Volumized trending on gas mileage
Discussion in 'Technical Chat' started by cvillechopper, Nov 19, 2007.
  1. Nov 19, 2007 at 10:45 AM
    cvillechopper
    cvillechopper [OP] Jackass to the masses
    Charlottesville, VA
    12 DCSB TRD Off-Rd 4x4, Roof Rack, Tube Steps
    K&N drop-in air-filter, extra D-rings, Custom Console lock-box, Leather heated seats, Studly Driver
    I've mentioned that I'm a numbers junkie in another thread and that's no lie. It's an addiction really. After seeing the results of the Eco-VPE test that Mav and 007taco did I am really interested in taking these tests to a larger test group and expanding the data collected. Knowing that there are several of us that will end up buying the Eco device to try it out and that there are many more that won't spend the money, here's what I'd like to do if anyone is interested.
    I've got a spreadsheet with all of the necessary data from Mav's test and will be getting the data from 007Taco's test in there shortly as well as starting to add my own. Using the theory of large numbers, the more data we get the better the information produced. To help you don't have to have the system (in fact, we'll need some that don't as a control group). Below is the list of data items I'm asking for. Simply send me periodic updates every tank or 2 with the info and I'll add it in. Then we can start to see the larger trends not only of the VPE, but of all sorts of mods.
    Thanks ahead of time for anyone that helps out. I know this is not exact, but in real science you look for trends and that's what I'd like to do here. There are several variables but we have the chance to reduce their effect through volume.
    Send data in any format you'd like but please include as much of this data as you can.
    username
    truck year
    approximate miles on truck (i.e. 10K, 54K, 110K, etc)
    engine size
    cab
    configuration (TRD-off-road, Pre-Runner, etc)
    secondary air-filter removed (yes or no)
    Stock airfilter or aftermarket (include manufacturer if aftermarket)
    4x4 (yes or no)
    Transmission (i.e. 5-spd manual, 4-speed auto, etc)
    Eco VPE installed (yes or no)
    Stock exhaust or aftermarket (include manufacturer for aftermarket)
    Total miles for a given tank (tank 1 - 220.5 miles, tank 2 - 180 miles)
    Gallons at fill-up (tank 1 - 17 gallons, tank 2 - 14 gallons)
    Any accessories you have that may effect efficiency (i.e. roof rack, Running boards, bull bar, etc - please include manufacturer if possible)
    Towing/hauling for this tank (yes or no)
    *Approximate average speed
    *% highway miles
    *any assorted notes you care to include
    * = not necessary, but helpful
  2. Nov 25, 2007 at 11:54 AM
    Toy4Life
    Toy4Life 668: The Neighbor of the Beast
    Chad
    Slippery Rock, PA
    96 Subaru Outback 2.2 5mt
    92 4Runner SR5 3.0v6 4x4(sold) 02 Tacoma SR5 TRD Offroad 4x4 (sold)
    I just thought of more info you should consider:
    1.)octane rating
    2.)Fuel brand (I bring this up because some places up north put in
    additives in the winter months that adversely affect fuel economy)
  3. Nov 25, 2007 at 2:07 PM
    maverick491
    maverick491 Towing Guru
    South Jersey
    07 4x4 Access Cab, TRD off road, 6 cyl, 6 spd
    Activator III brake controller, Extang Fulltilt toneau, Factory bed mat, Extra D-rings in the bed, 2ndary air filter removed, Garmin Ique GPS, Eco-2, AFE Pro Dry-s filter, USASPEC PA12-toy, Pioneer 3-way speakers, SG II on Blendmount, Gulf States Alarm added.
    Just noting if it was a tank of winter blend should be sufficient. Or more to the point noting if it was pumped between November 1 and April 1 would do as well. ALL brands/stations in cold climate areas are required to pump winter blend during that time period. (federal law)
    Octane rating is a good idea to include though.
  4. Nov 28, 2007 at 9:46 PM
    jonbob1
    jonbob1 Member
    brand spanking new SR5 TRD Tacoma
    nothing yet
    Everyone drives differently. As in "the tire Rack" web site if you review tires and driving conditions, no one mentions how often they turn on the four wheel drive or the the belt sander that they are running while the truck is at idle? using these items effect the MPG of all the trucks. I get about 17 MPG and I am happy for the weight and use of the truck.
  5. Nov 29, 2007 at 1:38 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    I'm happy with my mpg too, but I'll entertain chopper's number fetish. It's no skin off my ass.
  6. Dec 6, 2007 at 7:34 PM
    cvillechopper
    Charlottesville, VA
    Just wanted to thank those that have been sending me data. I've got about 400 tanks of data so far with at least 10 different configurations. I'm hoping to get a few more and put some tables together this weekend.
    Still needing as much data as is out there so keep it coming guys and gals.
    Thanks again
    James
  7. Dec 6, 2007 at 7:46 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    Just emailed tanks #2 + #3
  8. Dec 7, 2007 at 3:35 AM
    cvillechopper
    Charlottesville, VA
    Thanks Chad. I just got it.
  9. Dec 13, 2007 at 6:25 AM
    cvillechopper
    Charlottesville, VA
    Here's the first run of tables. Keeping it simple until we get more data.
    First table is average MPG for the different configurations over years. The second shows the number of tanks for each configuration. I'll be putting more analysis into the tables as we get more data so the numbers actually mean something.
    I can send different file types to those that want them but this is the only format I could get to work on here.
  10. Dec 13, 2007 at 8:32 AM
    cvillechopper
    Charlottesville, VA
    I just got this great idea from a guy on TN so I've created a file that I can send to anyone that wants it to keep track of their info in. Then they can just send me the file periodically and I can incorporate it into the data set. That way you don't have to create your own file and I don't have to send questions to get the info I need for the analysis.
    Send me a PM with your e-mail address if you'd like a copy of the file (or someone tell me how to send excel files on this forum) and I'll send it to you right away.
    Thanks
    James
  11. Dec 13, 2007 at 3:50 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    Was this thing supposed to be for the 2nd gens only? I couldn't help but notice that I'm the only 1st gen.
  12. Dec 13, 2007 at 6:04 PM
    cvillechopper
    Charlottesville, VA
    Nope. It's just that the 2nd gens have been responding. I was really interested to see how the technical advancements have effected mileage over the years. Hopefully we'll get more data.
  13. Dec 13, 2007 at 6:18 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    I was hoping to have some other 1st gens to compare to, but oh well.
    Here's tank latest data for you: 14.966 gallons of 87 / 248.8 miles / still bad o2 sensor
  14. Jan 26, 2008 at 2:33 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    I just emailed info from last 4 tanks. Sorry I didn't get that to you last weekend. I know, I'm a slacker.
  15. Jan 26, 2008 at 2:39 PM
    cvillechopper
    Charlottesville, VA
    Got it. Thanks.
  16. Feb 6, 2008 at 8:53 AM
    cvillechopper
    Charlottesville, VA
    Marvin02 set up this site for me to load the large data files to as well as come tables, etc.
    Looking for feedback...
    http://www.tacompg.info/
    Enjoy!
  17. Mar 6, 2008 at 7:06 AM
    cvillechopper
    Charlottesville, VA
    Bumpity, Bump, bump.
  18. Mar 6, 2008 at 6:58 PM
    Toy4Life
    Chad
    Slippery Rock, PA
    Just emailed you.
  19. Mar 7, 2008 at 7:05 AM
    cvillechopper
    Charlottesville, VA
    Just got it. Thanks.
  20. Mar 7, 2008 at 7:42 AM
    corywilson13
    corywilson13 Canadian Taco
    Vancouver Island, British Columbia
    08 Taco sr5 Access 6spd Std
    Grom-Ipod, Bed Mat, Tool Box with TRD mat, Inifnity 6x9's.
    2008
    10,000km
    4.0L V6
    access
    SR5
    secondary air-filter removed (no)
    Stock airfilter
    4x4 (yes)
    Transmission (6-spd manual)
    Eco VPE installed (no)
    Stock exhaust
    Total miles for a given tank (About 470 km)
    Gallons at fill-up (About 63L)
    Accessories (Tool box filled with tools, bedmat)
    Towing/hauling for this tank (no)
    95km*Approximate average speed
    80-90*% highway miles
