want to run 33's and a good look
Discussion in 'Suspension' started by rwmtaco, Jun 17, 2008.
  1. Jun 17, 2008 at 7:46 AM
    rwmtaco
    rwmtaco [OP] New Member
    I am new to the taco world and am interested in running 33's on my '05 sport ext cab...what would you all recommend for a lift and back spacing combo?
  2. Jun 17, 2008 at 7:51 AM
    Khaos
    Khaos Big Member
    Bryant
    Jacksonville, Florida
    2011 DC TRD SPORT Prerunner
    3” spacer lift, 285/75/17 KO2, Spidertrax 1.25” spacers
    Your gonna need atleast a 3" lift ( ). Your also gonna have to do quite a bit of trimming to get 33s to fit.
    I wish I could help you on the backspacing, but since I am gonna run stock aloys with my 285s I havn't looked into aftermarket wheels.
    Check the link in my sig.
  3. Jun 17, 2008 at 8:16 AM
    luk8272
    luk8272 Poodoo
    Lucas
    Southern Louisiana
    07 Silver4dr. 4x4, V6 Shortbed
    5% Tint, Bug flector, vent Visors, Removed secondary air filter, Rear Spring TSB w/ Wheeler's Add A Leaf HD Pack, Icon 2.0 rear shocks, Toytec 3" lift up front with Total Chaos UCA's, Debadged, Billet Grille,TRD Offroad rims/17x9 Pro comp 6001 rims, Duratracs 265/75/16 or 285/70/17, Fog light anytime mod, Tailgate hose clamp mod, Pro-dry AFE filter. Extended Differential Breather, ABS on/off, 6000k LEDs from CSJumper, heads/fogs, ScanguageII, Devil horns, Devil horns on third brake light, Mounted 60" Highlift, Mounted Tool Box, Wet Okole Front/Rear Seat Covers, TW sticker, Midland Handheld CB,Painted engine cover, Revenge Fab Sliders, ARE Topper, Weather tech Floorliners, Camper shell, ultimate headlight upgrade. URD -3° exhaust cam gears, .5" XTP Intake spacer. Custom dents.
    4.5" of backspacing and trimming isn't all that bad. Removed my mud flaps and trimmed that platic box in the very front of the wheel wells with razor knife then used a drimel to trim any other areas that rubbed. If I wasn't offshore I would go take you some pics. I'll be home monday hopefully.
