VVT-i
Discussion in '2nd Gen. Tacomas (2005-2015)' started by bobtackett, Aug 23, 2009.
  1. Aug 23, 2009 at 1:20 AM
    bobtackett
    bobtackett [OP] Well-Known Member
    chicago heights,illinois
    4x4 trd offroad package
    3inch suspension,side steps,westin brush guard,carbonfiber hood w/scoop
    anything special about haveing the " vvt-i " in our trucks?if so does toyota offer something of lesser grade?sure this sounds like a dumb question but there is a reason i'm asking ie method to my madness
  2. Aug 23, 2009 at 1:33 AM
    aces2
    aces2 Senior Arshole
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    Flowmaster 40, K&N CAI, RED brake light bulbs, BHLM, Rear dif breather line, Factory Skidplate painted BLACK, DRL's, YELLOW bulbs in Fogs Turn Signals and Marker lights, Custom "Toy Machine" center emblem, Sockmonkey "Nor-Cal" decals all BLACK, Redline tailgate damper and hood sruts, Painted steering wheel emblem BLACK, 12V always on, Foglight mod, 16" Pro-Comp 7089 rims BLACK powdercoated acorn lugnuts, BFG KM2's 285-75-16, Painted exhaust pipe BLACK, BLACK emblems all the way around, Rear BLACK bumper from base model, Radical RED "sport" grille-surround, Factory Toyota Bed extender, RED maglight mounted on each seat's side, TRD ball-type shift knob, Custom mounted Scangauge II under stereo, Aftermarket HU, Hardwired Garmin GPS 260W, TSB w/AAL and 2.5" 5100's, Weathertech floor liners, Removed front mud flaps, 95-04 "4WD" rear mudflaps, 3rd Brake light "TACO", BLACK front lip
  3. Aug 23, 2009 at 1:36 AM
    bobtackett
  4. Aug 23, 2009 at 1:37 AM
    aces2
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    I wanna know too 'tard-o...
  5. Aug 23, 2009 at 1:39 AM
    aces2
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    OMG, am I speaking fucking french?!
  6. Aug 23, 2009 at 1:40 AM
    bobtackett
    are you calling me tardo?thats got to be one of your more intel. 216 posts
  7. Aug 23, 2009 at 1:45 AM
    aces2
    Cody
    Hampton, VA
    08 SR5 RR AC 4x4
    Listen Davy Crockett... I was just subscribing to this post by leaving a reply in the hopes that I too could one day be privileged enough to find out the answer to the very question your pea brain pissed out.
    If this is a problem, politely fuck off and carry-on...
    austin2009 likes this.
  8. Aug 23, 2009 at 1:49 AM
    bobtackett
    dems a whole lotta werds you dun put togeder dare fella.id slow down a bit for you hert yerself
  9. Aug 23, 2009 at 1:50 AM
    bobtackett
    i agree cmack
  10. Aug 23, 2009 at 1:53 AM
    bobtackett
    mom and dad must be asleep while hes using there pc
  11. Aug 23, 2009 at 2:08 AM
    hoosiertaco
    hoosiertaco Well-Known Member
    the popcorn smilie post is used to signify that your waiting to see what happens as well.;)
    we all know what wtf is used for.:p
    please....back to your corners fellas.......a simple missunderstanding with some twisted TW humor.
    hey bob, can't help ya on your question, just wondering what the "method to my madness" was, if you don't mind me asking.:) You must have something up your sleeve....:spy:
  12. Aug 23, 2009 at 2:23 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    I thought the system was implemented more to increase HP and level the torque over higher RPM, no lower. Either way, that's basically it, it adjusts the timing of the valves to either lean out or make it burn a little richer to provide performance gains. I will say it's not as 'profound' as honda's VTECH YO TYPE R!!! stuff, but the truck does seem to have a lot of steady power through the RPM band to me.
    Also, chill guys, no one is retarded here, except me :D
    Also also, I'm sure Chris will set everything straight :D
  13. Aug 23, 2009 at 2:45 AM
    bobtackett
    yea i really didnt think flyboy needed to go from 0 to bunghole in .0 seconds.since we've gotten back to a reasonable conv. i'll explain.since day one of owning my 2nd gen i've thought that the access door was such a blank canvas and really needed something on it.given it alot of thought .i was wondering if "VVT-i" carried enough
    significance performance wise to merrit a chrome badge and after your levelheaded reply i think it does and i'll prob.put one under the rear back corner of the window a couple inches down http://cgi.ebay.com/ebaymotors/TOYO...ies?hash=item4ceaa341a6&_trksid=p4506.c0.m245
  14. Aug 23, 2009 at 3:19 AM
    GotLift37
    GotLift37 Bangers Runner
    North East AL
    07 4Runner 4WD
    2.5" front lift (leeper coilover) 1" body 16" Dick Cepek DC1 Black/polished 295/75/16 General Grabber AT2 Tinted Taillights 5% tint OEM Acura TSX HID Retrofit White LED dash light conversion WMW roof rack
    and for the non honda guys its not v-tech, its vtec (Variable Valve Timing and Lift Electronic Control) vtech is a telephone.....
    sorry I used to be a honda major honda guy.
  15. Aug 23, 2009 at 3:36 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    I know but I can't help but make fun of v-tec any chance I get, being a mitsu/nissan guy myself for the most part.
    Also, while it's valid to put VVT-i badging... it's also... eh I wouldn't but that's me :D To me, something worth showing off performance wise would be say, a TRD Supercharger or something of that nature. That's a badge that pulls it's own weight around, and then some.
    :cool:
  16. Aug 23, 2009 at 3:47 AM
    dalsmthme
    dalsmthme Well-Known Member
    Ithaca, NY
    '09 Double Cab 4X4 SR5
    There isn't a lesser grade offered than the VVT-i. This is just an oil pressure actuated cam phaser. This perticular application only controls cam angle of the intake camshaft, not lift or duration as mentioned earlier. Toyota does have the technology known as VVTL-i.
    Continuously variable valve timing is used to maximize intake at both low and high rpms. Traditionally, cam profiles and timing was set for peak power at high engine RPM. Most driving cycles are not at high rpm duty cycles. Low end torque is sacraficed. VVT allows the timing to be phased to maximize low end torque at low engine rpm and peak power at high rpm with one cam profile. The result is great drivability and high efficiency.
  17. Aug 23, 2009 at 3:47 AM
    bobtackett
    "toyota" wouldnt look right.you already got tacoma on the door [​IMG]thought about trd but thats on the back fender in the form of a sticker,so i started thinking out of the box.unless i spend a couple g's TRD Supercharger wouldnt be relavent.kinda even considered "4X4" in the same 1 by chrome lettering
  18. Aug 23, 2009 at 3:16 PM
    InfidelTaco
    InfidelTaco No better friend,No worse enemy...
    G
    PNW
    Prerunner
    AFE, Fox, Built Rights, Moog, SpiderTrax, Icon progressive, Grabbers
    speakn of vvti, hate to interrupt the discussion of badging, but vvti is great. i really never noticed it before, maybe bc i rarely punch. but i was stuck in traffic last night, and right when it free'd up, i was still stuck behind this retard that was trying to guess what happened. So i punched the throttle to overpass, and it seems that at 4-4.5 rpm, my Taco woke up like an angry beast. i was very impressed. i love my taco. . . . ok gents, im done, back to badging. and oh yah, thanx for listenin.
    G
  19. Aug 23, 2009 at 3:37 PM
    chris4x4
    FlimFlubberJAM
    Tenoe, AZ
    2019 Rubicon 4 Door,
    Bingo!
