition to the steering problem he's now dealing with.
  20. Jul 9, 2018 at 3:36 PM
    OnHartung'sRoad
    Jay- well, along with the nation’s most cars on the roads, we certainly have a lot of lemon law lawyers out here. Good luck!
    tcjacado and sdsurfer like this.
