Want tires to stick out more
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Lilbanas79, Aug 21, 2022.
  1. Aug 21, 2022 at 7:06 AM
    Lilbanas79
    Lilbanas79 [OP] Member
    Elizabeth
    2022 tacoma sr5
    Update: I have a 2022 sr5 and im looking to get my tires to stick out more as i dont like how they sit stock. I dont have a lift nor leveling kit dont prefer to put one on it, want to stick with more stock size tire and rims, willing to put spacers on it so what would be the best size, brad, and tire size keeping the original stock rims which have the 265/70/16 tires on them now?
  2. Aug 21, 2022 at 7:10 AM
    Ajsmith1990
    Ajsmith1990 Well-Known Member
    2016 Quicksand Tacoma OR DCSB
    Can always start out with some wheel spacers
  3. Aug 21, 2022 at 7:11 AM
    Terraj66
    Terraj66 Well-Known Member
    las vegas
    2016 DCSB 4x4 sport. super white
    You can add spacers or get new rims with a negative offset. But whoever told you that you can fit 285s on stock suspension is setting you up for failure. Good luck going over speed bumps with that setup, let alone do a trail.
    hiPSI likes this.
  4. Aug 21, 2022 at 7:12 AM
    hiPSI
    hiPSI Laminar Flow
    South Carolina
    2024 Long Tundra
    Depending on how much you want your tires to stick out, different mods will have to happen.
    If you go to 285 size, you can't stick out much more than stock because you will rub, so you gotta lift and cut.
    If you want to stick out an inch with stock size, you can do that with no mods.
    More than an inch, you gotta lift and cut.
  5. Aug 21, 2022 at 7:13 AM
    AtomAnt
    AtomAnt Well-Known Member
    Adam
    South Cackalacky
    2019 TRD Sport
    0 offset will put your wheels about flush with the fender flares. -12 offset will put them slightly outside of the flares. You’re more likely to have rubbing with -12 but mine was minor with 275/70/17s and Eibach 2” lift.
    svermilyea likes this.
  6. Aug 21, 2022 at 7:30 AM
    Lilbanas79
    Elizabeth
    2022 tacoma sr5
    Im not doing any off-road just pavement driving what size offset would have to be done to get them to come out to say the fender flares?
  7. Aug 21, 2022 at 7:38 AM
    Terraj66
    las vegas
    What atom ant said, -12 should be right where you want them. Honestly I would not have the headache of 285s if you’re just gonna do paved roads. Losing mpg and making the truck feel sluggish is not a good trade off if you’re not taking it on trails. Go with 265 ats and call it a day. Ultimately, it is your truck and do what you want. Keep us posted!
    the pic is with stock suspension on 265 ko2 tires. These are 17inch rims with a 0 offset tho. I’m just referencing the tire size and not the poke
  8. Aug 21, 2022 at 7:40 AM
    Lilbanas79
    Elizabeth
    2022 tacoma sr5
    I would like them to come out to about the fender flares or a little less not looking to do any mods really just new rims and tires so looking for the best size tires and offset rims or whatever to achieve that without doing anything much else
  9. Aug 21, 2022 at 7:44 AM
    bad_guac
    bad_guac Actually, this IS my first rodeo...
    Tyler
    Mesa, AZ
    '21 Army Green DCSB TRD OR
    Accutune stage 4 Adjustable King 2.5's w/resi's All the meso Diamondback HD Method 701's 17x8.5" 285/70R17 Diode dynamics fog/ditch/stealth lightbar Sliders RCI skids OTT tune Total Chaos bed gussets Etc...
    20211017_154256.jpgI'm running 265/75r16 with 1.25" spider Trax spacers
    71tattooguy likes this.
  10. Aug 21, 2022 at 7:52 AM
    71tattooguy
    71tattooguy Well-Known Member
    Dino
    Petaluma , Ca (707)
    2019 DCLB TRD OFF- ROAD
    Kings 2.5” front and rears from Accutune / ICON RXT LEAF PACK black badges doors and tailgate / method 315 / 255/85/16 Yokohama G003 / magnaflow exhaust , axle dump / meso int delete kit / meso led map lights / dome lights / wheelers front super bumps / accutune Flip kit with spacer and new bumps / Cali raised fog light pods / Cali raised ditch lights / RCI FULL SKIDS / SLIDERS / RCI rear bumper / rigid backup lights / tuned on 4.88’s
    285’s will not work without a lift and will rub. Also will be close UCA’s. 265’s with wheel spacer will give you the stance you are looking for.
  11. Aug 21, 2022 at 8:02 AM
    FL_TRD Sport
    FL_TRD Sport Suffering from Severe Wallet Drain
    Hector
    Port St. Lucie, FL
    2021 TRD Sport MGM DCLB (Sold)
    KDMax Pro 10.0, Form Lighting Tail Lights, and more
    I got the 4Runner pro wheels which took me from a +30 to a +4mm offset. The stance is a bit more aggressive and doesn't have the additional complications of a big negative offset. The suspension is completely stock, as are the Toyo A30s. When these wear out they will be replaced Michelin LTX AT2s.
  12. Aug 21, 2022 at 8:33 AM
    71tattooguy
    Dino
    Petaluma , Ca (707)
    None just run spidertrax or Bora. Follow specs and your good
  13. Aug 21, 2022 at 8:36 AM
    Lilbanas79
    Elizabeth
    2022 tacoma sr5
    [QUOTE="Lilbanas79, post: 27721551, member:
    What are the risks with wheel spacers if any[/QUOTE]
  14. Aug 21, 2022 at 8:52 AM
    brandon78lusch
    brandon78lusch Well-Known Member
    Brandon
    East Carolina University
    2019 TRD Sport DCSB, 1978 Pontiac Firebird Trans Am
    [/QUOTE]
    You get what you pay for. The cheaper the spacers the more likely they’ll cause you problems
    RIX TUX likes this.
  15. Aug 21, 2022 at 9:03 AM
    Lilbanas79
    Elizabeth
    2022 tacoma sr5
    You get what you pay for. The cheaper the spacers the more likely they’ll cause you problems[/QUOTE]
    What are some good brands as well as a good size to get the tires to stick out more than stock
  16. Aug 21, 2022 at 9:07 AM
    TRD Ted
    TRD Ted Well-Known Member
    2020 Army Green TRD Pro
    I wanted the same thing without any hardware or mods so I got rid of the POS factory tires and installed some Falken Wildpeaks. I was surprised how much different and more aggressive it looked and achieved what I was looking for.
  17. Aug 21, 2022 at 9:14 AM
    Lilbanas79
    Elizabeth
    2022 tacoma sr5
    Those are the tires im looking at getting as well so maybe i should get the tires first and go from there
  18. Aug 21, 2022 at 9:29 AM
    cryptolime
    cryptolime Here to Help
    Wilmington, NC
    2021 SR 4x4 2.7L
    you can add wheel spacers but it will make your truck handle like garbage and put more stress on the drivetrain. if you want to sacrifice drive-ability/handling for cosmetics then go for it.
    bulalo likes this.
  19. Aug 21, 2022 at 9:29 AM
    Lilbanas79
    Elizabeth
    2022 tacoma sr5
    So going with wheels spacers what do you think would be the better size as well as tire size to achieve this?
  20. Aug 21, 2022 at 9:33 AM
    brandon78lusch
    Brandon
    If you're thinking about switching out your wheels in the future, get wheels with like -12 offset (sticks out 1 inch). I don't know too much about wheel spacers other than most of them are wack
