VSV Valve Location
Discussion in '1st Gen. Tacomas (1995-2004)' started by iamjustifyd, Sep 7, 2017.
  1. Sep 7, 2017 at 7:29 PM
    iamjustifyd
    iamjustifyd [OP] Well-Known Member
    Sherry
    new orleans
    2001 PreRunner SR5
    I have code P0402 coming on. Came on first time about block and a half from the house, had it tested at O'reilly's. Had read shouldn't be the valve if truck is not warm, probably the temp. sensor. Pulled the negative cable, code went off and about 2 weeks late came back on in about the same location as the first time so with the truck not being warm I changed the temp. sensor. About 2-3 weeks later, I have a motorcycle and ride to work sometimes, CL came back on again in about the same location, same code. From what I've been reading probably not the valve itself stuck open because truck isn't warm and valve shouldn't even be opening but whatever tells the valve to open is faulty. Temp. sensor is already changed so I want to change the VSV. From what I hear this is a bear to do because of where it is located. Anyone have advice...pictures or can lead me to a good video to watch that is similar?
    Thanks!!
  2. Sep 7, 2017 at 7:32 PM
    Bishop84
    Bishop84 Well-Known Member
    It's the vacuum switching valve connected to the EGR.
    Just because the code is triggering doesn't necessarily mean it's the valve causing the issue.
    Best to give it 12v while running to see if it affects idle and opens the EGR valve.
  3. Sep 7, 2017 at 7:40 PM
    rngr
    rngr Aix sponsa
    01 SR5 4x4 2.7L
    Not sure which engine you have, but on the 2.7 it's under the intake manifold. It's the green thing you see in this pic
    And looks like this.
    It is a little aggravating to get to, but doable. Small hands help.
    Taco Phil likes this.
  4. Sep 7, 2017 at 7:47 PM
    iamjustifyd
    Sherry
    new orleans
    2001 PreRunner SR5
    Great, thanks! Same engine, I'll take a look for that tomorrow.
  5. Sep 8, 2017 at 12:58 PM
    Glamisman
    Glamisman Well-Known Member
    This code is a 2 trip code meaning that it will check for proper opperation only after 2 complete drive cycle trips parameter have been meet. Lots of gobbly gook words, sorry, in english it means that the air temp sensor and the coolant temp sensor have to be within 10 to 20 degrees of each other on 2 consectutive starts and this is usually only meet when it sits overnight.
  6. Oct 29, 2024 at 4:38 PM
    Johnny G
    Johnny G Member
    2003 Tacoma PreRunner 2.7 Automatic
    I realize this is an old thread, but I just did the VSV replacement on my 2.7. One thing to make it a little easier in my opinion: There is an accessible bolt on the side of the little metal bracket holding the VSV. Remove that, unplug the electrical and vacuum lines and take it all out together. In your hands you won't be likely to lose the little screw holding the bracket to the VSV and the little tab that locks into the bracket is a lot easier to maneuver when the bracket is in hand. Put it back as one piece and reconnect everything. Could have saved about 30 minutes if I'd figured this out sooner...
    FixMyTaco and ControlCar like this.
  7. Oct 29, 2024 at 8:32 PM
    ControlCar
    ControlCar My Moto: Help & Learn…period.
    Steven
    Sugar Land TX
    1996 Taco 2.4L 2wd Automatic
    Clock Volt meter/LSPV Delete/Hyundai 16’s/FP gauge/after 9months of wrenching ZERO oil leaks
    Thank you for tip! Definitely noted!^^^
