Warning for high trans fluid temp
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Taco4cg, Dec 12, 2022.
  1. Dec 12, 2022 at 6:08 PM
    Taco4cg
    Taco4cg [OP] Member
    2018 Tacoma SRS
    Appreciate any feedback or help. My 2018 Tacoma shut off at an intersection and I got a warning for high trans fluid temp. Took it to a dealer and they found a code for P1603 - stall code. They kept it for a few days and couldn’t find anything wrong. Picked up my truck and it happened again 2 days later, at the same intersection and about the same time of day. It happened after a cold start and about 1-3 miles afterwards around 8:20am / cold morning (54 degrees). The street was downhill but not too steep. Took the truck to another dealer. They’ve had it for over a week and drove over 100miles and could not duplicate the problem. So frustrated to have to go pick it up and wait for it to happen again and hope I get a code that will give them more info. This dealer even contacted Toyota engineers who gave them all kinds of things to check and everything checked out fine. This particular truck did have a recall for the fuel pump in late 2020.
    Any ideas based on the conditions of when the stall took place? Appreciate feedback. Thanks
  2. Dec 12, 2022 at 6:18 PM
    HondaGM
    HondaGM Call sign Monke
    James
    South-Pole, Alabama
    2023 access cab V6
    Has the fuel pump been replaced ?
    Taco4cg[OP] likes this.
  3. Dec 12, 2022 at 6:20 PM
    rnish
    rnish Well-Known Member
    Tacoma 2nd gen
    Get an OBD2 reader. Something like a Scangauge2. You can monitor the transmission temperature directly.
    cryptolime and Taco4cg[OP] like this.
  4. Dec 12, 2022 at 8:24 PM
    mattleg
    mattleg Well-Known Member
    Kansas
    2020 OR DCSB AT 4WD
    High trans temp warning is normal after a stall, a symptom, not the cause.
    BigWhiteTRD and Taco4cg[OP] like this.
  5. Dec 12, 2022 at 11:20 PM
    Taco4cg
    Taco4cg [OP] Member
    2018 Tacoma SRS
    Thanks for your replies.
    Yes, there was a recall and fuel pump was replaced in 2020. I bought this truck in January of this year. Only 37k miles.
    Pretty strange the stall happened the same distance and time within a week. Would love to know what’s up with it. Possible for a replaced fuel pump to give out after 2 years?
  6. Dec 13, 2022 at 8:39 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    this is what i use with the free ios "Car Scanner" app. you can get the post-converter and pan temps with it.
    https://www.amazon.com/Veepeak-OBDCheck-Bluetooth-Diagnostic-Supports/dp/B073XKQQQW?crid=2A12ETWIHIZHH&keywords=veepeak&qid=1670949549&sprefix=veepeak%2Caps%2C77&sr=8-1-spons
    works great, although may be a good idea to unplug it when not in use, as it still draws some power. But i've left it plugged in for a week while on vacation and my truck still started right up.
    prerecordedlive likes this.
  7. Dec 13, 2022 at 8:45 AM
    cryptolime
    Wilmington, NC
    2021 SR 4x4 2.7L
    it sounds like an electrical issue. could be faulty wiring to the fuel pump or others have found they needed to replace the crankshaft position sensor
    https://www.tacomaworld.com/threads/high-transmission-fluid-temp.771676/
    https://www.tacomaworld.com/threads/high-transmission-temp-warning-stalling-in-4lo.459469/
    parts:
    https://www.rockauto.com/en/catalog...1741,ignition,crankshaft+position+sensor,7196
    Taco4cg[QUOTED][OP] likes this.
  8. Dec 13, 2022 at 9:53 AM
    Taco4cg
    Taco4cg [OP] Member
    2018 Tacoma SRS
    Yes, it was replaced from a 2020 recall. Ironically, I just found a postcard I received a while back about a class action lawsuit against Toyota for faulty Denso fuel pumps. Not sure if my replaced fuel pump is this brand or??
  9. Dec 13, 2022 at 9:55 AM
    Taco4cg
    Taco4cg [OP] Member
    2018 Tacoma SRS
    That’s what the dealer said. Would like to now what the issue is. Unfortunately they can’t duplicate the problem.
  10. Oct 6, 2024 at 7:59 PM
    myn75
    myn75 Well-Known Member
    Nor Cal
    2021 TRD Off-Road 4x4 DCSB, 1996 4runner SR5 V6 4x4 auto
    ARB OME BP-51 2”, TJM sliders, AT3Ws, Diode Dynamics SS42"
    This just happened to me today, 4lo rolled back a bit on slick granite. Very hot day and the truck stalled and threw a AT overtemp.
