WARNING - DON'T USE PEEL AND SEAL (or ROOFING Materials) FOR SOUND DEADENING!!! + How to Remove
Discussion in 'Audio & Video' started by mbrogz3000, Aug 7, 2017.
  1. Aug 7, 2017 at 8:07 PM
    mbrogz3000
    mbrogz3000 [OP] Well-Known Member
    Northern NJ
    2020 Toyota 4Runner Limited
    Suggest making this a sticky - DON'T USE PEEL AND SEAL for sound deadening!!. Read my story below. So about 2 years ago, I started sound deadening my doors and back wall in the double cab with Home Depot's Peel and Seal, and also another similar material from Lowes. I never did the floor or roof. Seamed like it was an ok idea - lots of 'people on the internet' saying there is no smell and that the stuff keeps well against the surface, and it was cheap! About 1/4 cost of normal sound deadening material. I did a great job of applying it too - looked ok and significantly deadened road noise as a result.
    Well beginning last summer of 2016, I started getting smells, but I drive with the windows open, and the cabin would air out in less than a minute or so. Didn't address it. During the fall and winter, since temps are lower, there wasn't a smell. No headaches or sinus issues either btw.
    This past March 17, my job started requiring more travel from me - so my truck sometimes remains parked in a wide open controlled lot in the sun for sometimes weeks on end. When i get back, even in lower temperatures, there would be a musky tar smell in the cabin. It would clear out in a few minutes with the windows cracked or the HVAC running. Still no headaches or sinus issues either, but started raising this problem on my priority list. The smell is worse than last summer, but it clears out rather fast.
    Today, I finally removed the door panel and speaker to peek into door - lots of peel and seal material sliding downwards from gravity and hot temperature, and tar drippings in certain areas. WTF!!! Yep, I made a big mistake - learn from my mistake and don't ever use Peel and Seal for sound deadening!
    Now for the remediation - I need to rip out my door panels, speakers, sub box, and amp rack probably for a few weeks while I remove the crap and clean the residue adhesive. Which means no stereo for a while. Thankfully - removing Peel and Seal isn't too bad and requires:
    1. Heat Gun + manually peeling the material off and throwing it into the trash.
    2. MINERAL SPIRITS sparingly sprayed onto the remaining brown residue surface from the Peel and Seal
    3. MINERAL SPIRITS applied to a heavier duty rag or blue paper towel
    4. With a light wipe, The adhesive residue effortlessly wipes off like magic! (This was the part I was extremely worried about)
    5. After all the surfaces of an area are clean, use a clean rag to quickly clean it again with MINERAL SPIRITS and then Denatured Alcohol.
    Then immediately apply a real sound deadener material. I'll probably be using raamat.
    Do it right the first time - don't cheap out and use the right material!
    Pervy and 20RustyTaco06 like this.
  2. Aug 8, 2017 at 4:36 PM
    rob feature
    rob feature Tacos!
    Colorado
    2003 4x4 V6 X-Cab SR5
    Shocks. Pegs. Lucky.
    Thanks for this mbrogz. Sorry you had to find out the hard way, but hopefully this will save someone the headache as I still see people using it.
    On new stuff, do yourself a favor and read at least the last post in this thread. The entire thread is chock full of goodies, but it's summarized in the last post. If you can wait a bit, there's a test in progress of MLF, CCF and other decouplers. The guy doing it has the resources of Eminence as well as a few other solid minds in the hobby at his disposal so expectations are high.
    wilcam47 and skyking3 like this.
  3. Aug 10, 2017 at 8:45 PM
    paranoid56
    paranoid56 Well-Known Member
    San Diego
    14 double cab taco
    also check out second skin, i moved to that after using raamat. seems to work much nicer.
  4. Aug 11, 2017 at 3:44 AM
    rob feature
    rob feature Tacos!
    Colorado
    It's included in the testing referenced above. It performs okay, but for the price there are better dampers.
  5. Aug 11, 2017 at 8:29 AM
    paranoid56
    San Diego
    14 double cab taco
    man, that site is hard to read. for the price the second skin was better for me as i also didnt pay retail but dealer prices (sorry i dont sell it) so it still came out much cheaper. I used raamat and the Knu stuff in the past and i will say the knu was nicer then raamat, but you can usually find raamat for much cheaper with coupons
  6. Aug 11, 2017 at 9:37 AM
    nzbrock
    nzbrock Well-Known Member
    Noah
    San Marcos, TX
    99 TRD Prerunner 3RZ
    There are different kinds of "peel and seal" at HD and Lowes. Some contain asphalt, and some are purely butyl. Do you know which kind you used exactly?
  7. Aug 11, 2017 at 10:10 AM
    mbrogz3000
    Northern NJ
    Never knew of the differences when I was purchasing the stuff. I'm pretty sure it's asphalt based after removing some of it...lots of tar drippings/runs like I said. It's a f'ing mess is some areas.
  8. Aug 11, 2017 at 3:52 PM
    rob feature
    rob feature Tacos!
    Colorado
    You must be on mobile. It's impossible to use on mobile. I still use computers for such things.
  9. Aug 11, 2017 at 3:58 PM
    rob feature
    rob feature Tacos!
    Colorado
    No worries, not looking to buy 2nd skin. I don't care for the way the owner conducts business.
    Ya, Knu Kolossus is good stuff. I'd personally use it or Sound Deadener Showdown for a damper.
  10. Aug 13, 2017 at 6:07 AM
    mbrogz3000
    Northern NJ
    what about NVX deadner? 90 mil, 40 sq ft for $100 (free shipping)
  11. Aug 13, 2017 at 6:18 AM
    rob feature
    rob feature Tacos!
    Colorado
    I've only read a little about it but IIRC it has heat tolerance and QC issues. There are many proven great performers out there - you should know by now this is a bad place to try & save a few bucks :p. You don't need full coverage either - as little as 25% will do it with a good damper and strategic placement.
  12. Aug 13, 2017 at 6:50 AM
    127.0.0.1 AKA ::1
    /etc/hosts
    2013 NBM AC 4.0 4x4 Auto OR
    if it doesn't indicate a use for automobile sound deadening, do not use it
    a lot of adhesives and materials are toxic when they outgas, and vehicle temperatures in the sun will
    make nearly anything outgas
    toxic, mutagenic, cancerous...don't even think to install anything other than
    that which is specifically designed for automobile sound deadening usage
    cliffyk likes this.
  13. Oct 19, 2017 at 2:19 PM
    kgarrett11
    kgarrett11 Master Yoda
    Garrett
    CA desert
    2015 DCLB
    I've had no issues with Noico
  14. Oct 21, 2017 at 7:16 AM
    Dp1114
    Dp1114 Well-Known Member
    If your going to try cheap floor underlayment materials work well with some spray adhesive.
  15. Oct 27, 2017 at 11:35 AM
    ThatguyJZ
    ThatguyJZ Instagram: thatguyjz
    Jim
    TRIAD, NC
    2014 MGM DCSB 4x4 TRD Off Road
    A TRD OR built into a Baja/PRO hybrid
    LOL, man I feel for you. It's funny you mention this because I used a small amount of this too in my doors and noticed the same thing when I took my door panels off the other week to install new speakers. The higher stuff had slid down from the heat. Thanks for the heads up on Mineral Spirits. I'll prolly go back in on a rainy day and clean that mess up.
  16. Nov 6, 2017 at 3:23 AM
    CodyH.
    CodyH. Well-Known Member
    Cody
    Arizona
    '17 Inferno TRDORDCLB4x4, '99 SC 4x4 5 spd
    @kgarrett11 how hot does it get where you live? I live in AZ and I just ordered some Noico 80 mil yesterday. How long have you had that in your Tacoma?
  17. Nov 6, 2017 at 7:36 AM
    kgarrett11
    Garrett
    CA desert
    2015 DCLB
    it can get over 120. Had it about a year, no issues.
  18. Nov 6, 2017 at 12:48 PM
    CodyH.
    Cody
    Arizona
    Oh ok. Sounds similar to the climate here then. I guess I won't worry about it. Thanks!
  19. Nov 6, 2017 at 12:51 PM
    JimboAnz
    JimboAnz #OldNorm
    Jimbo
    Charlotte (Cornelius) NC
    2020 Ford F'in Ranger
    We call it peel n leak in the waterproofing biz
  20. Apr 23, 2024 at 4:14 PM
    Whitetail_warrior
    Whitetail_warrior New Member
    Jacob
    1998 ford f series
    Stock
    Ive had peel and seal in .y truck for going on 5 years now and never had any problems with smell and my tuck has no shade. Its literally designed to be applied to a roof. You have any idea how hot shingles get in the middle of summer? Tou guys can push your favorite products but dont do it at the expense anothwrs because you did a bad job applying it.
