Warn Winch 9.5xp VS M8000 motor swap?
Discussion in 'Off-Roading & Trails' started by skygear, Dec 5, 2012.
  1. Dec 5, 2012 at 5:55 PM
    skygear
    skygear [OP]                    
    negativity.
  2. Dec 6, 2012 at 1:54 AM
    itsakeeper
    itsakeeper Well-Known Member
    nova scotia
    2012 SR5
    you should be able to look at the part no's on the warn site for the motors - (look for the parts lists) if they are the same you should be good, if not then most likely the shafts may be different on the motor
  3. Dec 6, 2012 at 9:03 AM
    Socalduckslayer
    Socalduckslayer Pelfreybilt Off-Road
    Tyler
    San Diego, Ca
    12 Tacoma
    Odds and Ends
    I don't know how power hungry the m8000 is but I can tell you from experience that the 9.5xp is fast, strong and hungry. If you ever have to make a hard pull and cannot have engine running you will need more than just one battery.
  4. Dec 6, 2012 at 1:14 PM
    itsakeeper
    nova scotia
    2012 SR5
    #1 you ask if they are interchangeable and then you state above that they are completely different so how can the answer be Yes ??
  5. Dec 7, 2012 at 10:20 AM
    Chickenmunga
    Chickenmunga Nuggety
    Keizer, Oregon
    08 TRD Offroad DC 4x4 with stuff
    All the normal TW BS
    One thing to consider is that you are probably voiding the lifetime warranty, which makes part of these things so spendy.
  6. Dec 7, 2012 at 1:12 PM
    Chickenmunga
    Keizer, Oregon
    1 year on electrical
    lifetime on mechanical
    only works for original purchaser and is voided by modification.
    I wasn't aware you hadn't bought the winch new... sorry.
  7. Dec 7, 2012 at 1:43 PM
    itsakeeper
    nova scotia
    2012 SR5
    m8000 shouldn't be that expensive - I'd shop around before spending the cash on a swap that may/may not work
  8. Dec 7, 2012 at 7:07 PM
    TacoDell
    TacoDell Truck ~n~ Tow
    SoCal
    '00 Tacoma SR5 4X
    Donahoe CO's, Deaver leaf paks, Lockright Locker, All Pro body armor ( sliders, front and rear bumpers ), All Pro under belly skids, Warn M8K w/Masterpull synthetic line, Dual Optima battery system, 4 ea LightForce Striker 170 offroad lights, 8 ea wired rock lights, and plenty more I'm sure
    subscribed for the outcome of it ;)
  9. Dec 9, 2012 at 5:15 PM
    ImplicitlyAlberta
    ImplicitlyAlberta VA6DCO
    David
    edmonton
    06 SR5 Trail Rated, 16 Tundra CM TRD
    TC Uni Uppers, TC race lowers, TC shock tower gusset/ secondary shock hoop, Modified Pelfrey rear shock relocate, ATO shackle flip,radflo hydro bumps front and rear, Radflo 2.0 CO/ 14" rear, Arb rear air locker, ARB front bump/m8000, Road armor rear bump/m8000, FJ TransCase/ Twin sticks....other shit.
    Ummm.... whats the reason for the motor swap. Someone said power consumption, not entirely sure what the arguement here is about. I have 2 M8000 no issues ever.
    Are you aiming to get the power/strength from the other motor?
    I would just get the complete package warn factory built, to ensure reliability and all.
