Voltage Drop when Hot, Warm
Discussion in 'Technical Chat' started by BlueT, May 12, 2014.
  1. May 12, 2014 at 11:24 AM
    BlueT
    BlueT [OP] Well-Known Member
    NorthEast
    07 Dbl Cab LB with LSD
    Ok so this is weird and annoying.
    Vehicle: 2008 Sequoia with 5.7L and Tow Package. 70 000 miles.
    Problem: Voltage drops to below 13V when car warms up, or its Warm... (above 150F)
    When car starts in the morning (fully Cold voltage goes to 13.9 V and stays like this until car warms up. than starts dropping to 13V and hovers around 13V (+- 0.2V).
    If I start the car when its warm: Voltage starts at 13V and hovers at that voltage.
    Serpentine Belt was replaced some time ago with new battery (probably 4000 miles ago). No squeals during start up and when its running.
    So trying to figure out what gives.
    No problem before Winter now when temperatures had stood up suddenly voltage is junk.
    Any ideas ?
  2. May 13, 2014 at 5:15 AM
    nickonfire700
    nickonfire700 Reg. Cab Nation Member
    Nick
    Rhode Island
    05 Reg Cab SR5 4x4
    Satoshi grill, 3rd Gen TRDOR Bucket Seats, TRD front skid plate, TRD Beadlock Wheels, TRD Exhaust, OEM bed mat, LCE Header, LCE Balance Shaft Delete, ECGS front diff bushing, TRD Sport LSD rear diff, Diode Dynamics SS3 Sport fog lights, Stainless Steel Brake-lines, No A/C with Defrost mod, 2014 OEM Radio, Illuminating 4x4 switch, Various LEDs, UWS Toolbox, Proven Design Products Mudflaps, Bilstein 8112 front Coilovers w/ rear Bilstein 5125's/IronMan lift leaf springs, Archive Garage Hammer Hangers, JBAs HD UCAs, SOS Bolt-On rock sliders, TRD bedside decals, ImMrYo Mirror Bracket, Relocated rear diff breather, 2019 Steering wheel, color matched door handles
    I assume you checking the voltage at the battery? Or from the inside from some other source? I am not overly sure if that would make a difference, but it could. But I really think your alternator is done. Take it out, and have it tested by advance auto or auto zone. For reference, I have a 4 cyl truck and my voltage goes from (when very cold) 14.4 volts to (very warm) 13.5 volts.
  3. May 13, 2014 at 5:36 AM
    BamaToy1997
    Bill
    Navarre, FL
    The ECU has a voltage sense wire that controls the alternator's output. If the vehicle is cold, then when you first start the engine you will have a slightly higher output from the alternator as it does it's initial recharge of the battery from starting your engine, as well as the common parasitic loads of a vehicle that has sat for a while. It does this because after sitting, your battery voltage is at 12.6 volts, or a tiny bit lower depending on the active loads.
    This is where things get a little different: When the engine is hot, your battery still has a "surface charge" that can be as high as 13.5 volts, or even more. When you start the engine the ECU will not ramp up the alternator as much, hence the 13V that you see. As mentioned the true reading should be done at the battery terminals.
    If you are concerned with alternator output at idle, then an easy test would be to start the truck up warm, connect a volt meter to the battery terminals, and watch the voltage gauge as you load the system by turning on all your lights, and the high beams, as well as your hazard flashers. If the voltage remains at 13V or higher, you should be fine. If it drops down to 12.8 or more AT THE BATTERY, then you may have a weak alternator.
  4. May 13, 2014 at 8:23 AM
    BlueT
    NorthEast
    Ok I understand ECU role but FSM says truck should be between 13.2V and 14.8V when 2000 RPMS and no load. Truck stays 13V and just bounces voltage by 0.2V up and down. Nothing in manual if that voltage is at cold or warm.
    Truck definitely had higher voltage than this before. So I am trying to figure out if this is Alternator dying or something else (lose ground, lose cable)
    Battery problem again ( realized battery is wet)
    For comparison My Tacoma stays at 14V and above. regardless if its warm or cold.
    Just dont want to swap $1000 alternator for nothing, especially alternator on that Truck is major pita to swap.
    My reading comes from Scanguage. but planning today to deep dive and get reading straight from Alternator cables. Wondering if any relay would play role in this. Somebody on Tundra forum wrote they had the same issue and it turns out one of those massive fuses where a problem.
  5. May 13, 2014 at 1:46 PM
    BamaToy1997
    Bill
    Navarre, FL
    The prior question from myself and another still stand: Where did you measure the voltage at? That is a major factor there.
  6. May 16, 2014 at 4:42 AM
    Shadetree
    Shadetree Well-Known Member
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    Locking Tailgate & Gas Cap and extra bed D-rings
    Please see Section 9.3.3 in the Car and Deep Cycle Battery FAQ on www.batteryfaq. org for a Charging Voltage Temperature Compensation Table.
  7. Oct 21, 2015 at 2:14 PM
    gearcruncher
    Canadain bumper technician
    I am having voltage issues as well
  8. Oct 21, 2015 at 2:21 PM
    BamaToy1997
    Bill
    Navarre, FL
    Hey Gear! Haven't seen you in a while! What kind of voltage issues are you having?
  9. Oct 23, 2015 at 5:37 PM
    Shadetree
    BiLL
    Bozeman, Montana
    2011 Access Cab 4x2
    If you have a healthy alternator and battery, then look for voltage drops in the cabling, fuses, relays, etc. on both the hot and ground sides. I bet your battery is not being fully charged. To prevent sulfation you need to keep the battery fully charged with the battery manufacturer's recommended temperature compensated charging voltages.
