VSC? Yes or NO?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by billas333, Mar 17, 2010.
  1. Mar 17, 2010 at 2:44 PM
    billas333
    billas333 [OP] They Still Love To Hate Me! - T.O.
    Joel
    NorCal
    2008 4x4 Tacoma Sport
    Mods so far: Tube steps from toyota, Bed extender from toyota, Spare Tire lock, Sound System Makeover, Tacoma All-Weather heavy duty rubber floor mats. Rear TSB, Icon Coilovers w/ TC UCA's and 3inch rear block with rear 5100 bilstein shocks, Black Headlights, Grillcraft black grill, Devil Horns from Andres, Black Headlights, Chrome Liquid Metal Gatlins Wheels, 285/70R17 Nitto Tera Grapplers, Wet Okole Seat Covers! Seat Belt Chime Mod, Flowmaster 50 series dual exhaust, Debadged tailgate, TRD Decals, HID hi/low + fogs.
    Hey Guys,
    I have a 2008 TRD Sport 4x4. Curious if I have the VSC for purposes of getting the proper Pro Comp Lift.
    I do not have a light or switch for it, isnt it only on off-road tacomas??
    Thanks
  2. Mar 17, 2010 at 2:46 PM
    Zac808
    Zac808 Custom User Title
    Zac
    Viva Las Vegas
    08 TRD DC SB 4x4
    In my sig
    I 98% sure you don't have VSC. Neither do I and I am TRD off road.
  3. Mar 17, 2010 at 3:10 PM
    The_Hodge
    The_Hodge Volunteer Moderator
    SC
    15 Lariat Sport 5.0L
    u would have the button to the left of the steering wheel w/ the car and the squiggly lines under it if u did
  4. Mar 17, 2010 at 3:29 PM
    ttylerr
    ttylerr Well-Known Member
    Tyler
    Fort McMurray, Alberta
    09 MGM 4Banger 4x4
    5% tint all around, Alpine IVA-W505, 16x8 Mojave Teflon Rims w/Hercules Terra Trac 265/75, Grillcraft Grill, Slimcubby HIDs, Front 5100's @ 0 w/Eibach 1.6" springs, URD Short Shifter, Extang Trifecta Tonneau Cover, Uniden Pro510XL and K30Mag Mount, Relentless Fab Bumper soon to come
    i don't believe so, pretty sure that system came out in '09
  5. Mar 17, 2010 at 3:31 PM
    billas333
    Joel
    NorCal
    Thanks for the info!
  6. Mar 17, 2010 at 3:45 PM
    The_Hodge
    SC
    VSC was optional before then. some folks even had it back in 04 as an option. it has only become a standard since 09. there are people here w/ 05-08 that have it, just not many
  7. Nov 27, 2010 at 9:24 PM
    DJ Derek
    DJ Derek New Member
    Derek
    Delta Junction, AK
    TRD
    so i'm new to the forum and potentially a new taco owner. i'm considering purchasing a used 2005-2008 tacoma. however it's important for me to have VSC for safety considerations (wife will be driving regularly and roads are often icy up here in interior Alaska). from my research, i understand VSC was optional but non-selectable (ie no button) on 05-08 tacos... my question is how do i determine if VSC is included without a button or documentation?
  8. Nov 27, 2010 at 9:27 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    my 07 has it
  9. Nov 28, 2010 at 12:56 AM
    TACOMA TRD
    TACOMA TRD Well-Known Member
    Tom
    PA
    2011 MGM SPORT DC 4x4
    Alpine HU, Apline 6.5 3 way Speakers, Access Cover.
    so does my 07....
  10. Nov 28, 2010 at 1:30 AM
    DevL
    DevL Well-Known Member
    Go do some donuts and see if it kicks in. If you get beeping and feel the brakes pulse you have it.
  11. Nov 28, 2010 at 9:00 AM
    David K
    David K Well-Known Member
    Pala Mesa, California
    2010 4WD Off Road DC
    Not sure on the pre-'09s, but VSC has a beeper and light indicator when it is working... When you turn your key to on (without starting), do all the dash lights come on? Is there a VSC light?
    If you take it in snow or on slippery roads, do some S turns at speed. The VSC will correct any fishtailing of the rear end and alert you with a beep-beep-beep each time (plus the dash indicator light comes on).
    For me, it is a great bit of science on a pickup truck... when the bed is empty on slippery roads it often wants to go sliding around, when making turns, etc. Now with VSC the truck drives like it is in 4WD on wet roads... as far as handling and driving at speed is concerned. I used to put me previous two Tacomas into 4WD on heavy rain days... not anymore with VSC on my 2010.
  12. Dec 2, 2010 at 6:01 AM
    TACOMA TRD
    Tom
    PA
    Whats the difference between VSC and Atrac? Are they one in the same just different wording?
  13. Dec 2, 2010 at 6:50 AM
    The_Hodge
    SC
    now you've done it....wait for the lengthy explainations coming. :laugh:
  14. Dec 2, 2010 at 9:26 AM
    David K
    Totally different things...
    VSC (Vehicle Stability Control) is on all Toyotas now... (Star Safety System) it is a safety feature developed from Bosch that automatically corrects the car/ truck when the rear end begins to slide out when you suddenly try to avoid hitting something while driving at speed... It prevents you from spinning out of control and keeps you going in the direction you want. There is a good video of this posted. My truck no longer spins out on slippery roads or when making fast turns.
    A-TRAC (Active Traction Control) is only on Off Road 4WD Toyotas (2009+ Tacomas) and only works in Low Range... it is a traction enhancement system that puts all available torque to tires with traction by locking a spinning tire to the traction tire with the brakes on that tire... True 4 wheel drive, like automatic lockers front and rear... Only locks when the tire is off the ground or spinning faster than the other tire on the axle. This means steering control is not affected the way it is with locking differentials. With just one tire on firm ground, A-TRAC will pull your truck through. A-TRAC requires the stronger hydraulic brake booster over the standard vacuum brake booster.
    I have a link in my signature to explaining the traction systems and video clips of A-TRAC at work...
  15. Dec 2, 2010 at 9:32 AM
    Kyouto42
    Kyouto42 Iron Beard
    Jake
    Ahwatukee, AZ
    BSP '10 4x4 TRD Off-Road DC
    See build thread in signature
    VSC will help with traction on wet roads... but it's nothing like having 4WD... at all. I can still kick my truck out with VSC enabled if I wish (granted I could do it in 4WD too).
    Honestly, I never cared for the system that much myself. In my G35 I'd start the car and immediately turn it off. On the Taco it's a little less annoying and really seems to go off only on slipping situations. It is handy in the rain, but nothing beats proper driving. My 2008 PreRunner never had it, and I never missed it.
  16. Dec 2, 2010 at 9:42 AM
    David K
    Just so the facts are known... it is TRAC (traction control) that helps with traction on wet roads... this is a limited slip system that uses the brakes instead of the differential hardware.
    VSC uses TRAC, but VSC is only a steering/ stability aid to keep you from spinning out of control. See the video... can someone post the Bosch clip on VSC here?
    TRAC in 2WD works when you excellerate from a stop on wet or slippery roads... The amount of spinning on one tire is reduced and torque transfered to the opposite tire. TRAC in 4WD is a big improvement over the former only open differentials for traction.
  17. Dec 2, 2010 at 1:33 PM
    TACOMA TRD
    Tom
    PA
    Thanks David K....Im going to be reading your sigs.. I did a search, but so much came up, it was confusing.
  18. Dec 2, 2010 at 2:48 PM
    David K
    Let me know if youi need any more details... My link on A-TRAC in my sig is pretty complete with the You Tube clips...
    Remember, normal differentials (open differentials) divide the torque from the drive shaft (engine) to both tires equally. However, if one tire has less traction than the other, the torque is going to that easier to spin tire. This is allowing easy steering, but can get you stuck.
    When a 4WD gets stuck, usually one sees one tire in front spinning and one tire in back spinning. Those two tires had less traction than the other two, so torque went to them. A 2WD stuck has one tire spinning.
    To get unstuck, you want torque going to the tire(s) with traction.
    Limited Slip Differentails were invented so more torque can go to the traction tire when the other one is spinning in a stuck or slippery surface. 'Posi-Traction' is one of the popular limited slip differentails.
    Toyota's TRAC and AUTO LSD use sensors and brakes to slow the spinning tire and that gives torque to the traction tire.
    Locking Differentials were invented so the torque goes equally to both tires, no matter what. This was a great advance to off roading.
    Because no slipping of one tire over the other can happen, steering is difficult. Locking Differentials are recommended only in off road situations to get out of a stuck and no more than 5 mph.
    A-TRAC is a more aggressive traction aid than TRAC that uses sensors to monitor wheel spin and a hydraulic brake booster to prevent any torque from being lost on a spinning tire. The non-traction tire rotation is nearly locked with the traction tire, as a locker does but steering is not affected because the locking is automatic as needed.
  19. Dec 2, 2010 at 3:13 PM
    David K
  20. Dec 2, 2010 at 9:26 PM
    urbanplanner
    urbanplanner Well-Known Member
    washington state
    My 06 off road has VSC without the button. Best way to tell would be to check the dash lights with the key "on". There will be VSC off, VSC TRAC, and the truck with slippery tracks symbol. They only stay lit for a few seconds.
